(2013-06-06, 20:00)MariusTh86 Wrote: [ -> ]Maybe it or a file inside it is 'in use'? or the folder is protected from changes?
Maybe...
I tried to rename the folder via Finder after mounting the NAS drive and it wouldn't let me.
So I created a new folder called "Houseeeeeeeee Ruleeeeee" with the intention of letting VIMM rename it for me.
I moved all the *.mp4 and *.avi files, deleted the rest (all the old .nfo, etc) and was left with the new folder and the video files.
ViMM then was able to create the new .nfo's and jpgs but didn't create the Season 01 folder nor did it move the files there, and it didn't rename the files...
Any other ideas
Something like that would have been mine idea if you hadn't come up with it yourself. ^^
Did it at least rename the folder to "House Rule" instead of "Houseeeeeeeee Ruleeeeee"?
If the only thing that wasn't affected where the episode files, then I'd check to see if the preferences where set to manage 'files & folders' instead of just 'folders', also check to see if the renaming pattern under the 'TV Tab' is filled out properly.
Edit:
Could you send me a screenshot of the folder and episode files?
Yes it did the following:
1) It renamed "Houseeeeeeeee Ruleeeeeeeeeee" to "House Rules AU" (this is correct)
2) Yes it created tvshow.nfo files
I manually re-created the "Season 01" and "extrafanart" folders myself though, and I only wanted to end up with episodes 9-15 to be moved into the "Season 01" folder!
Here's a Finder screenshot:
Here's two screenshots of my VIMM config...
Any ideas would be great!
(2013-06-10, 10:35)MariusTh86 Wrote: [ -> ]Seems like there was something wrong with the 'regular expression' that checked the filename for 's01e08', I'm not entirely sure what, but try this build:
http://www.mediafire.com/folder/8j6ve2f4..._Debugging
Yes this build is working for me, Thanks!
Great work on such a quick turnaround!
Just downloaded and trying to scrape my movie folder. All movies are in folders with the name as the folder, for instance Braveheart (1995) is the folder, and then the movie is named the same inside the folder.
Anyway, whenever it scans the folder, it gets stuck on A Christmas Story (1983) for some reason, and shows that as the name for the movie for all my movies after that point. Even though as it scans I can see the correct names, when it's done scanning I have about 120 A Christmas Story records.
I tried to manually update each title one by one, and that seemed to work until I rescanned and it did the exact same thing.
I tried using the Update Metadata button and it put A Christmas Story information in all of the other movie's folders!!!
I'm at a loss. I'd love to use it, but I can't get it to scan right.
Not sure how to attach a picture or I would.
Hope someone can help. I also emailed the developer from within the app.
Hey Marius, I'm a little confused how multi-part movies are supposed to work. I have them named <movie name (year)>-pt1.avi, then -pt2, etc. When ViMM renames them, it changes the name of -pt1 by just removing that, leaving the second one as -pt2. XBMC then gets confused and sees two movies.
Should I be telling ViMM in Metadata Editor > Information that the name is <movie name>-pt1? That wouldn't work I don't think, because then it would put the year after the -pt1? What am I doing wrong?
I've supported several 'part'ing systems, except -pt#, -part# should work better right now, but i'll see if i can't add your system as well
Oh, duh - it didn't occur to me that I wasn't using a proper suffix. No need to add -pt#, I can switch to -part#.
The latest posted build (
http://www.mediafire.com/?8j6ve2f4je6et) doesn't seem to automatically download Extras, even though Auto-download is selected in the Preferences. It downloads the poster and the trailer, but that's it. The other items exist, if I manually download each individually it'll download them all, it just won't do it automatically.
Any ideas? Some kind of preferences corruption, or is there something I can try?
(2013-06-14, 10:17)MariusTh86 Wrote: [ -> ]I've supported several 'part'ing systems, except -pt#, -part# should work better right now, but i'll see if i can't add your system as well
Thank you. This explains the issues with my split movies. It would be a welcome update.
Also. Under the Extras menu. Would like to be able to process (less than all but more than 1) selected movies/shows. With more than 1 process. Like say i only want logos, banners and missing posters.
Thanks again for a real Mac Media Manager.
Ok for the love of me I can't change the movie after its been already scraped. It scraped the wrong movie. It was the original version of 101 dalmations and VIMM scraped the 2000' something remake. Now I can change it manually and it'll download the right pics and put it in the file folder but it won't change the main information on VIMM.
Also - am I correct to assume that lock makes it so that VIMM won't change any of the pics/info of a movie that's locked? I wish there was an icon for it.
