(2016-05-01, 15:43)Matt Devo Wrote: [ -> ] (2016-05-01, 15:31)HarryMohan Wrote: [ -> ]I cant tell, it's new install, its trying to run your script from hard drive, and its stuck there,
On screen I see " SeaBios (version rel-1.9.8-126-g7d4d62-20160418-MattDevo)
Booting from Hard Drive.....
After that nothing happens.
ok, so if you can see that, what's the problem with booting the USB installer?
Sorry for asking silly questions, USB installer means just download LibreElect on USB and run it?
(2016-05-01, 16:05)HarryMohan Wrote: [ -> ]Sorry for asking silly questions, USB installer means just download LibreElect on USB and run it?
No, if you didn't use the script to create the install media, then you need to do it manually like every other PC user
Instructions/links are on the Chromebox wiki page
USB intaller means that you download your OS of choice and burn it to the USB thumb drive using software like Rufus or Win32DiskImager,etc. in order to boot from it and proceed to install the Operative System (OS).
Depending of the OS (LibreElec/GalliumOS) you can also use Matt's script to download and create the USB installer easily and straight forward.
(2016-05-01, 16:23)Veronica Wrote: [ -> ]USB intaller means that you download your OS of choice and burn it to the USB thumb drive using software like Rufus or Win32DiskImager,etc. in order to boot from it and proceed to install the Operative System (OS).
I created USB installer with Matt's Script, Tried to verify Legacy boot functionality CTRL-L "nothing" tried ESC "nothing"
Still stuck on screen with Booting from Had Disk, seems it doesn't want to boot from USB, I have used same USB stick & Keyboard in past
(2016-05-01, 16:56)HarryMohan Wrote: [ -> ]I created USB installer with Matt's Script, Tried to verify Legacy boot functionality CTRL-L "nothing" tried ESC "nothing"
Try creating the install media manually as per the wiki, using a different USB stick. Also, you don't use CTRL-L for a standalone install, just ESC when prompted
(2016-05-01, 16:22)Matt Devo Wrote: [ -> ] (2016-05-01, 16:05)HarryMohan Wrote: [ -> ]Sorry for asking silly questions, USB installer means just download LibreElect on USB and run it?
No, if you didn't use the script to create the install media, then you need to do it manually like every other PC user Instructions/links are on the Chromebox wiki page
BTW, I did create script to install media as per "wiki" only thing I did by error was install headless version
Matt, new USB worked. Thank you, sir.
Matt,
have you ever gotten a chance to look at the dual ouput hdmi/displayport bug that came about in Jarvis builds? i know after i posted some threads you said you may test it when you got a chance
thanks
(2016-05-01, 19:37)knives of ice Wrote: [ -> ]Matt,
thanks
I have not, it fell off my to do list. I'll try and take a look next week sometime
Hello
I am having trouble with the easy script.
I get an error handshake failure.
I verified I have a network connection wired.
Any idea what a may be doing wrong?
This is my second chromebox the first time a few months back went like clock work.
This is a hp: CB1-014
thanks
(2016-05-02, 15:27)mxlance Wrote: [ -> ]I get an error handshake failure.
please post the full/exact error msg. Just verified there's no issue with the script or server.
(35) error:14077410:SSL routines:SSL2.3_GET_SERVER_HELLO
slu3 alert handshake failure.
this is a little hard to read so i hope i got it correct.
thank you matt
(2016-05-02, 16:05)mxlance Wrote: [ -> ](35) error:14077410:SSL routines:SSL2.3_GET_SERVER_HELLOslu3 alert handshake failure.
thank you matt
And the error occurs when exactly? When downloading the script, or running it?
I don't know why you'd get a SSL error on a non-https connection offhand
