I seem to be having a problem opening the CouchPotato webbrowser at
http://localhost:5000
I had it running on my server. A windows 7 32 bit box. Everything was working fine unitl I tried to add a movie this morning. I couldn't open the browser to edit my entires, This is the error I now have:
Error 500 Internal Server Error
Something unexpected has happened.
I was getting this with my old install and am getting the same with an install that I downloaded today. I also have Sickbeard and SABnzbd installed on the same PC and can access their local webpage for editing.
Here is the log file:
15:58:16 INFO [ app.config.db] Initializing Database.
15:58:16 INFO [ ENGINE] Listening for SIGTERM.
15:58:16 INFO [ ENGINE] Bus STARTING
15:58:16 ERROR [ ENGINE] Set handler for console events.
15:58:16 INFO [ ENGINE] Started monitor thread '_TimeoutMonitor'.
15:58:18 INFO [ app.lib.cron] Starting Cronjobs.
15:58:18 INFO [er.yarr.sources.nzbmatrix] Using NZBMatrix provider
15:58:18 INFO [rovider.yarr.sources.nzbs] Using NZBs.org provider
15:58:18 INFO [ider.yarr.sources.newznab] Using Newznab provider
15:58:18 INFO [provider.yarr.sources.tpb] Using TPB.org provider
15:58:18 INFO [.movie.sources.theMovieDb] Using TheMovieDb provider.
15:58:18 INFO [movie.sources.imdbWrapper] Using IMDB provider.
15:58:18 INFO [ app.lib.cron.trailer] TrailerCron thread is running.
15:58:18 INFO [ app.lib.cron.subtitle] SubtitleCron thread is running.
15:58:18 INFO [ app.lib.cron.eta] MovieETA thread is running.
15:58:18 INFO [ app.lib.cron.renamer] Renamer thread is running.
15:58:18 INFO [ app.lib.cron.renamer] Watched folder doesn't exist.
15:58:18 INFO [ app.lib.cron.yarr] YarrCron thread is running.
15:58:19 INFO [ ENGINE] Serving on 0.0.0.0:5000
15:58:19 INFO [ ENGINE] Bus STARTED
15:58:22 INFO [04/Apr/2011:15:58:22] HTTP
Request Headers:
COOKIE: showDetails=false; jqCookieJar_tablesorter=%7B%22showListTable%22%3A%5B%5B1%2C0%5D%5D%7D; smplrefresh=5; showDetails=false; session_id=f14941e7e600f88ed79cf188cac5ab28bf8100ba; speedlog2=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
HOST: localhost:5000
KEEP-ALIVE: 115
CONNECTION: keep-alive
Remote-Addr: 127.0.0.1
ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
ACCEPT-CHARSET: ISO-8859-1,utf-8;q=0.7,*;q=0.7
USER-AGENT: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.13) Gecko/20101203 Firefox/3.6.13
ACCEPT-LANGUAGE: en-us,en;q=0.5
ACCEPT-ENCODING: gzip,deflate
15:58:22 ERROR [04/Apr/2011:15:58:22] HTTP Traceback (most recent call last):
File "C:/Program Files/RuudBurger-CouchPotato-ce5b537\cherrypy\_cprequest.py", line 660, in respond
response.body = self.handler()
File "C:/Program Files/RuudBurger-CouchPotato-ce5b537\cherrypy\lib\encoding.py", line 193, in __call__
self.body = self.oldhandler(*args, **kwargs)
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962\app\config\render.py", line 14, in __call__
return self.template.render_unicode(**env)
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962/library\mako\template.py", line 198, in render_unicode
as_unicode=True)
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962/library\mako\runtime.py", line 403, in _render
_render_context(template, callable_, context, *args, **_kwargs_for_callable(callable_, data))
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962/library\mako\runtime.py", line 434, in _render_context
_exec_template(inherit, lclcontext, args=args, kwargs=kwargs)
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962/library\mako\runtime.py", line 457, in _exec_template
callable_(context, *args, **kwargs)
File "_base_html", line 72, in render_body
File "C:/Users/SERVER/AppData/Local/Temp/_MEI37962\app\config\updater.py", line 118, in checkForUpdate
self.updateVersion = update.get('name').replace('RuudBurger-CouchPotato-', '').replace('.tar.gz', '')
UnboundLocalError: local variable 'update' referenced before assignment
15:58:29 INFO [ app.lib.cron.yarr] Searching for new downloads, for all movies.
15:58:29 INFO [ app.lib.cron.yarr] Finished search.
15:59:24 INFO [04/Apr/2011:15:59:24] HTTP
Request Headers:
COOKIE: showDetails=false; jqCookieJar_tablesorter=%7B%22showListTable%22%3A%5B%5B1%2C0%5D%5D%7D; smplrefresh=5; showDetails=false; session_id=10e8b31ce89d168cf5dd2b22e7bf7a4e595eff9a; speedlog2=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
KEEP-ALIVE: 115
15:59:24 ERROR [04/Apr/2011:15:59:24] HTTP Traceback (most recent call last):
as_unicode=True)
Any help with this is appreciated.
Thanks,
Mark
