2012-06-13, 16:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
2012-06-13, 16:25
(2012-06-13, 16:17)qickquestion Wrote: [ -> ]Thank you very much!
http://xbmclogs.com/show.php?id=3541
It starts at line 275.
Like I guessed: One of your my-stations is not accessible. I have to catch that error.
16:03:07 T:139994459010816 NOTICE: Radio.de scraper: __urlopen opening url=http://radio.de/info/broadcast/getbroadcastembedded?broadcast=11534
16:03:07 T:139994459010816 NOTICE: Radio.de scraper: __urlopen ended with 3358 bytes result
16:03:07 T:139994459010816 NOTICE: Radio.de scraper: __resolve_playlist started with playlist_url=http://62.75.187.84:8000/listen.pls
16:03:07 T:139994459010816 NOTICE: Radio.de scraper: __urlopen opening url=http://62.75.187.84:8000/listen.pls
16:03:07 T:139994459010816 NOTICE: Radio.de scraper: __urlopen URLError: <urlopen error [Errno 111] Connection refused>
If you want to quick fix it yourself, open "~/.xbmc/userdata/addon_data/plugin.audio.radio_de/settings.xml" and remove station 11534 from settings.setting.mystations.value.
I'm rewriting the my-stations logic anyway - so it should be fixed in a few days.
regards,
sphere
2012-06-13, 16:31
It worked! Marvellous!
So the problem are those IDs, if the station ceases to exist?
2012-06-14, 14:40
I created a new version of this addon.
Changelog:
On first start it will migrate all your stations from your mystations-list to store them in a json file.
The listing of "My Stations" will be much faster after the migration (so the second entering).
I would be happy if some of you could test it and report back if everything works as expected or anything went wrong.
You can download it (Version 1.1.0) here.
regards,
sphere
Changelog:
- New My Station logic
regards,
sphere
2012-06-15, 03:42
Thanks for this, works a treat!, missus would like smooth radio adding to the list (UK)!
Cheers
Cheers
2012-06-15, 22:58
Really an excellent add-on sphere. I like it a lot. Only a pity that the streams don't work when added to the favorites. Any change in the core planned for that?
2012-06-16, 09:21
(2012-06-15, 22:58)dcallebaut Wrote: [ -> ]Really an excellent add-on sphere. I like it a lot. Only a pity that the streams don't work when added to the favorites. Any change in the core planned for that?
It is on my list - I guess it will be ready for testing in a few days.
2012-07-14, 09:33
Version 1.1.0 is now in the official Repo.
As mentioned earlier you should notice speed improvements regarding the My-Stations Menu.
regards,
sphere
regards,
sphere
2012-07-14, 11:47
Is it possible manually to add radio stream?
2012-07-14, 19:51
(2012-07-14, 11:47)skullmonkey Wrote: [ -> ]Is it possible manually to add radio stream?
This is on my todo-list, I will announce it here when its ready.
regards,
sphere
2012-07-15, 09:48
2012-07-17, 08:03
(2012-07-15, 09:48)skullmonkey Wrote: [ -> ]Any ETA on that?
Thanks,
S@
I think I have a beta ready for testing within this week.
2012-07-17, 08:12
Thanks for you Nice Radio addon!
and for your xbmcswiftFork for the xbox!
Regards Jan
(skatulskijean) my Jan'sEnglishXBMC4XBOX http://www.xbmc4xbox.org.uk/forum/viewto...p?f=9&t=72
Regards Jan
2012-07-23, 13:20
It works fine for me.
Why not a Spanish language version?
This is my Spanish translated English strings.xml file.
Thank you.
Thank you.
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<strings>
<!-- Root menu entries -->
<string id="30100">Emisoras recomendadas por los editores</string>
<string id="30101">Las 100 mejores emisoras</string>
<string id="30102">Buscar por género</string>
<string id="30103">Buscar por tema</string>
<string id="30104">Buscar por país</string>
<string id="30105">Buscar por ciudad</string>
<string id="30106">Buscar por idioma</string>
<string id="30107">Emisoras cercanas</string>
<string id="30108">Mis emisoras</string>
<!-- Search -->
<string id="30200">Buscar una emisora</string>
<string id="30201">Escriba el nombre, país o idioma</string>
<!-- Settings -->
<string id="30300">Idioma</string>
<string id="30301">Inglés</string>
<string id="30302">Alemán</string>
<string id="30303">Francés</string>
<!-- Spanish string in Setting "Español" -->
<!-- Context Menu -->
<string id="30400">Añadir a "Mis emisoras"</string>
<string id="30401">Quitar de "Mis emisoras"</string>
</strings>
2012-07-23, 13:52
(2012-07-23, 13:20)Patrizia Wrote: [ -> ]This is my Spanish translated English strings.xml file.
cool - I will add it. Could you also translate "summary" and "description" in the addon.xml?
