I have denon 6200 with hdr and 2.0a. Gonna test with 4k TV when i receiver q10 from batch 2
you are lucky
the HDR will be available with the next f/w
in my case I have 2 choices with the himedia Q10 pro :
Q10 pro connected to my receiver but no HDR.
Q10 pro connected to my tv 4k and spdif with my receiver but no HD audio.
am I wrong ?
(2016-05-11, 15:51)OlivierQC Wrote: [ -> ]you are lucky
But the big question is when the next f/w will be out? Was promised already a couple of weeks ago i read.
You're stated connection options are correct.
So, according to @OlivierQC's message, HDR doesn't seem to work with Kodi v17.0 (Well... that was kind of what was expected). Thanks Olivier for testing.
I am little confused here. So, the shipping firmware doesn't support HDR, but Olivier somehow got a beta firmware that has HDR support?
I don't think the Pioneer SC-81 can be upgraded to HDMI 2.0a. The only way to get HDR and HD audio without upgrading the AVR would be by getting a HDFury Integral.
i think this week (source futeko) or may be the next week (source hdmkv)
Yamaha RX-A1050
This AV receiver completely supports with the latest HDMI standards. Thanks to transmission of 4K video at 60 frames per second pass-through, you can fully enjoy the high definition video quality of 4K without degradation. It also adheres to the HDCP2.2 copyright protection standard for 4K video transmission. It also supports HDR (High Dynamic Range) Video which provide enhanced picture quality by simultaneously enabling greater detail for both the dark and bright parts of an image. Furthermore it supports wider color gamut of BT.2020 pass-through.
Latest firmware update will be required to enable HDR.
RX-V1079/RX-V2079/RX-V3079/RX-A1050/RX-A2050/RX-A3050 Firmware Update Version 1.77
Latest firmware includes
1. The latest multi dimensional surround sound DTS:X playback
DTS:X decode
Neural:X upmixing processing
DTS Dialogue Control
2. HDR (High Dynamic Range) pass through and GUI overlay
3. Connectivity improvement with Rhapsody/Napster service as well as some STBs/TVs via HDMI.
4. MusicCast functionality improvement
i. Search function for vTuner
ii. Sort function for "Favorites"
iii. “Recents” feature to display recently listened 40 songs
iv. Audio sync of its external inputs with other MusicCast models in MusicCast Link mode. Some conditions may apply.
v. Speed Boost in Link Control (suitable for wired connection)
5. Fixing network initial setup issue when using WiFi WEP security method
yes and I have the same teeth
Maybe UHD TV was getting
at this pun on "beaver"
. Maybe this only has double meaning in the U.S.
(2016-05-11, 21:18)hdmkv Wrote: [ -> ]Maybe UHD TV was getting at this pun on "beaver" . Maybe this only has double meaning in the U.S.
No , I can definitely say that the pun was intended as it also has a double meaning here in the UK , hence the...
"i will get my coat" smiley
Good morning everybody
What do you think about ExpressX engine v2, this is my opinion but the image processing is less visible on screen than the Version 1 with Q5/Q10 4K3D.
I see the contrast changed a bit but that's it, may be it is normal with 4K demo...
I know that the settings are not the same for each person but what are your settings ?
(2016-05-11, 16:04)OlivierQC Wrote: [ -> ]in my case I have 2 choices with the himedia Q10 pro :
am I wrong ?
q10 connected to TV and HD audio via ARC is possible depending on TV model.
