2016-02-16, 04:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
2016-02-16, 04:22
Any reason why I would have no problems installing on my iPhone and iPad Air but when I install on my iPad Pro and go to launch from the device it just crashes and goes back to the homescteen?
2016-02-16, 20:47
Thanks Dan for your patience today, One last question, i did one for my friend when he was visiting last week but now he has gone back to scotland. Will it stop opening on his apple tv4 once 90 days is up?
I only had the free dev account
2016-02-16, 20:56
(2016-02-16, 20:47)robappleby Wrote: [ -> ]Thanks Dan for your patience today, One last question, i did one for my friend when he was visiting last week but now he has gone back to scotland. Will it stop opening on his apple tv4 once 90 days is up?
Yes, it will stop opening after 90 days if you only have the free account
You need to re-sign every time it expires (90 days for free / 1 year for paid)
2016-02-16, 21:26
(2016-02-16, 20:56)DanTheMan827 Wrote: [ -> ](2016-02-16, 20:47)robappleby Wrote: [ -> ]Thanks Dan for your patience today, One last question, i did one for my friend when he was visiting last week but now he has gone back to scotland. Will it stop opening on his apple tv4 once 90 days is up?
By re sign you mean you have to load up the IPA again?
That's a bummer from a peace of mind perspective , but I understand it's working within apples parameters
2016-02-16, 23:13
(2016-02-16, 21:26)ATVwaffles Wrote: [ -> ](2016-02-16, 20:56)DanTheMan827 Wrote: [ -> ](2016-02-16, 20:47)robappleby Wrote: [ -> ]Thanks Dan for your patience today, One last question, i did one for my friend when he was visiting last week but now he has gone back to scotland. Will it stop opening on his apple tv4 once 90 days is up?
Yeah, I don't know the exact process since I haven't had my free account for more than 90 days but I would imagine you would go back into Xcode with a blank project that uses the same ID as before and it would offer to fix the issue just like initially... or it may even do it automatically...
2016-02-17, 00:37
I finally got it to install on my iPad but the app will crash before I can see anything... Any suggestions?
(15.2-1 on iOS 9.2.1)
2016-02-17, 04:04
When i try to download the kodi DEBs it says that it is unable to find the link.
Any suggestions?
Any suggestions?
2016-02-17, 20:55
Hey I have done all but its want work :/
I try all given get
No code signature found. -> iPhone, iPad
The application does not have a valid signature. -> AppleTV4
I have a paid dev account...
Thanks for your help
and I have use for iPhone the iOS and Apple TV with apple tv project the TVOS Profile
I try all given get
2016-02-17, 21:45
(2016-02-17, 20:55)ioshoop Wrote: [ -> ]Hey I have done all but its want work :/
I try all given get
Do you have the newest version of iOS App Signer?
This error generally means that you didn't select any code signing certificate or that you selected the wrong one
You also have to choose the correct provisioning profile based on the type of device you're installing to (tvOS or iOS)
Also, you may have an expired certificate on your system... See this post for more details...
2016-02-17, 22:07
jes I have the 17r
for IOS I use iOS Team provisioning profile: APP ID (same as xcode project)
for TVOS -> tvOS Team provisioning profile: APP ID (same as xcode project)
I have delete my account on settings page. delete all developer certificates in keychain and reset it
2016-02-17, 23:20
(2016-02-16, 23:13)DanTheMan827 Wrote: [ -> ](2016-02-16, 21:26)ATVwaffles Wrote: [ -> ](2016-02-16, 20:56)DanTheMan827 Wrote: [ -> ]Yes, it will stop opening after 90 days if you only have the free account
I'll be waiting to see what happens to yours, then I'll know what is going to happen to mine too....
2016-02-18, 21:29
Hi Dan
I tried what you said me to put on terminal
xcode-select --install
but the program ios app signer me keeps coming
Error processing deb file
2016-02-18, 21:53
If you run the this command in terminal does it complain about not being installed or does it "just work"
if it works, post the log of iOS App Signer after failing to sign (View > Application Log)
ar
2016-02-19, 17:05
Hi All,
Thanks for the guide!
Finally, I can install kodi in my iPhone, but when I open it, the app crashes always!
I check the logs and find an error:
Incident Identifier: 0E160FD8-44F9-4D20-A72A-BB5470319796
CrashReporter Key: d92a3bb2bae47d00ff9e550bc64eb007dfe1d458
Hardware Model: iPhone8,2
Process: Kodi [596]
Path: /private/var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Kodi
Identifier: com.betosbar.Kodi-ios2
Version: 1.0
Code Type: ARM (Native)
Parent Process: launchd [1]
Date/Time: 2016-02-19 08:54:47.47 -0600
Launch Time: 2016-02-19 08:54:47.47 -0600
OS Version: iOS 9.2.1 (13D20)
Report Version: 105
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x00000000e7ffdefe
Triggered by Thread: 0
Filtered syslog:
None found
Dyld Error Message:
Dyld Message: Library not loaded: @executable_path/Frameworks/libsmbclient.dylib.0
Referenced from: /var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Kodi
Reason: no suitable image found. Did find:
/var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Frameworks/libsmbclient.dylib.0: mmap() errno=1 validating first page of '/var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Frameworks/libsmbclient.dylib.0'
/private/var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Frameworks/libsmbclient.dylib.0: mmap() errno=1 validating first page of '/private/var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Frameworks/libsmbclient.dylib.0'
Dyld Version: 370.6
Binary Images:
0x2c000 - 0x1c93fff Kodi armv7 <2fe92c40647d3b399d4f1d3e6b7f2117> /var/mobile/Containers/Bundle/Application/57257267-4C7E-4CCE-B553-8DFEAD30E0DF/Kodi.app/Kodi
0x1fe28000 - 0x1fe4ffff dyld armv7s <bf233c7c81083586bfb84e9c19eb135c> /usr/lib/dyld
I donĀ“t know what can be the problem, any suggestion?
Thanks for the help!
Nice day
betosbar
Process: Kodi [596]
Version: 1.0
Report Version: 105
Filtered syslog:
None found
Dyld Error Message:
Dyld Version: 370.6
Binary Images:
Nice day
betosbar
