When I updated to the newest version I started fresh. Everything was going fine until none of my TV shows will import now. Previous beta I didn't have an issue. My media is on a NAS and I have the shares mounted to my computer. This is the same for my movies which import fine.
This is the error that shows. I'm guessing it's not finding the shared drive? Thanks
2014-10-18 23:22:21.8994,EmberAPI.Scanner,EmberAPI.Scanner.ScanTVSourceDir,8,ERROR,ScanTVSourceDir,"EXCEPTION OCCURRED:System.NullReferenceException: Object reference not set to an instance of an object.
at EmberAPI.Scanner.ScanTVSourceDir(String sSource, String sPath, String sLang, Ordering sOrdering, Boolean isInner)* at EmberAPI.Scanner.ScanTVSourceDir(String sSource, String sPath, String sLang, Ordering sOrdering, Boolean isInner)"
2014-10-18 23:25:45.5840,EmberAPI.Scanner,EmberAPI.Scanner.ScanForTVFiles,7,ERROR,ScanForTVFiles,"EXCEPTION OCCURRED:System.IO.IOException: An unexpected network error occurred.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.CommonInit()
at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
at System.IO.DirectoryInfo.InternalGetFiles(String searchPattern, SearchOption searchOption)
at System.IO.DirectoryInfo.GetFiles()
at EmberAPI.Scanner.ScanForTVFiles(TVShowContainer& tShow, String sPath)* at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at EmberAPI.Scanner.ScanForTVFiles(TVShowContainer& tShow, String sPath)"
2014-10-18 23:25:45.5840,EmberAPI.Scanner,EmberAPI.Scanner.ScanTVSourceDir,7,ERROR,ScanTVSourceDir,"EXCEPTION OCCURRED:System.NullReferenceException: Object reference not set to an instance of an object.
