(2016-09-27, 10:55)DenisDA Wrote: [ -> ] (2016-09-27, 10:42)Koying Wrote: [ -> ] (2016-09-27, 10:21)DenisDA Wrote: [ -> ]The options openWRT are added to a functionality of Zidoo X9S:
Yeah, it apparently can run openWRT, but is definitely for another purpose than a media player...
At Zidoo X9S modules from openWRT are fastened to the Android kernel though they advertize it as two systems.
quote, X9s have awesome network performce 100MB/s !
never see before on ARM soc
Bit slow actually that 100MB/s, how about 116MB/s ~ 930Mbps on a 64bit ARM ODROID C2 - AMLogic S905 SoC
This is getting close to Maxiing out a Gigabit Ethernet connection. (125 MB/s = 1000 Mbps)
http://forum.odroid.com/viewtopic.php?f=135&t=19826
It actually depends on what server / client setup you are talking to as well.
Curiously the C2 is using a Realtek RTL8211F integrated Ethernet transceiver.
This is test
http://jell.yfish.us/
5Ghz WI-Fi
Zidoo X9S maximum 25Mbps without freeze, while SHIELD 90Mbps without freeze, IconBit XDS74K 80Mbps without freeze!
On wire Zidoo X9S 160Mbps without freeze.
Check who has 5Ghz WiFi.
Over CAT5E wired, via my Synology NAS, it can actually do 300Mbps using native player. With ZDMC and internal player, 180Mbps. Your NAS and network affect bandwidth obviously.
I'll try the max available 400Mbps later today.
Also have a new APK from @mirror88 to test DVD menu support (folder and ISO). Had to borrow a DVD from my neighbor as I had zero retail DVDs left/saved at home.
Got my copy today, will review it sunday.
Where to get latest firmware ?
Quote:Audio absent in Sony 'Camp' and other HDR HEVC 10-bit videos
We tested a lot of HEVC HDR 10bit videos.There is no audio issue.What about your settings?RAW or PCM
You know on that page theres a link to download apk if u still have old version zdmc
but that apk download is a zip file no apk?
(2016-09-28, 19:07)Skank Wrote: [ -> ]You know on that page theres a link to download apk if u still have old version zdmc
Which version is the current firmware?Just check the online upgrade.v1.2.3 is the latest version.Forget about the ZDMC version.also will be upgrade.
havent checked yet
will boot and immediately update firmware to 1.2.3 , so not local but online?
will do in an hour
thx
And what's about Wi-Fi 5Ghz and 25Mbps maximum?
(2016-09-28, 19:53)Skank Wrote: [ -> ]havent checked yet
will do in an hour
thx
Not available OTA, so must update via local if I recall correctly.
(2016-09-28, 19:06)mirror88 Wrote: [ -> ]We tested a lot of HEVC HDR 10bit videos.There is no audio issue.What about your settings?RAW or PCM
RAW...
With native player, I don't get audio from any of these for example:
Sony Camp
Exodus and Life of Pi samples
LG Daylight
BT.2020.20140602.ts
Euh for the wrapper...
You have to download this from google store first? It doesnt come preinstalleD?
Plus, we have to pay for the wrapper?
Update to latest firmware did it automatically
