(2024-03-01, 18:52)_BJ1 Wrote: [ -> ]No problems here, nor on LibreElec or CoreElec. Are you using the 21.2.0+omega.x version (last x is 9) or the Nexus Branch?
I went to grab the fresh Beta 3 release and managed to accidentally get and install the most recent Nexus release of Kodi instead. I fixed that and everything's good now. Back to Omega and no issues. Just me being careless.
I've noticed that PVR widgets "last played, all channels" are not being automatically refreshed similar to the original Estuary, progress and current program will only refresh when scrolling through the widgets but not when idle, how can I activate this?
(2024-03-03, 21:02)psbguy Wrote: [ -> ]progress and current program will only refresh when scrolling through the widgets but not when idle, how can I activate this?
You can't.
### 4.2.0+nexus.12 ### 21.2.0+omega.10 ###- visibility of cd art in music osd modified (a never ending story)
- PVR widget update on content changes (info update) implemented @psbguy
(2024-03-10, 12:15)_BJ1 Wrote: [ -> ]### 4.2.0+nexus.12 ### 21.2.0+omega.10 ###- visibility of cd art in music osd modified (a never ending story)
Thank you, works well
Just out of curiousity.... what's changed? I liked it as it was already, and IMHO I don't notice a difference?
[for me the tv-box / mediaplyer is just being used (mainly) as my jukebox]
The CD replacement was visible on radio stations (PVR) even when replacement was set to invisible in skin setup.
Hi there -recently the icon for unwatched items in list view changed to have SD / HD symbol - is it possible to have an option to revert this to the previous design?
Just looking for the previous circle for unwatched items.
Thank you!
Would like to second this request.
The icon for unwatched items was never a circle, that was a simple square. This has replaced by a 8K/4K/HD/SD icon. All other icons (in progress, watched, collection, movie version etc) are not affected by this replacement.
Hi - Ahh I remembered it was something simple before
Any chance we can have the option to toggle it back please as I already have the SD/HD info at the bottom like normal.
Thanks for your consideration and efforts!
I appreciate that and had seen the posts, but that was one user so I did not think it was unfair to ask for the previous icon as an option was all.
But OK - Thanks anyway
I agree with nullafy, the HD/SD icon is not nessesary as it is already in the codec info. So now it’s double in views.
I also prefer the old look.
Thanks in advance.
You guys are driving me crazy.
