Ok, could you post it at the Github Issues?
Something to check out
Stumbled on this yesterday. Excellent work!
simply amazing....
I had added some movies via the URL links because the sab ext in chrome doesn't work for ME using it remotely here at work. the movies completed and went into my completed folder but weren't renamed and moved because CP had no idea about them.
I simpled added to to the CP database let if fetch the move and deleted it after it added to sab.
CP renamed and moved my file once it saw it was in the completed folder....
*does cloud 9 happy dance*
-=Jason=-
freezy Wrote:Stumbled on this yesterday. Excellent work!
XBMC, Sabnzbdplus,CouchPotato, and Sickbeard should all be MUST have for any HTPC.....
-=Jason=-
so I just had a lil snafoo happen
I downloaded IP Man and IP Man 2 when IP Man 2 was finished it got renamed as IP Man and moved into IP Mans folder instead of IP Man 2 folder
it must not have known that IP man 2 was a different movie due to the file name
22:22:19,489 INFO [app.lib.cron.cronRenamer] Removing dir: /mnt/1tb/unsorted.media/Complete/Movies/Ip Man 2 2010 720p BluRay x264 DTS WiKi in download dir.
22:21:52,259 INFO [app.lib.cron.cronTrailer] No trailer found for Ip Man.
22:21:29,642 INFO [app.lib.provider.trailers.hdtrailers] Searching http://www.hd-trailers.net/blog/?s=Ip+Man
22:21:19,377 INFO [app.lib.provider.trailers.hdtrailers] Searching http://www.hd-trailers.net/movie/ip-man/
22:21:19,376 INFO [app.lib.cron.cronTrailer] Search for trailer for: Ip Man
22:21:19,347 INFO [app.lib.cron.cronRenamer] Removing dir: /mnt/1tb/unsorted.media/Complete/Movies/Ip Man 2 2010 720p BluRay x264 DTS WiKi/sample in download dir.
22:21:19,345 ERROR [app.lib.cron.cronRenamer] Tried to clean-up download folder, but "/mnt/1tb/unsorted.media/Complete/Movies/Ip Man 2 2010 720p BluRay x264 DTS WiKi" isn't empty.
22:21:19,148 INFO [app.lib.cron.cronRenamer] Moving file "/mnt/1tb/unsorted.media/Complete/Movies/Ip Man 2 2010 720p BluRay x264 DTS WiKi/ip.man.2.2010.720p.bluray.x264.dts-wiki.mkv" to /mnt/1tb/Movies/Ip Man (2008)/Ip Man.mkv.
22:21:19,147 INFO [app.lib.cron.cronRenamer] Removed old file: /mnt/1tb/Movies/Ip Man (2008)/Ip Man.mkv
22:21:19,062 INFO [app.lib.cron.cronRenamer] Quality Old: 4478, New 6702.
22:21:19,043 INFO [app.lib.cron.cronRenamer] Trying to find a home for: ip.man.2.2010.720p.bluray.x264.dts-wiki.mkv
22:21:19,041 INFO [app.lib.cron.cronRenamer] Total size of new files is 6702.
22:21:19,040 INFO [app.lib.cron.cronRenamer] Finding quality for Ip Man.
22:21:19,030 INFO [app.lib.cron.cronRenamer] Found via last resort searching.
21:33:39,646 INFO [app.lib.cron.cronYarr] Finished search.
-=Jason=-
Yeah last resort searching isn't really accurate.
Will check it out, because I had the same with Tomb Raider.
Just got recommended here from the Sick Beard forums. Nice work so far. I'd like to suggest a feature:
Minimum AND maximum qualities. I know you have max quality already, but I'd like for it not to download certain movies until an R5, DVDRip, or 720p version becomes available. So it would ignore TS/CAM for that particular movie, but download the higher quality versions.
Also, it'd be nice if there were a filter based on the time it was in theaters or the amount of money it made in theaters, since that will filter out a lot of the junk.
You can do the quality thing already, just create your own in Settings.
And what do you want to filter out? You add the movies yourself
Thanks... figured out the quality thing by reading back a few pages (oops). For filtering, I'm talking about the Coming Soon page, which is also currently stuck on "Searching for new release dates" for me (will troubleshoot/post log later). I was assuming that page showed all movies that were coming to DVD or theaters soon.
Al the movies that are in your wanted list.
Yeah I know about the endless "searching for new release dates" if you find out, when it does that. let me know
RuudBurger Wrote:Yeah last resort searching isn't really accurate.
Nooooooooooooooooo.....
this just happened with Twilight new moon just overwrote twilight shit..... these were 15GB files ...
-=Jason=-
Do you have SABNzbd set to delete the .nfo files?
Because this shouldn't happen if an .nfo file with IMDB link exists.
And, maybe it's a sign you should download such shitty movies
Hmm. When "checking", is there any order or filtering? I have 44 movies on the "wanted" list, amongst others Centurion which was released yesterday and also shows up on nzbm but doesn't get snatched. Doesn't even get searched after when checking the logs. However it shows up on the "soon" page, under theater releases (26 aug), so I'm assuming that CouchPotato doesn't search for movies that aren't supposed to be released?
Yeah it uses the release date. Could you make an issue for it on github?
Should make something to force the search.
