(2014-09-30, 10:17)DanCooper Wrote: [ -> ] (2014-09-30, 09:02)peregrine Wrote: [ -> ]For some reason EMM won't do anything; it doesn't generate nfos, doesn't download images (although the dialog works fine). What gives?
Please Upload your Settings.xml and AdvancedSeetings.xml.
I can confirm the same behaviour; scrape works via the Scrape Movies button, but choosing (Re)Scrape Movies from the context menu does not work.
AdvancedSettings.xml
Settings.xml
(2014-09-22, 09:38)Cocotus Wrote: [ -> ]Going to check this, thx! BTW, I just noticed that Apple Trailer download within Ember seems not to work. Trying to fix this right now...
EDIT: Just changed the studio-tag structure in nfo. Now if there are more than one studios scraped, they will be saved in multiple studio-tags like genre and director.
Dan ! Thanks for HD trailers Integration. did you get a chance to integrate the work done by cocotus regarding the multiple studios being scraped together . Awaiting update on git !
(2014-09-30, 10:56)peregrine Wrote: [ -> ]Apparently it works if I scrape my movies via the Scrape Movies button. However, if I choose (Re)Scrape Movies from the context menu, it does not function.
Settings.xml: https://www.dropbox.com/s/8qf34hfl1rf62z...s.xml?dl=0
AdvancedSettings.xml: https://www.dropbox.com/s/jc8oxeenp3aizc...s.xml?dl=0
(2014-09-30, 12:24)HotBlack Wrote: [ -> ] (2014-09-30, 10:17)DanCooper Wrote: [ -> ] (2014-09-30, 09:02)peregrine Wrote: [ -> ]For some reason EMM won't do anything; it doesn't generate nfos, doesn't download images (although the dialog works fine). What gives?
Settings.xml
Very strange. For me it works without problems, even with your settings.
(2014-10-02, 12:40)shaktoo Wrote: [ -> ] (2014-09-22, 09:38)Cocotus Wrote: [ -> ]Going to check this, thx! BTW, I just noticed that Apple Trailer download within Ember seems not to work. Trying to fix this right now...
The HD-Trailers.net scraper comes from Cocotus:-)
We are in the process to improve search results.
But there are all of the changes (including studio & director fix) available on GitHub. You just have to compile the code.
(2014-10-02, 13:46)DanCooper Wrote: [ -> ] (2014-09-30, 10:56)peregrine Wrote: [ -> ]Apparently it works if I scrape my movies via the Scrape Movies button. However, if I choose (Re)Scrape Movies from the context menu, it does not function.
(2014-09-30, 12:24)HotBlack Wrote: [ -> ] (2014-09-30, 10:17)DanCooper Wrote: [ -> ]Please Upload your Settings.xml and AdvancedSeetings.xml.
Settings.xml
Hmmm. Curious. What's your Windows and .NET Framework version? And did you run EMM as administrator? Also the Edit Movie dialog is not showing up.
(2014-10-02, 15:37)peregrine Wrote: [ -> ]Hmmm. Curious. What's your Windows and .NET Framework version? And did you run EMM as administrator? Also the Edit Movie dialog is not showing up.
Ahhh.... do you have read the big, bold and red written text in the
download thread
EDIT: I still have a few arrows added so you see it better ....
My settings are still the same.... oh you mean VLC? Hahaha. Will try now
(2014-10-02, 15:42)peregrine Wrote: [ -> ]My settings are still the same.... oh you mean VLC? Hahaha. Will try now
Yes, VLC with ActiveX plugin
Man, years of using MPC-HC makes me neglect VLC. Works perfectly! Thanks!
i'm am still missing the download trailer in the movie folder...simply doesnt work!...
see a few posts mine before, please!.
I don't know the reason for Not downloading videos-trailers from youtube...i think all my options are correct.
some screens:
[url=https://drive.google.com/open?id=0B2vZ6lUhEr87M1lqaFRGYm1vUHc&authuser=0]1[/url]
[url=https://drive.google.com/open?id=0B2vZ6lUhEr87OGJ3MmFvQTVUZjg&authuser=0]2[/url]
[url=https://drive.google.com/open?id=0B2vZ6lUhEr87bFpWc28xWW05NGs&authuser=0]3[/url]
[url=https://drive.google.com/open?id=0B2vZ6lUhEr87cS1xMGxxTE54Q3c&authuser=0]4[/url]
Youtube Link for the trailer:
plugin://plugin.video.youtube/?action=play_video&videoid=fhDwT3JdtTQ
And also ,,,it doesn't appears any "local trailer saved" in the edit tab...when actualy i have movies with trailer(s) in movie folders...
it's a mess?
@ orbtwin
Im looking at apple and hd-trailer.net trailer options for Ember right now - I will try to reproduce your problem
(2014-09-26, 00:15)T-bird_se Wrote: [ -> ] (2014-09-25, 00:05)solamnic Wrote: [ -> ] (2014-09-24, 22:09)T-bird_se Wrote: [ -> ]For this to work you must have scanned for meta data
After that the setting for file pattern is
Just updating the library wont do? (i have to do something else?)
Depends of your db status, do you have meta data scraped?
If meta data is selected in settings, all flags are visible on the bar over the fanart picture.
If they are empty, you have to scrape them, do so from drop down "scrape movie" --> all --> automatic --> only meta sata
ounce that is finished, rename just one movie and see if done correct (right click on movie list)
If yes, use bulk renamer on hole collection
Today i managed to try it...
it does not work..
renamed movie goes
lets say
4 Minute Mile.mkv
and not 4.Minute.Mile.2014.1080p.mkv
Hola tengo un probrema con
<mpaa>USA:R</mpaa> deveria escrivir esto Rated R
<certification>USA:R</certification> deveria escrivir esto Rated R
y XBMC no me coge mpaa ni certification
me pueden ayudar GRACIAS..................
<name searchstring="Rated G">
<icon>usa/mpaag.png</icon>
<country>usa</country>
</name>
<name searchstring="Rated PG">
<icon>usa/mpaapg.png</icon>
</name>
<name searchstring="Rated PG-13">
<icon>usa/mpaapg13.png</icon>
</name>
<name searchstring="Rated R">
<icon>usa/mpaar.png</icon>
</name>
<name searchstring="Rated NC-17">
<icon>usa/mpaanc17.png</icon>
(2014-10-03, 14:16)jtm010101 Wrote: [ -> ]Hola tengo un probrema con
<mpaa>USAG-R</mpaa> deveria escrivir esto Rated R
<certification>USAG-R</certification> deveria escrivir esto Rated R
</name>
</name>
</name>
</name>
... and in english?
(2014-10-03, 14:08)solamnic Wrote: [ -> ] (2014-09-26, 00:15)T-bird_se Wrote: [ -> ] (2014-09-25, 00:05)solamnic Wrote: [ -> ]Just updating the library wont do? (i have to do something else?)
it does not work..
renamed movie goes
lets say
4 Minute Mile.mkv
Tell me the existing file name and what you wanna have as result.
Lets say:
Filename
About.Time.(2013).720p.Bluray.X264.Dts-Ltrg.mkv
needs to be renamed to
About.Time.2013.720p.mkv
