Full Version: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
(2020-04-13, 10:26)beinhart Wrote: [ -> ]good mornig at all,
I have problems playing some german radio stations like ANTENNE BAYERN or Radio7.
kodi 18.6 is running with libreelec on pi3 and ubuntu 18.04 on nuc.
after choosing the radio station kodi crahes. log says something about curl and it happens
with radio 2.4.2 and radio 3.0.0
2020-04-13 10:01:41.969 T:140460374337280 NOTICE: [plugin.audio.radio_de] get_top_stations started with sizeperpage=50, pageindex=1
2020-04-13 10:01:41.969 T:140460374337280 NOTICE: [plugin.audio.radio_de] __api_call started with path=v2/search/topstations, param={'sizeperpage'$
2020-04-13 10:01:41.970 T:140460374337280 NOTICE: [plugin.audio.radio_de] __urlopen opening url=http://api.radio.de/info/v2/search/topstations?siz$
2020-04-13 10:01:46.441 T:140459572905728 NOTICE: [xbmcswift2] Request for "/station/9111" matches rule for function "get_stream_url"
2020-04-13 10:01:46.441 T:140459572905728 NOTICE: [plugin.audio.radio_de] get_station_by_station_id started with station_id=9111
2020-04-13 10:01:46.441 T:140459572905728 NOTICE: [plugin.audio.radio_de] __api_call started with path=v2/search/station, param={'station': '9111'}
2020-04-13 10:01:46.441 T:140459572905728 NOTICE: [plugin.audio.radio_de] __urlopen opening url=http://api.radio.de/info/v2/search/station?station$
2020-04-13 10:01:46.539 T:140459572905728 NOTICE: [plugin.audio.radio_de] get_stream_url result: https://stream.antenne.de/antenne/stream/mp3?aw_0$
2020-04-13 10:01:48.120 T:140459213039360 ERROR: CCurlFile::FillBuffer - Failed: Error in the HTTP2 framing layer(16)
2020-04-13 10:01:48.171 T:140459213039360 ERROR: Open - error probing input format, https://stream.antenne.de/antenne/stream...st.playeri$
2020-04-13 10:01:48.172 T:140459213039360 ERROR: Init: Error creating demuxer
2020-04-13 10:01:48.172 T:140459213039360 ERROR: CAudioDecoder: Unable to Init Codec while loading file https://stream.antenne.de/antenne/stream/$
2020-04-13 10:01:48.172 T:140459213039360 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
2020-04-13 10:01:48.354 T:140460365944576 NOTICE: [xbmcswift2] Request for "/station/2275" matches rule for function "get_stream_url"
2020-04-13 10:01:48.354 T:140460365944576 NOTICE: [plugin.audio.radio_de] get_station_by_station_id started with station_id=2275
2020-04-13 10:01:48.354 T:140460365944576 NOTICE: [plugin.audio.radio_de] __api_call started with path=v2/search/station, param={'station': '2275'}
2020-04-13 10:01:48.354 T:140460365944576 NOTICE: [plugin.audio.radio_de] __urlopen opening url=http://api.radio.de/info/v2/search/station?station$
Not related to curl but with an issue in kodi regarding the BusyDialog (2 instances at the same time): https://github.com/xbmc/xbmc/issues/16756
Till the moment no kodi developer has yet come up with a proper solution to the issue.
Hi, I tried to add Revolution 96.2 to My Channels but couldn't get it to work, any chance could this be added to the addon?
I was using
http://webradio.radiomonitor.com/m3u/Revolution.m3u
which works in VLC but not in the addon.
(2020-04-13, 12:57)FXB78 Wrote: [ -> ]Hi, I tried to add Revolution 96.2 to My Channels but couldn't get it to work, any chance could this be added to the addon?
I was using
Sure, done in https://github.com/XBMC-Addons/plugin.au...7ac2a41a77
I'll push a new release in a while.
(2020-04-13, 13:22)enen92 Wrote: [ -> ]
I was using
Great, thanks Smile
When I try to play Antenne Bayern - Oldies But Goldies, it either doesn't play goes back to station list, or crashes Kodi.
Given Kodi has crashed and I have three logs, how do I upload them, so I can post their links here?
In Kodi 17.6 and Kodi 18.6 plays no problem
(2020-04-13, 14:49)Jeffers24 Wrote: [ -> ]When I try to play Antenne Bayern - Oldies But Goldies, it either doesn't play goes back to station list, or crashes Kodi.
See my reply above, this is a known issue in kodi.
Just want to  say thanks to all involved in this Radio add-on on Kodi (Add-on:Radio (wiki)), it is excellent and it's great that people have kept this thread going since 2012!
Unlike others posting, I thankfully have no issues with radio channels playing.
However, i do have a query - it's a bit a long-winded but bear with me!.
I am using libreelec 9.2.1 on a raspberry pi - where the only add on that I want is this Radio add-on.
Why - well because i want to give it to an elderly person as an internet radio connected to her stereo versus 3.5mm jack.
I have picked nine radio stations and added them to favourites.
In the "Startup" options, I have set "perform on startup"  to "Play Radio" and "Startup Window" to "home window"
where for my Home options i have specified only favourites (audio/video/music/weather etc are all hidden).
So, once the Kodi (libreelec) starts up, she is met with a home screen consisting of 9 radio stations - she need only select one and it plays - so all good.
Ideally it would be nice if one of the radio stations could start playing upon boot up but don't think that's possible.
For most stations when you click on them, you remain in the home screen and the in top right corner you see a blue play arrow and the name of the station. That is perfect.:-)
But then some stations, when you click on them, it brings you into a NEW screen specifically for that one radio station. :-(
It is confusing for her to know to select the Square button in the bottom left of the screen to get back to the list of favourite radio stations on the home screen.
So, my question, how do i stop a radio station opening it's own window? (the station in question is LMFM in Ireland!)
(2020-04-13, 15:16)enen92 Wrote: [ -> ]
Do you mean this post https://forum.kodi.tv/showthread.php?tid...pid2940193 where you have posted a fix to github and will do a release later?
(2020-04-13, 15:46)Jeffers24 Wrote: [ -> ]
This one
https://forum.kodi.tv/showthread.php?tid...pid2940180
(2020-04-13, 21:34)enen92 Wrote: [ -> ]
(2020-04-13, 15:16)enen92 Wrote: [ -> ]See my reply above, this is a known issue in kodi.
This one
Thanks for the link.
I read the kodi dialogue on github.
Didn't understand it all, and not clear if the kodi team accept issue and will fix it.
If it is the same issue, my example is when using the Radio Music Addon.
Anyone experienced issues with saved stations lately? If i choose a station from my stations i want to play it sometimes plays the choosen station and sometimes it throws me an error. After i get an error shown all saved stations get deleted and the my_stations.json is empty after that. 🤔
(2020-04-15, 17:59)peat Wrote: [ -> ]Anyone experienced issues with saved stations lately? If i choose a station from my stations i want to play it sometimes plays the choosen station and sometimes it throws me an error. After i get an error shown all saved stations get deleted and the my_stations.json is empty after that. 🤔
please post a log and a snipped of the my_stations.json file
Since version 3.0.1 I get an error with my custom station
http://stream.radioparadise.com/aac-320
Never had problems before with it...
(2020-04-16, 10:50)C.O.D. Wrote: [ -> ]Since version 3.0.1 I get an error with my custom station
Similar issue here: I had a custom "France Info" station, started to fail with "Radio error"; solved that by doing a search and saving the station found there.
I've been using this add-on for a long time and it's been great, but now I'm having problems with kodi version 18.6
I've updated my raspberry pi to latest LibreELEC(9.2.1) and kodi 18.6-Leia
This fresh install has the radio add-on but I can't get some stations to play. When I search for radioparadise it finds the station but playback results in an error.
That station has multiple different streams for different types of music and when I add them to the custom stations they result in playback errors too.
I used the kodi feature to post the debug log to http://ix.io/2iK9
Any ideas on what could cause this? I know the stream links are good. I'm currently listening to them on another pi/kodi with the radio add-on that hasn't been updated yet.
Thanks for all the time you put in on this.
