New release 1.4.0.1 (2014-10-17) is online
Please, read my f****** hints in download thread (at least this time)
Changelog 1.4.0.1 Beta (2014-10-17)
[Main]
added: MovieSet title renamer (auto rename titles like "Hangover Reihe" to "Hangover Collection")
added: missing icons for sd video sources
added: more video sources
added: clean MovieSet DB on update
added: delete images with MovieSets
added: filters for MovieSets
added: filters for TV Shows (beta)
added: search bar for MovieSets
added: search bar for TV Shows
added: exclude directories (you can add directories who will be completely ignored by Ember)
added: search bar in Edit MovieSet dialog
added: key sensitive movie list in Edit MovieSet dialog
added: setting to set the release date in US format (yyyy-mm-dd)
added: more settings for MovieSets
added: missing locks
added: scrape global episode runtime for tv shows from TVDB
added: runtime in tv show and episode NFO
added: use Show Runtime for Episodes if no Episode Runtime can be found
added: a Movie source can set as "exclude from DB update" like in XBMC
added: filter "Country" to Movie filters
added: [none] to genre filter to find movies/tv shows without genre
added: ListTile and sort tokens for tv shows
added: "Cleanup disabled fields" for movie scraper
added: HD-Trailers.net and Davestrailerpage.com as additional trailer scrapers
added: "* All Seasons" to season list
added: "Display Image Names" for main window (like "ClearArt", "Landscape")
added: XBMC <StereoMode> tag in NFO
added: full MKV 3D support
added: better external subtitles support (in movie folder and "subs" subfolder)
added: "Original Title" as separate data scraper option
added: MovieSet images renaming if movieset title has changed
fixed: missing items scraping ("All Items" isn't available at the moment)
fixed: MovieSet info panel height
fixed: Ember wants restart while DB update after cloding settings dialog
fixed: rating stars color for disabled stars
fixed: MPAA/Certification handling
fixed: Settings dialog is not sizable
fixed: "Remove MovieSet images with MovieSet" to cleanup images from deleted MovieSets
fixed: theme scraper in Edit Movie dialog
fixed: delete existing trailers/themes
fixed: some issues in main menu
fixed: extrathumbs, extrafanarts and actorthumbs handling in Edit Movie dialog
fixed: all missing/wrong "Expert Settings" for movie
changed: Movie data scraper handling (now the first scraper in settings has the highest priority)
changed: list sorting in movie list or filter will be saved and restored while DB-update, changed settings or Ember restart
changed: Country and Studio are now saved in multiple NFO tags for each entry
changed: trailer preview buttons logic in Edit Movie dialog
changed: trailer logic
removed: old MovieSets manager
removed: Czech language (broken)
[Renamer]
added: MovieSet name tag
fixed: bugs with special characters
fixed: many other bugs
[TMDB]
fixed: MovieSet scraper get random images if no TMDBCOlID is available
changed: API logic (now it's possible to change settings without restart)
[Fanart.tv]
added: private API key handling
[IMDB]
fixed: wrong runtime scraping
fixed: wrong votes scraping
[GoEar]
fixed: theme scraping
