Thanks for confirming.
I'm also having a HDMI handshake issue when changing input on my AVR to the Chromebox (running Ubuntu 14.10 + Kodi set to autostart) - I get blank screen which occasionally shows a fuzzy white image and I can sometimes hear crackling noises. I've had similar problems with Windows based machines connected to my AVR.
I know it's not the best, but I can suspend the Chromebox and then wake which forces the HDMI handshake again, which always works, not exactly slick though. The other problem with doing this is that a cursor sometimes appears in the middle of the screen (not the Kodi cursor) which is extremely irritating.
So, does anyone have any tips for fixing either the HDMI handshake issue OR removing the cursor on resume/wake?
Hello everyone, I've just bought an Asus Chromebox (M031U) and stuck OpenELEC 5.0.1 on it. I'm getting a load of skipped frames intermittently. I might start a movie and it'll skip maybe every 5 frames (the skipped frame counter increased a few times a sec) however after a few jumps forward or back I can get rid of the problem and able to play the same part of the movie fine that was skipping.
I have been using XBMC since the Xbox 180 days and have 3x PCs running it around my house and they can all handle the same file fine so I don't think the source is to blame. It does it on 720p MKVs and 1080p BD-raw rips that I've made myself.
I stream over NFS from my server so thought this might be an issue but it was doing this last night on a local USB drive.
http://xbmclogs.com/show.php?id=420262
my debug log above. Playing back of Star Trek commences around 00:32:14 and stops around 00:39:00.
Having only just got the box on Saturday I've not changed many settings. I disabled VDPAU since it doesn't have an nVidia chipset, I'm using VAAPI and disabled the VC-1 handling (I think this is the default). I run through an AV amp at 1080p native (in case it matters) and have enabled the option for changing the display to match the video refresh rate (or whatever the exact name is).
The only add-on's I've installed are the watchdog and I've enabled the MythTV PVR add-on. I've not noticed it skip with myth content playback but I've only tried a couple of TV shows to check it works.
It's not a major issue for me as I have plenty of other PCs to run Kodi, I really got the Chromebox just to play around with and see what it can do/does so if it's a known bug I'm happy to wait it out or if you want me to do anything to test I'm happy to try and help.
(2015-02-09, 13:09)bhampton Wrote: [ -> ]That "was" the proper fix and it's supposed to correct a bug that has been removed from OpenElec 5.0.
Of course,... I guess if you are running Kodi off a full Ubuntu install that's a different config. either way turning off prefer Vaapi Render is known to fix that problem.
And,... if you do the "Broadcast RGB" "Full" tweak to get the right video output then the Prefer Vaapi Rendered is supposed to be off also....
Selecting software decoding fixed the problem, but that is probably not the best solution. I'll try changing the render method tonight.
Hi everyone , have a few questions with which I need help. I am running an asus chromebox moo4u using standalone setup with open elec to run xbmc via wifi (wifi router netgear n300) and I am encountering a lot of buffering when I play movies , about every 30 seconds movie buffers. The fixes I have tried are fresh start and advanced setting zero caching. My question is this , would this be a router issue as we do use router for several different things in home and this may not be the best router or have I missed some settings that I need to set to help with buffering. I also notice that I have to go through a lot of links to find one that will work. I hope I have given enough info to receive help but I do have limited knowledge and I am in the process of learning as I enjoy as hobby , so if someone could please help with these issues I would greatly appreciate it Thank you
I've been watching using only software decoding on my Chromebox with OpenElec.
Most everything plays back lovely.
I kept the debug log enabled so I could see the FPS and CPU use and most every video I have did fine.
My blu ray MKV from "The Dark Knight" was choppy and often pegged one or the other CPU core at 100% so for that video I will enable acceleration unless I just re-encode it and dumb down the bit rate some.
Subjectively... I think it looks better and smoother using software rendering. That could be my imagination but I always welcome perceived improvements regardless of if it's imaginary.
-Brian
(2015-02-09, 14:43)pharcycle Wrote: [ -> ]Hello everyone, I've just bought an Asus Chromebox (M301U) and stuck OpenELEC 5.0.1 on it. I'm getting a load of skipped frames intermittently. I might start a movie and it'll skip maybe every 5 frames (the skipped frame counter increased a few times a sec) however after a few jumps forward or back I can get rid of the problem and able to play the same part of the movie fine that was skipping.
I have the same issue and posted my log a few pages back.
http://pastebin.com/R97uXCfT
Issue persists whether the file is local or on NFS
there's quite a few fixes in OE 5.0.2 that may help, update and see if the problems persist
(2015-02-09, 23:27)Matt Devo Wrote: [ -> ]there's quite a few fixes in OE 5.0.2 that may help, update and see if the problems persist
sweet! updating now
unfortunately frames are still skipping
Has anyone got boblight working with openelec on a chromebox? I had it working on Kodi for windows, but in openelec I have installed the plugin and daemon, and I cant get the lights to come on using my previous config from windows. I have updated the device to the correct /dev/amc0 entry, but it doesn't light up.
If I use the sample config I get the lights, but its only setup for 25 lights not the 50 I have so it doesn't work properly. I can change the number of lights from 75 to 150 and the prefix to what I had in my windows config and it still works but when I copy over my light config to go from the 25 defined to the 50 I have, boblight then doesnt start properly and I just get 'failed to connect to boblightd'.
This is the config that I want to get working:
[light]
name 50
color red ambilight 148
color green ambilight 149
color blue ambilight 150
hscan 0 4.17
vscan 92.86 100
[light]
name 49
color red ambilight 145
color green ambilight 146
color blue ambilight 147
hscan 0 4.17
vscan 85.71 92.86
[light]
name 48
color red ambilight 142
color green ambilight 143
color blue ambilight 144
hscan 0 4.17
vscan 78.57 85.71
[light]
name 47
color red ambilight 139
color green ambilight 140
color blue ambilight 141
hscan 0 4.17
vscan 71.43 78.57
[light]
name 46
color red ambilight 136
color green ambilight 137
color blue ambilight 138
hscan 0 4.17
vscan 64.29 71.43
[light]
name 45
color red ambilight 133
color green ambilight 134
color blue ambilight 135
hscan 0 4.17
vscan 57.14 64.29
[light]
name 44
color red ambilight 130
color green ambilight 131
color blue ambilight 132
hscan 0 4.17
vscan 50 57.14
[light]
name 43
color red ambilight 127
color green ambilight 128
color blue ambilight 129
hscan 0 4.17
vscan 42.86 50
[light]
name 42
color red ambilight 124
color green ambilight 125
color blue ambilight 126
hscan 0 4.17
vscan 35.72 42.86
[light]
name 41
color red ambilight 121
color green ambilight 122
color blue ambilight 123
hscan 0 4.17
vscan 28.57 35.72
[light]
name 40
color red ambilight 118
color green ambilight 119
color blue ambilight 120
hscan 0 4.17
vscan 21.43 28.57
[light]
name 39
color red ambilight 115
color green ambilight 116
color blue ambilight 117
hscan 0 4.17
vscan 14.29 21.43
[light]
name 38
color red ambilight 112
color green ambilight 113
color blue ambilight 114
hscan 0 4.17
vscan 7.15 14.29
[light]
name 37
color red ambilight 109
color green ambilight 110
color blue ambilight 111
hscan 0 4.17
vscan 0 7.14
[light]
name 36
color red ambilight 106
color green ambilight 107
color blue ambilight 108
hscan 4.17 8.33
vscan 0 7.14
[light]
name 35
color red ambilight 103
color green ambilight 104
color blue ambilight 105
hscan 8.33 12.5
vscan 0 7.14
[light]
name 34
color red ambilight 100
color green ambilight 101
color blue ambilight 102
hscan 12.5 16.67
vscan 0 7.14
[light]
name 33
color red ambilight 97
color green ambilight 98
color blue ambilight 99
hscan 16.67 20.83
vscan 0 7.14
[light]
name 32
color red ambilight 94
color green ambilight 95
color blue ambilight 96
hscan 20.83 25
vscan 0 7.14
[light]
name 31
color red ambilight 91
color green ambilight 92
color blue ambilight 93
hscan 25 29.17
vscan 0 7.14
[light]
name 30
color red ambilight 88
color green ambilight 89
color blue ambilight 90
hscan 29.17 33.33
vscan 0 7.14
[light]
name 29
color red ambilight 85
color green ambilight 86
color blue ambilight 87
hscan 33.33 37.5
vscan 0 7.14
[light]
name 28
color red ambilight 82
color green ambilight 83
color blue ambilight 84
hscan 37.5 41.67
vscan 0 7.14
[light]
name 27
color red ambilight 79
color green ambilight 80
color blue ambilight 81
hscan 41.67 45.83
vscan 0 7.14
[light]
name 26
color red ambilight 76
color green ambilight 77
color blue ambilight 78
hscan 45.83 50
vscan 0 7.14
[light]
name 25
color red ambilight 73
color green ambilight 74
color blue ambilight 75
hscan 50 54.17
vscan 0 7.14
[light]
name 24
color red ambilight 70
color green ambilight 71
color blue ambilight 72
hscan 54.17 58.33
vscan 0 7.14
[light]
name 23
color red ambilight 67
color green ambilight 68
color blue ambilight 69
hscan 58.33 62.5
vscan 0 7.14
[light]
name 22
color red ambilight 64
color green ambilight 65
color blue ambilight 66
hscan 62.5 66.67
vscan 0 7.14
[light]
name 21
color red ambilight 61
color green ambilight 62
color blue ambilight 63
hscan 66.67 70.83
vscan 0 7.14
[light]
name 20
color red ambilight 58
color green ambilight 59
color blue ambilight 60
hscan 70.83 75
vscan 0 7.14
[light]
name 19
color red ambilight 55
color green ambilight 56
color blue ambilight 57
hscan 75 79.17
vscan 0 7.14
[light]
name 18
color red ambilight 52
color green ambilight 53
color blue ambilight 54
hscan 79.17 83.33
vscan 0 7.14
[light]
name 17
color red ambilight 49
color green ambilight 50
color blue ambilight 51
hscan 83.33 87.5
vscan 0 7.14
[light]
name 16
color red ambilight 46
color green ambilight 47
color blue ambilight 48
hscan 87.5 91.67
vscan 0 7.14
[light]
name 15
color red ambilight 43
color green ambilight 44
color blue ambilight 45
hscan 91.67 95.83
vscan 0 7.14
[light]
name 14
color red ambilight 40
color green ambilight 41
color blue ambilight 42
hscan 95.83 100
vscan 0 7.14
[light]
name 13
color red ambilight 37
color green ambilight 38
color blue ambilight 39
hscan 95.83 100
vscan 7.14 14.29
[light]
name 12
color red ambilight 34
color green ambilight 35
color blue ambilight 36
hscan 95.83 100
vscan 14.29 21.43
[light]
name 11
color red ambilight 31
color green ambilight 32
color blue ambilight 33
hscan 95.83 100
vscan 21.43 28.57
[light]
name 10
color red ambilight 28
color green ambilight 29
color blue ambilight 30
hscan 95.83 100
vscan 28.57 35.71
[light]
name 9
color red ambilight 25
color green ambilight 26
color blue ambilight 27
hscan 95.83 100
vscan 35.71 42.86
[light]
name 8
color red ambilight 22
color green ambilight 23
color blue ambilight 24
hscan 95.83 100
vscan 42.86 50
[light]
name 7
color red ambilight 19
color green ambilight 20
color blue ambilight 21
hscan 95.83 100
vscan 50 57.14
[light]
name 6
color red ambilight 16
color green ambilight 17
color blue ambilight 18
hscan 95.83 100
vscan 57.14 64.28
[light]
name 5
hscan 95.83 100
vscan 64.28 71.43
[light]
name 4
hscan 95.83 100
vscan 71.43 78.57
[light]
name 3
hscan 95.83 100
vscan 78.57 85.71
[light]
name 2
hscan 95.83 100
vscan 85.71 92.85
[light]
name 1
hscan 95.83 100
vscan 92.85 100
Thanks for any help!
bob
(2015-02-09, 23:31)bob808 Wrote: [ -> ]Has anyone got boblight working with openelec on a chromebox? I had it working on Kodi for windows, but in openelec I have installed the plugin and copied over my boblight.conf from my working windows setup but get no lights. Also there are no config options in the plugin on openelec?
I am not sure if the actual boblight daemon is installed and running - on windows I needed to setup boblight as a program and run it before kodi would interface with it, so assume its the same. I tried downloading the source code to compile but get an error just running the configure part, so not sure if I can get this to work.
I have an arduino uno flashed already, so I just need to see if I can get this working on openelec via the usb in the chromebox.
bob
this has nothing to do with the ChromeBox hardware or the setup script; it's an OpenELEC / boblight plugin issue. Please start a new thread in the appropriate forum/section.
Hi Matt, I read in this thread that you have tried to increase the memory allocated to the GPU but have not had success. Did you test with various amounts of system RAM or just on a box with 2GB RAM?
Do you know if it works like some computers (Mac Mini's I think), where more GPU RAM is automatically allocated if you increase the total RAM in the system. Others allow increasing the max GPU RAM in the bios depending on the amount of system RAM.
When I check my M004u with 2GB RAM, there is 256MB allocated to the GPU. It would be interesting to see how much is allocated if there was 4GB or 8GB RAM.
Ben
Hi, like morbidz said, the issue is still present for me with 5.0.2 and streaming either from attached USB disk or over NFS.
http://xbmclogs.com/show.php?id=421252
Another log from my box, clean boot, started my BD rip with dropped frames, paused and resumed 3-4 times and it played fine. Skipped forward 30s and it skips frames, again 3-4 pause/resumes fixes the issue.
Is there a set of recommended playback settings for these boxes, it's quite possible I've set something sub-optimally as I'm used to running Kodi on full PCs with nvidia cards.
Thanks and keep up the good work!
(2015-02-10, 00:03)BenH Wrote: [ -> ]When I check my M004u with 2GB RAM, there is 256MB allocated to the GPU. It would be interesting to see how much is allocated if there was 4GB or 8GB RAM.
I've got a 4GB HP Chromebox and it also only has 256MB allocated to the GPU.
chromebox:~ # free -m
total used free shared buffers
Mem: 3891 700 3190 231 42
-/+ buffers: 657 3233
Swap: 0 0 0
chromebox:~ # lspci -v -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
Subsystem: Google, Inc. Haswell-ULT Integrated Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at e0000000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: i915
(2015-02-10, 00:19)ant_thomas Wrote: [ -> ]I've got a 4GB HP Chromebox and it also only has 256MB allocated to the GPU.
OK, thanks. I suppose that answers the question about it automatically allocating.
Ben
(2015-02-10, 00:03)BenH Wrote: [ -> ]Hi Matt, I read in this thread that you have tried to increase the memory allocated to the GPU but have not had success. Did you test with various amounts of system RAM or just on a box with 2GB RAM?
Ben
it's fixed to 256MB regardless of system RAM. I'll test something else now to see if I can bump to 512MB. stay tuned
