Hi
Maybe is just me , I do not know if it was the skin or recently updated Kodi (19.4) , now if I take a quick look of the file , and i mean a few seconds the movie or shows that is in progress , before this it did not happen unless the file was watched for 10-15 seconds
I know this can be modified in
advancedsettings.xml , is there a menu option where this can be modified??
I've don't made modifications that affect the behaviour (changing the view status) that You described above. I think that is related to the update, but I'm not sure. Also there isn't a menu option where you can modify the status.
Regards
Hi mate
I imagined that , checked all over
I guess I will have to change it in the advancedsettings .
hi, stupid question.
I can't figure out how to change the country flags for the audio to coloured ones. I only have the default white ones.
Could someone tell me how to get the coloured icons on the flags for audio and subtitles?
Thanks in advance.
Coloured audio + subtitle flags has been removed from skin.
3.4.0+matrix.8
- Remove detection and use of extrafanart folder, as this isn't used by addons anymore
- Remove fanart section from DialogVideoInfo and DialogMusicInfo
- small changes to skinshortcut template (loading menues up to 100% faster), many thanks to beatmasterRS
- add bookmarks button to simplified video osd
Hi all,
Just discovered mod, impressed so far.
New to this so sorry if stupid question.
Is there a way to automatically open context - information screen when you click on movie?
I use shield, can you exit by back button?
Thanks for great work
And for the widgets on the home screen there is an option in the skin settings "Default action on 'Movie' and 'TV-Show' widgets".
Thanks guys, appreciate help
### 3.4.0+matrix.9 ###
- Player process window in small osd adjusted
- List settings button in DialogVideoInfo removed
- Option for showing artist list in skin settings added
- Fixed issue with missing widget titles
- Albums count from widget templates removed
- Missing language strings (GER) for rating colors added
- Some modifications on holiday themes, Palm Week colors added
How can i change skin color ? It seems that the menu is greyed out and only “Palm Week” color is available…
This is fixed now in version .11
Same problem. I simply want to select "midnight" from skin options but i cannot set anything except the orange theme.
Goto Setup --> Skins --> Extras --> Disable "Activate Themes (Valentine, Easter, Halloween, Christmas)". Make sure you have installed the last version of the skin (3.4.0+matrix.11).
