2014-12-27, 14:03
ah sorry for that, i think i found de problem but don't know how to fix it.
my setup is OpenElec 4.97.3 (but with 4.2.1 is the same) on the DN2820, i have a HP MCE remote and a URC 7960 remote that has cloned the HP buttons, so they are basically identical.
this is what is going on with a short debug log
the first parti is the URC, if i press rapidly DOWN button Lirc doesn't recognize every single button pressed but instead a repeat.
the second part is button DOWN hold down for a couple of sec, and it repeats correctly as it should.
the third part is the HP remote with the same code, if i press rapidly DOWN Lirc can read every button press correctly and so UI are not laggy at all.
the last part is a hold DOWN button and it repeats as it should.
that is strange because the code is the same on both remotes as you can see, so there is something like calibration or config that cannot see the remote rapidly pressing the down button on the URC.
i tried to play a bit with ir-keytable -D -P but no success.
i tried KODIbuntu 14 official and both HP and URC remotes are working perfectly fine and identical so it must something in OpenElec that is different in Lirc or so.
Thanks for the support
Quote:11:50:22 T:139743604737920 DEBUG: LIRC: Update - NEW at 2199177:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:22 T:139743604737920 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
11:50:24 T:139743604737920 DEBUG: Previous line repeats 5 times.
11:50:24 T:139743604737920 DEBUG: LIRC: Update - NEW at 2201059:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:26 T:139743604737920 DEBUG: LIRC: Update - NEW at 2203641:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:26 T:139743604737920 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
11:50:29 T:139743604737920 DEBUG: Previous line repeats 12 times.
11:50:29 T:139743604737920 DEBUG: LIRC: Update - NEW at 2206371:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:33 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210369:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:33 T:139743604737920 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
11:50:33 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210559:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:33 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210598:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:33 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210731:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:33 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210744:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:34 T:139743604737920 DEBUG: LIRC: Update - NEW at 2210964:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:34 T:139743604737920 DEBUG: LIRC: Update - NEW at 2211003:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:34 T:139743604737920 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
11:50:34 T:139743604737920 DEBUG: LIRC: Update - NEW at 2211215:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
11:50:35 T:139743604737920 DEBUG: LIRC: Update - NEW at 2212483:6c 0 KEY_DOWN devinput (KEY_DOWN)
11:50:35 T:139743604737920 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
11:50:37 T:139743604737920 DEBUG: Previous line repeats 8 times.
11:50:37 T:139743604737920 DEBUG: LIRC: Update - NEW at 2214775:6c 0 KEY_DOWN_UP devinput (KEY_DOWN_UP)
