(2015-07-17, 19:16)calcio1 Wrote: [ -> ]I just bought a 55inch samsung UHD 4k smart tv
It refused to recognise my chromebox
When I connect chromebox to my old tv (32 in non smart), then connect the HDMI to the new TV, it works.
But if I turn off the chromebox, it doesn't recognise it again.
How can I fix this, please help me before I go apeshit on my new tv
I suspect it's the same issue I ran into with a 4K visio set, where it advertises accepting 1080p 120Hz input but actually doesn't. You can test this by booting on the new TV, then connecting via ssh and checking the output resolution / refresh rate via xrandr --props, and then manually set it to 1080p60 (via xrandr, not sure of exact command) if it's not already. Might be worth popping on IRC to get some help there
Hi Matt,
First time Dell Celeron ChromeBox owner
So far so good....thanks for your work.
(2015-07-17, 21:12)Matt Devo Wrote: [ -> ] (2015-07-17, 19:16)calcio1 Wrote: [ -> ]I just bought a 55inch samsung UHD 4k smart tv
Matt do you mean ssh into tv or chromebox?
EDIT I can't seem to ssh into TV and I don't know the user name / password for openelec
(2015-06-26, 10:09)joeilly Wrote: [ -> ]I must have done something wrong following the instructions of the OP. I was attempting to do a standalone openelec install. After creating the recovery usb, I couldn't get past the boot screen "Booting from hard disk...". Can't get Ctrl-D to work. Ditto for hitting Esc. Tried entering recovery, but get stuck in the same spot. I created a recovery usb using the Google utility, but there's no way to get the Chromebox to look at the USB. It only hangs on the same screen "Booting from hard disk..."
Any suggestions?
Many thanks!
Did you ever find a solution? I'm having the same issue. Thanks.
(2015-07-18, 03:19)visiter555 Wrote: [ -> ]Hi Matt,
(2015-07-18, 03:40)calcio1 Wrote: [ -> ]Matt do you mean ssh into tv or chromebox?
root/openelec. It's on their wiki
(2015-07-18, 05:18)PunchDown Wrote: [ -> ]Did you ever find a solution? I'm having the same issue. Thanks.
It's either an issue with your keyboard or USB stick (as per the wiki). Pressing anything other than ESC as directed is sure to bollocks things up. The recovery button and CTRL-D/L have no function once you've flashed my custom firmware.
Matt this is the output from xrandr (with kodi viewable on my tv). How should i get it to default to 1080px60?
also, does this mean i can't view 4k content from chromebox?
thanks
# xrandr --props
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
EDID:
00ffffffffffff004c2d000c01000001
2a180103807944780a23ada4544d9926
0f474abdef80714f81c0810081809500
a9c0b300010104740030f2705a80b058
8a00501d7400001e023a801871382d40
582c4500501d7400001e000000fc0053
414d53554e470a2020202020000000fd
00184b0f511e000a2020202020200110
020340f153df101f041305142021225d
5e62636407160312290907071507503d
07c08301000076030c002100801e21d0
880102030401400fff50608090e2000f
011d80d0721c1620102c2580501d7400
009e662156aa51001e30468f3300501d
7400001e000000000000000000000000
00000000000000000000000000000006
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
3840x2160 30.00 + 25.00 24.00 29.97 23.98
4096x2160 24.00 23.98
1920x1080 60.00* 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1600x900 59.98
1280x1024 75.02 60.02
1440x900 59.90
1366x768 59.79
1280x800 59.91
1152x864 75.00
1280x720 59.97 60.00 50.00 59.94
1440x576i 50.00
1024x768 75.08 70.07 60.00
1440x480i 60.00 59.94
832x624 74.55
800x600 72.19 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DP1 disconnected (normal left inverted right x axis y axis)
audio: auto
HDMI2 disconnected (normal left inverted right x axis y axis)
audio: auto
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
(2015-07-19, 13:57)calcio1 Wrote: [ -> ]Matt this is the output from xrandr (with kodi viewable on my tv). How should i get it to default to 1080px60?
thanks
so, the output of xrandr is telling us that 3840x2160p30 is the default resolution (indicated by the +), which apparently your TV doesn't like (at least on that particular input - some 4K TVs are picky about that). 4K 30Hz output is pretty crappy for the GUI, so outputting 1080p60 is actually better unless you have h264 4K content you want to play.
To set the output to 1080p60 on startup,
create an autostart.sh script containing the following:
xrandr --output HDMI1 --mode 1920x1080
Did anyone tried the Chromebox DiplayPort 1.2 output to HDMI 2.0 TV input ?
As it's the only way to have 2160p60.
(2015-07-20, 01:28)desperado77 Wrote: [ -> ]Hi,
There's no adapter from DisplayPort 1.2 to HDMI 2.0 which utilizes MST (multi-stream transport, which effectively uses 2 displays as one), so there's no way to get 2160p60 out of the Chromebox via HDMI, period
Hi Matt,
Are all the videos up-scaled to the resolution that is indicated by the '+' in xrandr (native resolution)?
(2015-07-20, 01:31)desperado77 Wrote: [ -> ]Hi Matt,
They are scaled to the selected output resolution, up or down. The native resolution of the display doesn't factor in at all
Is there a way to limit the GUI to 1080p60 and use the 2160p output resolution for videos ? like in raspberry pi
Bizlink announced DP 1.2 to HDMI 2.0 Adapter, but no retailer have this now.
im dual booted with your script i tried the beta 5.95.3 dual boot how do i roll back to 5.08 thanks
(2015-07-20, 05:32)leo5111 Wrote: [ -> ]im dual booted with your script i tried the beta 5.95.3 dual boot how do i roll back to 5.08 thanks
Easiest way is to re-run the script (only have to do it once) and select the stable version instead
