(2015-12-09, 17:41)SONY007 Wrote: [ -> ] (2015-12-09, 01:01)jdf76 Wrote: [ -> ]Can you connect to a SMB network share by going to the file manager and then going to windows share?
(2015-12-08, 22:58)SONY007 Wrote: [ -> ]I've got Kodi installed on my non jailbroken device but what I've been trying to do is restore from a backup that I had saved on my WD mycloud which is what I would normally do, but for some reason when I go to install from zip and then windows network smb it sees my device but won't connect. Have I forgotten to tick a box somewhere or change a setting maybe?
It does the same thing, it sees the device but the 'timeout error message' appears when I try to access the folder.
Just trying again to access windows network (SMB) via file manager and it see the NAS but when I try to drill down to the next sub folder I still get the spinning wheel and the timeout message.
i downloaded the kodi DEB tvos, but the application doesn't work. it says this application is not supported for my mac. can u help please
(2016-01-25, 10:50)JDQ24 Wrote: [ -> ]i downloaded the kodi DEB tvos, but the application doesn't work. it says this application is not supported for my mac. can u help please
What version of OS X does your computer have?
The application requires 10.9 or newer
(2016-01-23, 21:18)DanTheMan827 Wrote: [ -> ]You would need to resign
Could you potentially change the effecting values (TimeToLive, etc?) within the provisioning profile?
(2016-01-25, 19:22)Chinese1904 Wrote: [ -> ] (2016-01-23, 21:18)DanTheMan827 Wrote: [ -> ]You would need to resign
Could you elaborate?
Are you talking about changing default kodi settings or modifying the provisioning profile? I can't modify the provisioning profile because that's signed by Apple
My wife got mad at me the last time I resigned. She wanted to know how we were going to pay the bills.
(2016-01-25, 20:38)wgstarks Wrote: [ -> ] (2016-01-23, 21:18)DanTheMan827 Wrote: [ -> ]You would need to resign
Haha, clever clever...
one dash and a word changes completely...
(2016-01-25, 20:16)DanTheMan827 Wrote: [ -> ] (2016-01-25, 19:22)Chinese1904 Wrote: [ -> ] (2016-01-23, 21:18)DanTheMan827 Wrote: [ -> ]You would need to resign
I opened the .mobileprovision file to look at it. I was wondering that if you change
<key>ExpirationDate</key>
<date>2016-04-17T18:13:44Z</date>
and
<key>TimeToLive</key>
<integer>365</integer>
would that make the app run past the year?
(2016-01-25, 23:25)Chinese1904 Wrote: [ -> ] (2016-01-25, 20:16)DanTheMan827 Wrote: [ -> ] (2016-01-25, 19:22)Chinese1904 Wrote: [ -> ]Could you potentially change the effecting values (TimeToLive, etc?) within the provisioning profile?
and
Provisioning profiles can't be modified
Hi
Is there any one that would help me for a couple of bucks, instilling kodi on the apple tv, tried everything and it won't work...
Team viewer maybe?
(2016-01-26, 15:58)arneleo Wrote: [ -> ]Hi
Team viewer maybe?
It's not so difficult and you don't have to pay anything. If you can't find anyone, I'd help you tonight from 9pm Chicago time. I don't know where you're located.
Hi Thanks
I am i norway, but want to figure this out so will wait for your help
thanks
(2016-01-26, 16:47)arneleo Wrote: [ -> ]Hi Thanks
I am i norway, but want to figure this out so will wait for your help thanks
Please make sure you already installed Xcode 7.2 on your Mac already and dowloaded the iOS App Signer.
If you have iMessage, you can send me private message where to contact you.
Norway? Nice country. I'm German born American.
(2016-01-26, 16:17)underwriter Wrote: [ -> ] (2016-01-26, 15:58)arneleo Wrote: [ -> ]Hi
Team viewer maybe?
(2016-01-26, 17:35)underwriter Wrote: [ -> ] (2016-01-26, 16:47)arneleo Wrote: [ -> ]Hi Thanks
I can't send private messages for some reason, but my email is ** email removed **
You're too new and haven't posted enough to send PMs that's why
I've also gone ahead and removed your email while sending a PM on your behalf
