2018-08-27, 20:07
Thanks for your reply! One more question, if I enable "Use Task Scheduler on Windows", should I be able to see the scheduled task within the Task Scheduler? I'm not able to find the task if so.
(2018-08-27, 20:07)purplehorseshoes Wrote: [ -> ]Thanks for your reply! One more question, if I enable "Use Task Scheduler on Windows", should I be able to see the scheduled task within the Task Scheduler? I'm not able to find the task if so.I can't guarantee that the Windows Task Scheduler code is working perfectly. I haven't fully tested it for a while.
(2018-08-27, 20:10)purplehorseshoes Wrote: [ -> ]Is there a keyboard shortcut or a button or something that I can use to immediately start recording whatever I'm watching?Not in IPTV Recorder but there is in TV Guide Fullscreen.
(2018-07-13, 21:25)primaeval Wrote: [ -> ]If your Android device isn't routed it is going to be hard to find the binary ffmpeg from an Android app or apk.Just discovered this thread. What a great addon primaeval. I have everything set up and working fine on my Windows systems. But finally realized ffmpeg couldn't run on my android phone because it's not rooted. Reading through this thread I found a recent post with your comment above, and started to wonder if it may actually be possible to track down a binary version of ffmpeg that will execute without being put in that root \data\data folder. Does such a beast actually exist?
The permissions prevent apps looking at each other's files
(2018-09-01, 21:00)JQZ* Wrote: [ -> ]Thanks. I'm pretty sure this works on an unrooted Android device. I just tried my xmltv Meld addon on a Nvidia Shield which does the same thing with busybox as ffmpeg and that worked.(2018-07-13, 21:25)primaeval Wrote: [ -> ]If your Android device isn't routed it is going to be hard to find the binary ffmpeg from an Android app or apk.Just discovered this thread. What a great addon primaeval. I have everything set up and working fine on my Windows systems. But finally realized ffmpeg couldn't run on my android phone because it's not rooted. Reading through this thread I found a recent post with your comment above, and started to wonder if it may actually be possible to track down a binary version of ffmpeg that will execute without being put in that root \data\data folder. Does such a beast actually exist?
I was also wondering if you could add an option to disable a rule. There are news programs I'd like to record that air Mondays through Fridays, but not on weekends. It'd be nice to be able to disable them for those 2 days, and then re-enable them on Manday rather than have to delete and then reconfigure them again.
Amazing work yours as always p.![]()
(2018-09-01, 21:31)primaeval Wrote: [ -> ] Thanks. I'm pretty sure this works on an unrooted Android device. I just tried my xmltv Meld addon on a Nvidia Shield which does the same thing with busybox as ffmpeg and that worked.Are you suggesting that I could install your xmltv Meld addon and use some component of that to set in IPTV Recorder in the ffmpeg option and get recording working on my unrooted phone? Sorry. I'm not all that knowledgeable about most things Kodi.
The addon works within Kodi and has access to it's own data\data folder but no other processes.
Quote:I don't really want to mess around with days of the week schedules but if you enable that news program as a daily recording and it doesn't occur at that time at the weekends it should just record monday to friday.I could certainly use the rule as it is. Repeats of those programs air at different hours on the weekends. But it really wouldn't be a problem just to delete them. Just to be clear, I wasn't suggesting you create something to select specific days for a program to be recorded. I just thought it might be a simple tweak to disable just the rule, and then re-enable it later. I've not looked at the files the addon creates yet to see if I could create a batch file that might achieve what I'm after.
Is that good enough?
(2018-09-01, 22:23)primaeval Wrote: [ -> ]I confused you about xmltv Meld. Ignore that.Well I struggled with getting ffmpeg to work in android. I found an earlier post in this thread that seemed to be saying the phone needed to be rooted. And when I saw these errors in the kodi.log, it seemed to be confirming that. I was guessing that error was due to an inability to write to any \data\data folder if it actually exists hidden somewhere.
I just tested IPTV Recorder on my unrooted Android Shield and it recorded fine in the default temp folder.
I could even watch the recording as it recorded.
Just do Record Daily for your news program and it should just record weekdays if they are at the same time Monday to Friday.
Check they are exactly at the same time.
02:04:17.489 T:18446744071996963120 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: [Errno 8] Exec format error
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/addon_data/plugin.video.iptv.recorder/jobs/ac2e524a-ac33-11e8-977e-9d57b890b082.py", line 6, in <module>
p = subprocess.Popen(cmd, shell=False)
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-21/lib/python2.7/subprocess.py", line 711, in __init__
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-21/lib/python2.7/subprocess.py", line 1343, in _execute_child
OSError: [Errno 8] Exec format error
02:04:47.329 T:18446744072484572500 WARNING: CPeripheralBusAndroid: failed to update input device with ID 1 because it couldn't be found
20:36:56.128 T:149305660656 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:36:56.128 T:149305660656 NOTICE: -----------------------------------------------------------------------
20:36:56.128 T:149305660656 NOTICE: Starting Kodi (17.6 Git:20171119-ced5097). Platform: Android ARM 64-bit
20:36:56.128 T:149305660656 NOTICE: Using Release Kodi x64 build
20:36:56.128 T:149305660656 NOTICE: Kodi compiled Nov 19 2017 by GCC 4.9.0 for Android ARM 64-bit API level 21 (API level 21)
20:36:56.128 T:149305660656 NOTICE: Running on NVIDIA SHIELD Android TV with Android 8.0.0 API level 26, kernel: Linux ARM 64-bit version 3.10.96-tegra
20:36:56.128 T:149305660656 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
20:36:56.128 T:149305660656 NOTICE: 4 CPU cores available
20:36:56.128 T:149305660656 NOTICE: Product: foster_e, Device: foster, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: foster_e
20:36:56.130 T:149305660656 NOTICE: External storage path = /storage/emulated/0; status = ok
20:36:56.130 T:149305660656 NOTICE: ARM Features: Neon disabled
20:36:56.130 T:149305660656 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
20:36:56.130 T:149305660656 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
20:36:56.130 T:149305660656 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-7izRBbn7d4vzticmXKpGpw==/lib/arm64
20:36:56.130 T:149305660656 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
20:36:56.130 T:149305660656 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
20:36:56.130 T:149305660656 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
20:36:56.130 T:149305660656 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
20:36:56.130 T:149305660656 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
20:36:56.130 T:149305660656 NOTICE: The executable running is: /data/app/org.xbmc.kodi-7izRBbn7d4vzticmXKpGpw==/lib/arm64/libkodi.so
20:36:56.130 T:149305660656 NOTICE: Local hostname: localhost
20:36:56.130 T:149305660656 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
01:52:53.321 T:18446744072079030576 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:52:53.321 T:18446744072079030576 NOTICE: -----------------------------------------------------------------------
01:52:53.321 T:18446744072079030576 NOTICE: Starting Kodi (17.6 Git:20171114-a9a7a20). Platform: Android ARM 32-bit
01:52:53.321 T:18446744072079030576 NOTICE: Using Release Kodi x32 build
01:52:53.321 T:18446744072079030576 NOTICE: Kodi compiled Nov 14 2017 by GCC 4.9.0 for Android ARM 32-bit API level 21 (API level 21)
01:52:53.321 T:18446744072079030576 NOTICE: Running on samsung SM-G550T2 with Android 6.0.1 API level 23, kernel: Linux ARM 32-bit version 3.10.9-8180604
01:52:53.326 T:18446744072079030576 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
01:52:53.327 T:18446744072079030576 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
01:52:53.327 T:18446744072079030576 NOTICE: Product: on5ltetmowal, Device: on5ltetmo, Board: universal3475 - Manufacturer: samsung, Brand: samsung, Model: SM-G550T2, Hardware: universal3475
01:52:53.333 T:18446744072079030576 NOTICE: External storage path = /storage/emulated/0; status = ok
01:52:53.333 T:18446744072079030576 NOTICE: ARM Features: Neon enabled
01:52:53.333 T:18446744072079030576 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
01:52:53.333 T:18446744072079030576 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
01:52:53.333 T:18446744072079030576 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-1/lib/arm
01:52:53.334 T:18446744072079030576 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
01:52:53.334 T:18446744072079030576 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
01:52:53.334 T:18446744072079030576 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
01:52:53.334 T:18446744072079030576 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
01:52:53.334 T:18446744072079030576 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
01:52:53.334 T:18446744072079030576 NOTICE: The executable running is: /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
01:52:53.334 T:18446744072079030576 NOTICE: Local hostname: localhost
01:52:53.335 T:18446744072079030576 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
01:52:53.335 T:18446744072079030576 NOTICE: -----------------------------------------------------------------------
01:52:53.346 T:18446744072079030576 NOTICE: load settings...
01:52:53.396 T:18446744072079030576 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
01:52:53.409 T:18446744072079030576 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
01:52:53.442 T:18446744072079030576 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
01:52:53.452 T:18446744072079030576 NOTICE: Float is supported
01:52:53.453 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 32000 supported
01:52:53.453 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 44100 supported
01:52:53.454 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 48000 supported
01:52:53.454 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 88200 supported
01:52:53.455 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 96000 supported
01:52:53.455 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 176400 supported
01:52:53.456 T:18446744072079030576 DEBUG: AESinkAUDIOTRACK - 192000 supported
01:52:53.472 T:18446744072079030576 NOTICE: Found 1 Lists of Devices
01:52:53.472 T:18446744072079030576 NOTICE: Enumerated AUDIOTRACK devices:
01:52:53.472 T:18446744072079030576 NOTICE: Device 1
01:52:53.473 T:18446744072079030576 NOTICE: m_deviceName : AudioTrack
01:52:53.473 T:18446744072079030576 NOTICE: m_displayName : android
01:52:53.473 T:18446744072079030576 NOTICE: m_displayNameExtra: audiotrack
01:52:53.473 T:18446744072079030576 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:52:53.473 T:18446744072079030576 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR,BC,BLOC,BROC
01:52:53.473 T:18446744072079030576 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
01:52:53.473 T:18446744072079030576 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT,AE_FMT_RAW
01:52:53.473 T:18446744072079030576 NOTICE: m_streamTypes : No passthrough capabilities
01:52:53.495 T:18446744072079030576 DEBUG: CSkinSettings: no <skinsettings> tag found
