(2015-02-27, 13:40)DanCooper Wrote: [ -> ] (2015-02-27, 12:40)skaxx Wrote: [ -> ] (2015-02-13, 22:08)Cocotus Wrote: [ -> ]I will check it this weekend and report back.
EDIT:
Found problem! It seems moviepilot changed website a bit, I fixed scraping of plot - tested with 12 years a slave and its scraping the outline. Will commit this to Dan for next Beta later, thanks for reporting!
Thanks, scraping is working fine now for most movies. For some, however, it's still not possible to scrape the outline. Examples are Thor(2011), Star Wars Ep. IV(1977) and Bad Neighbors (2014). They all appear to be relatively long outlines compared to the ones that are scraped without problems. Could it be that this has something to do with it?
Please try this fix: Link
Extract the DLL to .\EmberMediaManager\Modules and overwrite the old file.
Feedback is welcome.
Now works perfectly, thank you!
(2015-02-27, 15:12)SamStoat Wrote: [ -> ]Thanks for updating, but I might have found a problem. When editing movie sets, no movies are showing up when I search for them on the Movies tab.
Confirmed. I forgot to adjust the query to the new database.
Hey Dan,
Awesome looking build, thanks as always!
I have one small(ish) issue though.
Due to my OCD TV file naming preferences, when I scan:
SHOWNAME - S06E08 - EPISODE TITLE [SD.480p.720x404.x264.AAC].mp4
It adds episodes S04E80 & S07E20 to my library.
Is there any way for me to keep my filenames the way I like them?
(2015-02-27, 16:17)zerocool_ie Wrote: [ -> ]Hey Dan,
Move this line 1 step down:
Great job on 1.4.0.8!
One issue I've encountered since upgrading from version 1.4.0.7 to 1.4.0.8 is that I'm unable to add movies to new or existing movie sets.
Symptoms
- Navigate to Sets > [Select Movieset] > Edit Movieset > Movies
- Enter movie and press Search Movie
- The Search Movie button grays-out after pressing and nothing happens. No search results come up. This holds true for existing and new moviesets.
(2015-02-27, 17:53)JavaLawyer Wrote: [ -> ]Great job on 1.4.0.8!
One issue I've encountered is that I'm unable to add movies to new or existing movie sets.
Symptoms
Take a look back, about 3 posts, too this one:
http://forum.kodi.tv/showthread.php?pid=...pid1940735
(2015-02-27, 17:55)FreeMan xbmc Wrote: [ -> ] (2015-02-27, 17:53)JavaLawyer Wrote: [ -> ]Great job on 1.4.0.8!
Symptoms
Take a look back, about 3 posts, too this one: http://forum.kodi.tv/showthread.php?pid=...pid1940735
Ah, thanks! I should read a bit further back before posting.
And I should be better about proof reading posts from my cell phone. Too <> to...
(2015-02-27, 15:37)skaxx Wrote: [ -> ] (2015-02-27, 13:40)DanCooper Wrote: [ -> ] (2015-02-27, 12:40)skaxx Wrote: [ -> ]Thanks, scraping is working fine now for most movies. For some, however, it's still not possible to scrape the outline. Examples are Thor(2011), Star Wars Ep. IV(1977) and Bad Neighbors (2014). They all appear to be relatively long outlines compared to the ones that are scraped without problems. Could it be that this has something to do with it?
Thanks Dan, glad that it seems to work now
Woaaaaaaa!!
Thanks, thanks, thanks, to everyone involved.
Freaking fast, freaking complete!!
Brilliant work.
Dan you rock!!!!!
Let's now merge the changes and start to work on 1.5
I have a lot of stuff pending...
Hi Dan thanks for the release I'm looking forward to trying it out
I'm moving from 1.4.0.6, should i still
change the banner filenames to make sure the old ones are picked up?
Hi Dan,
2 questions for the TV Show rename options :
- Is there a variable for the episode airdate? That's my most important one for TV Shows not scraped from TVDB/TMDB
- Can i remove the leading 0 for Seasons? I prefer Show - 1x01 - Title rather than Show - 01x01 - Title
Since installing 1.4.0.8, the bulk renamer isn't working for me. Known issue?
