(2023-12-18, 20:43)Pienoet Wrote: [ -> ] (2022-03-12, 15:49)kambala Wrote: [ -> ] (2022-03-11, 21:37)MoshePupkin Wrote: [ -> ]I followed the steps to install it on the latest Apple TV and keep getting the "unable to install" message...any ideas?
please check troubleshooting steps from https://forum.kodi.tv/showthread.php?tid=353308
also: which macOS version do you have and which Xcode version you're using?
What version macos an xcode is needed?
usually any would work. Just that Xcode 15.0.x has issues with uploading ipa to device.
which step are you having troubles with?
(2023-12-19, 08:33)kambala Wrote: [ -> ] (2023-12-18, 20:43)Pienoet Wrote: [ -> ] (2022-03-12, 15:49)kambala Wrote: [ -> ]please check troubleshooting steps from https://forum.kodi.tv/showthread.php?tid=353308
no issues yet i just finshed setup a VMware macOS Monterey with xcode 13.3.1 on my AMD pc.
we'll see of this gonna work.
(2023-12-19, 22:50)Pienoet Wrote: [ -> ] (2023-12-19, 08:33)kambala Wrote: [ -> ] (2023-12-18, 20:43)Pienoet Wrote: [ -> ]What version macos an xcode is needed?
FYI you can run 14.2 on Monterey
(2023-12-19, 23:07)kambala Wrote: [ -> ] (2023-12-19, 22:50)Pienoet Wrote: [ -> ] (2023-12-19, 08:33)kambala Wrote: [ -> ]usually any would work. Just that Xcode 15.0.x has issues with uploading ipa to device.
i tried 14.3.1 and it didnt work 13.3.1 works but i cant see my apple tv in xcode
(2023-12-20, 00:12)Pienoet Wrote: [ -> ] (2023-12-19, 23:07)kambala Wrote: [ -> ] (2023-12-19, 22:50)Pienoet Wrote: [ -> ]no issues yet i just finshed setup a VMware macOS Monterey with xcode 13.3.1 on my AMD pc.
i tried 14.3.1 and it didnt work 13.3.1 works but i cant see my apple tv in Xcode
14.3.1 doesn't work, but 14.2 does
your Mac and atv must be on the same local network. You can also try adding device via its IP address: the + button in the bottom.
(2023-12-20, 08:44)kambala Wrote: [ -> ] (2023-12-20, 00:12)Pienoet Wrote: [ -> ] (2023-12-19, 23:07)kambala Wrote: [ -> ]FYI you can run 14.2 on Monterey
also i cant fix this and my apple tv is in the same network as my macos vmware
(2023-12-20, 17:11)Pienoet Wrote: [ -> ] (2023-12-20, 08:44)kambala Wrote: [ -> ] (2023-12-20, 00:12)Pienoet Wrote: [ -> ]i tried 14.3.1 and it didnt work 13.3.1 works but i cant see my apple tv in Xcode
I don't have any experience with devices on a virtual machine
have you tried this?
Quote:You can also try adding device via its IP address: the + button in the bottom
Are you able to login to iCloud and and use your AppleID? You might need to virtualize OpenCore etc to define a SMBIOS
(2023-12-20, 20:47)emveepee Wrote: [ -> ]Are you able to login to iCloud and and use your AppleID? You might need to virtualize OpenCore etc to define a SMBIOS
yes i can login with my icloud
