2021-11-27, 17:25
(2021-11-27, 03:01)Lirunaway Wrote: [ -> ]Do you plan to update the script for LibreElec 10.1 & Kodi 19.3? I had my Chromebox working and dual boot. I updated LibreElec to 10.1 within Kodi. Then found I would have to reload Kodi in order to update Kodi for a usable build. I managed to bring up your script. However, I had to add -k to get the script to work or so I thought. Upon rebooting the device the device failed. Maybe because it's loading an older LibreElec version onto a newer version LibreElec. I tried all day and finally I got it by doing a stand alone installation. However, the Kodi version is 18.7 again and lost dual boot. Thinking when it's available I'll have to make a USB on a Linux laptop I'm guessing in terminal.
I just did - simply create fresh install media (using my script or the official LE media creation tool) and do a clean install of 10.0.1. Standalone is the way to go on these devices, they are far EOL for ChromeOS. If you want to dual boot ChromeOS, I'd recommend doing so from external media via the Brunch project. Requires the box have my latest coreboot+UEFI firmware flashed.
