Ok...Im lost. Vista 32 bit Installed Python 3.1.2, installed r11 double click on couchpotato.exe and it appears to work for a few seconds and then nothing...Here is the log:
http://pastebin.ca/1902205
New Windows build available, with some bug fixes and more accurate search.
HarryRosen
Latest release should fix it.
@kri kri
Nothing planned yet. As soon as a movie is downloaded, you shouldn't be needing CP for it anymore
@Only One Haze
The Windows build shouldn't need a python installation and uses it's own python included in the .exe. Please check out the latest build, I fixed a few bugs
I love this app. But for some reason when it downloads the torrents my bittorrent client says there's something wrong with them and that I need to re-download them.
With all of them or just a few? If it's a few, could you PM me the movienames + year + quality?
Every one that was downloaded was bad in utorrent and bitcomet
jbrillo1126
Found what it is, will be fixed in next release
@Only One Haze
Does it make the config. data.db files and start the browser?
Latest gitversion has an update function build in now. Go to /config/update/ and wait
No GUI for it yet, want to test it out a bit first, so please try it.
Still have to find a way to update the Windows .exe. As it it in use and thus can't be overwriten. If someone has an idea, please let me know.
RuudBurger Wrote:@kri kri
What kri is probably asking for, and what I'd like to see eventually, is the ability to look for upgrades for movies like Sickbeard can now do for TV shows. That way I can upgrade my old SD rips to BluRay 720p or 1080p as they become available.
Testing out the latest Windows exe now, thanks for all the hard work!
RuudBurger Wrote:@Only One Haze
makes the config.ini, data.db and the cache and log folders but does not start the browser.
New version available, with updating functions.
It will say you will need an update, the first time you start it. This is because I don't know the version if you never used the update function. So this time, you'll have to do a double update. (Hope that makes sense...)
Windows users will get a notification, but still have to shutdown and overwrite the .exe manually
@Only One Haze
I don't know what it could be..
Started using this out of curiosity and firstly have to say it's pretty sweet so far.
Only problem I noticed is that I've specified only BRRip, 720p and 1080p and it is pulling back nzb's with 'R5 Line' in the title. They do also have 720p but I'm thinking that maybe it's not explicitly saying that it does not want the qualities I've deselected (R5 etc.)?
Other than that, looking awesome so far - keep up the great work!!
anything I need to change in the config after its created? does my default web browser (chrome) have anything to do with it maybe?
No it should work. Maybe check you firewall or something.
ECEC Wrote:What kri is probably asking for, and what I'd like to see eventually, is the ability to look for upgrades for movies like Sickbeard can now do for TV shows. That way I can upgrade my old SD rips to BluRay 720p or 1080p as they become available.
This is exactly what I would like.
