2010-09-20, 16:59
Hi, I'm running the r21 Windows build of CouchPotato, but I cannot seem to get the automatic downloading of NZBs to work. The log is also not really helping me in this case..
I start Couchpotato and I have 1 movie (Iron-Man 1080p) in the Wanted list, I hit the refresh button when it comes up, and nothing happens.
I tried both the Blackhole and SabNZB options, but neither seems to work.
What am I doing wrong?
EDIT: Seems all that was needed, was a little patience..
Great stuff!
16:49:59,996 INFO [app.config.db] Initializing Database.
16:50:00,091 INFO [app.lib.cron] Starting Cronjobs.
16:50:00,091 INFO [app.lib.provider.yarr.sources.nzbmatrix] Using NZBMatrix provider
16:50:00,091 INFO [app.lib.provider.yarr.sources.nzbs] Using NZBs.org provider
16:50:00,091 INFO [app.lib.provider.yarr.sources.tpb] Using TPB.org provider
16:50:00,091 INFO [app.lib.provider.movie.sources.theMovieDb] Using TheMovieDb provider.
16:50:00,091 INFO [app.lib.provider.movie.sources.imdbWrapper] Using IMDB provider.
16:50:00,107 INFO [app.lib.cron.cronTrailer] TrailerCron thread is running.
16:50:00,107 INFO [app.lib.cron.cronETA] MovieETA thread is running.
16:50:00,107 INFO [app.lib.cron.cronRenamer] Renamer thread is running.
16:50:00,107 INFO [app.lib.cron.cronYarr] YarrCron thread is running.
16:50:00,107 INFO [app.lib.cron.cronRenamer] Watched folder doesn't exist.
16:50:02,134 INFO [app.config.updater] No update available
16:50:11,118 INFO [app.lib.cron.cronYarr] Searching for new download for all movies.
16:50:31,207 INFO [app.lib.cron.cronYarr] Finished search.
Great stuff!
