(2015-03-16, 19:19)joshua99 Wrote: [ -> ] (2015-03-16, 18:31)Grand Total Wrote: [ -> ] (2015-03-16, 16:13)joshua99 Wrote: [ -> ]Which pins did you short?
@ xbmcdoc, AuXBoX showed me on a photo I sent him, it was the 2 centre pins on the outer side of the box.
Cheers. Josh.
Would you mind posting the photo, in case it helps someone else?
Hi, I would not mind at all if I could but I can't find anyway to upload photos.
Ironically it would now help me.
I now have a box which shows a red light initially, it changes to green after about 60 seconds and I get video out, but that's as far as it gets.
(2015-03-17, 05:03)Grand Total Wrote: [ -> ] (2015-03-16, 19:19)joshua99 Wrote: [ -> ] (2015-03-16, 18:31)Grand Total Wrote: [ -> ]Would you mind posting the photo, in case it helps someone else?
Ironically it would now help me. I now have a box which shows a red light initially, it changes to green after about 60 seconds and I get video out, but that's as far as it gets.
hey im pretty sure this is the only set of pins that you need to short
(2015-03-17, 05:54)kashmoney Wrote: [ -> ] (2015-03-17, 05:03)Grand Total Wrote: [ -> ] (2015-03-16, 19:19)joshua99 Wrote: [ -> ]Hi, I would not mind at all if I could but I can't find anyway to upload photos.
this is my photo. The board on joshs is different
the chip is still the same though on both the 1200 and the 520(e) just gotta find it on the board near the SOC which is fairly easy
(2015-03-12, 22:54)xbmcdoc Wrote: [ -> ] (2015-03-11, 17:47)p_turner_uk Wrote: [ -> ]Hi AuXBoX
The post where you mentioned the AmLogic AML8726-MX was the most stable device you have used for Linux-MX was of particular interest to me. The only issue I have with the ATV1200 now is that as you know it likes to freeze from time to time. I seem to have less problems with it freezing as long as the RSS feed is turned on (which I assume in this instance acts like a screensaver in some ways keeping the screen active).
Now I would buy a AML8726-MX but I believe it doesn't have a coaxial out (only S/PDIF optical).
I like to connect to my surround system via coaxial, and I wondered in your opinion what box out there is the most stable solution for Linux/Kodi with the coaxial option, I'm guessing at the moment it is the ATV1200? I would really value hearing what you might think on the matter.
Cheers
Pete
The ATV520(e) does not have coaxial nor S/DIF. Also, the ATV520(e) and ATV1200 have the same chips (AML8726-MX). See if your TV has a Coax out, you can connect the HDMI to the TV and then tv coxial to the receiver. They do sell SPDIF Coaxial converters.
Well I use the ATV1200 with both my tv and projector. As a result I wanted the audio from the ATV to the surround system direct.
(2015-03-13, 00:52)AuXBoX Wrote: [ -> ] (2015-03-11, 17:47)p_turner_uk Wrote: [ -> ]Hi AuXBoX
Cheers
Pete
Does your amp not have s/pdif?
If you need coaxial you will need to stay wih 1200
Yes the amp does have s/pdif but it's taken up with another device (youview box, which does not have coaxial to swap with).
So at the moment I do need the coaxial out, so I will stick with the 1200.... the occational freeze is only a minor annoyance! Overall I am very happy with what they allow me to do for the price.
Thanks for getting back to me
Auxbox I have got that dual core CMX box now as recommended so would appreciate if you can send me the link for the Linux Helix 14.0 compile for it so I can test it out. Many thanks in advance mate.
(2015-03-17, 06:08)kashmoney Wrote: [ -> ]the chip is still the same though on both the 1200 and the 520(e) just gotta find it on the board near the SOC which is fairly easy
Thanks kashmoney and AuXBoX for the pictures. I don't think my box is like either of those, but the pictures should help me find the right chip.
(2015-03-17, 16:15)Grand Total Wrote: [ -> ] (2015-03-17, 06:08)kashmoney Wrote: [ -> ]the chip is still the same though on both the 1200 and the 520(e) just gotta find it on the board near the SOC which is fairly easy
Can you upload a pic to dropbox and post a link? Always good to save it for future reference for others.
(2015-03-17, 06:02)AuXBoX Wrote: [ -> ][this is my photo. The board on joshs is different
I have two boxes, both bricked, and I tried this method on one of them. It worked, but only partially in the sense that I didn't end up with a box running Android 4.1 as I expected. Instead it recovered and was running the (custom) software that was running on it before I bricked it. This evening I shall try to reflash it with the firmware I want on it. If that goes well I'll try to recover the box I bricked the day before yesterday.
(2015-03-18, 13:43)AuXBoX Wrote: [ -> ] (2015-03-18, 07:15)xbmcdoc Wrote: [ -> ] (2015-03-17, 16:15)Grand Total Wrote: [ -> ]Thanks kashmoney and AuXBoX for the pictures. I don't think my box is like either of those, but the pictures should help me find the right chip.
Pins to short
1200
https://mega.co.nz/#!WpQQDaRA!NWWRaG7AeA...KaU5VRnl0k
520
https://mega.co.nz/#!n55CRBQa!0WBRxLUSyG...UgflEpnUOc
Thank you AuXBoX. I want looking for pictures of Grand Total box as he mentioned it was different. But your are good reference.
(2015-03-18, 15:08)Grand Total Wrote: [ -> ] (2015-03-17, 06:02)AuXBoX Wrote: [ -> ][this is my photo. The board on joshs is different
Sounds like the box went back to factory reset. Try the reflash again to see if it sticks. You probably don't need to short the pins this time.
