2016-02-05, 03:36
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2016-02-05, 20:21
(2016-02-03, 21:37)axbmcuser Wrote: [ -> ]2.8.69 (2016-02-03)
- Reworked floor graphics height and transparency
- Added OPTIONAL setting for removal/replacement of floor-graphics (see Skin Settings)
- Added clean KODI logo for SYSTEM area (native for 1080p)
- Reworked DialogCloseButton.png (now native for 1080p)
- Removed RDS and ProgrammeInfo player control buttons outside of FullscreenVideo (because of inconsistency and problems with ActivateWindow(PVRGuideInfo) - known KODI Bug)
- Reworked standard folder icons like DefaultAddonLyrics.png etc. (just removed the strange border which was "hardcoded" within the graphics - icons itself untouched)
Great! I tried the removal of floor-graphics. I very like it personally. Thanks for your great and hard work
2016-02-09, 02:43
Came across this skin variation today & decided to give it try. VERY NICE! Thanks for spinning off a modern look & keeping it updated.
2016-02-10, 18:47
Hi "axbmcuser"
I installed "The Confluence ZEITGEIST" with KODI 16RC3.
In fact: Excellent. My congratulations.
I liked it. It has seven shortcuts in the submenus of the items on the main page.
He is functional, fast, with good looks, a great job as said.
Keep up the good work.
Hugs.
Hi "axbmcuser"
Hugs.
2016-02-11, 02:17
Thanks for the feedback. Glad you like it.
Update online:
2.8.70 (2016-02-11)
- Slightly cleaned up Settings area KODI logo graphic (no messy border anymore within the Skin)
- Cleaned up global dialog header background graphic (no gradient anymore)
- Reworked standard main List view (50). Poster/thumb now left, list-Panel now wider (making more labels readable without scrolling)
- Some changes in "DialogVideoInfo.xml" (Video Information Dialog) (visual changes + removed conditonal plot height for Windows Platform, slightly optimized cast view)
- Added two additional Roboto-Font variants (Light, Medium) (for now only used in "DialogVideoInfo.xml" to make the text less bulky)
Update online:
2.8.70 (2016-02-11)
2016-02-11, 12:21
(2016-02-11, 02:17)axbmcuser Wrote: [ -> ]Thanks for the feedback. Glad you like it.
Update online:
2.8.70 (2016-02-11)
Hi, "axbmcuser"
Thank you for your message and information.
Excellent update 2.8.70 (02/11/2016). It has very interesting and important improvements in the program, keeping it light and very functional.
Very good work. My congratulations.
Hugs.
2016-02-17, 11:38
2016-02-17, 13:07
It's intentional. Although i slightly remember i left it that way for a reason, i'll recheck next time i work on an update. Greets
2016-02-18, 23:56
Great Skin. Any way to increase the size of the shortcut icons? I'm using about 6 under my videos and there is alot of space between the shortcut icons and they appear a bit small...or maybe move the hompage bar a bit to allow for larger shortcut addons...
2016-02-21, 19:11
This is the best mod confluence that I could see. Congratulations beautiful
2016-02-24, 16:55
(2015-11-05, 22:43)axbmcuser Wrote: [ -> ]@Robotica
Just looked into it. The error regarding the programs main menu icon is just "logfile-cosmetic" and causes no visible problems whatsoever - it's fixed for the next version. Thanks for pointing out!
1080p optimized graphics - .xml dimensions x factor 1.5
(had to make sure .xml graphics dimensions are always even numbers for width and height, so you can multiply clean x 1.5 (720p x 1.5 = 1080p))
- Main menu icons
The 3 DefaultXXX.png graphics are used in multiple sizes, so they i made one large one which is kind of about 1080p optimized. You can see that when having these graphics in large view.
its pretty awesome, but can u add media view 2 as a view option and to stay on that view
prewt
2016-03-05, 05:11
Nice
2016-03-22, 17:36
Are custom home screen nodes made with Library Node Editor possible?
2016-03-24, 00:17
Im using this skin now mainly because of the favorites in the center of the screen.
Three questions:
- what is the small square above the right side of the main menu?
- is it possible the enlarge the thumbnails of the shortscuts a bit?
- can you make the 'checks' of a seen episode/movie a bit more visible? Maybe green en bigger?
Thanks for this nice skin!
Three questions:
2016-03-28, 11:45
I would appreciate slightly larger home menu icons and shortcut thumbnails - make an option to choose small - medium - large icons ?
