I've tried both settings and yet I'm still getting the same response.. I'll go back to the 17th nightly and see how that works out.
At least it's not the script or the skin though
Your guys work is working perfectly but the cinema script its self isnt.. No biggie though I. Sure it'll be sorted soon.
Still the popup menu and trailer in a Window etc are awesome and starting a movie in a window is a Massiv plus for us as we can pick one while we start the other one off....
Awesome work as usual guys!
PatrickBateman Wrote:I love you butch x
That sounds like something an inmate might say
el_Paraguayo Wrote:htpc_guy Wrote:That sounds like something an inmate might say
best post ever!
bump...+1...FTW...
Really really laughed about this one *thumbsup*
mad-max Wrote:bump...+1...FTW...
Couldn't help but make the comment. It was was screaming at me. Now back on topic.
Looking back... I really should have put the "a" on the end
I currently have the theme installed including the updates from SVN on my ATV 2 - for some reason today, I go into movies and the default icon is no longer there, how do I get it back?
Thanks in advance
PatrickBateman Wrote:Hey guys,
Popup menu is working perfectly for me, it's fantastic! Such a great little menu and sooo useful. It also saves me from accidentally hitting down and getting a trailer in the face when I least expect it
I'm on the latest nightly and it's working perfectly with cinema, and all options do as expected! Outstanding work el_p it's pretty much perfect!
I'd love to be able to Play cinema windowed but I think we discussed this earlier as being a limitation of the cinema script. For me I'd lime to watch the trailers in a windows and then if I see any I like add them to my favourites at the click of a button, then I'll full screen it manually when the film begins...
It's working pretty much perfectly though, I'll test it throughly and see if I can break it
It
is possible to get Cinema Experience to play trailers in a window, but you'd need to edit the script yourself.
If this is important to you I can probably talk you through the necessary changes.
ady199 Wrote:I currently have the theme installed including the updates from SVN on my ATV 2 - for some reason today, I go into movies and the default icon is no longer there, how do I get it back?
Thanks in advance
Settings Show parent folder.
butchabay Wrote:Settings Show parent folder.
Thanks for your reply and sorry for sounding thick, but you say settings, is this under the system menu?
Thanks in advance
ady199 Wrote:Thanks for your reply and sorry for sounding thick, but you say settings, is this under the system menu?
Thanks in advance
System Settings -> Appearence --> File lists -> show parent folder items...
Machine-Sanctum Wrote:System Settings -> Appearence --> File lists -> show parent folder items...
That's what I thought, but I already have this enabled and it's still not showing in Movies
Edit: I've just checked and it's showing under Music but not Movies
