el_Paraguayo Wrote:Weemaan,
Not a silly question at all.
Looking at the code, the skin is looking for the user-defined location of the fanart, but I can't see it in the Skin Settings page. Butcha, pm me if I didn't send that bit through.
You'll also need to download the fanart if you haven't done so already. The link's in the post with the download link for the skin.
el_P
Hey,
Yea i was about to report back on a few little things i have found, this was one of them
Also, the origonal "Clean Home Now Playing" option is also missing even when the new "extended now playing" is disabled?
A few comestic things i noticed too, were,
The new Extended now playing bar seems to be a different level of transparency/colour to the main cirrus menu bars, could this be set to match the other bars purly for cosmetic reasons? Most of the menu bars are a darker transparent black (weather, date, time, horizontal menu,medi update screen etc...) and the new now playing seems to be much lighter and sticks out a little from the rest of the skin.
When streaming some music the progress bar doesn't work (i assume this is due to some trakcs having no end time) is there any work around for this?
When the next 5 tracks is enabled and one of the tracks has a long file name and is requireed to scroll, is it possible for the number (1,2,3,4,5) to stay exactly where it is and only have the text of the track scroll raththan the entire track titles and number?
And finally (for now)
The extended now playing window sits directly on top of the rss feed and about 10 pixels down from the horizontal menu bar, is it at all possible to center the extended now playing plugin so that it would sit 5 pixels above the rss ticker and 5 pixels below the horizontal menu to help it look and feel more comfortable symetrical? "i know its not exatly 10 pixels but i knoe you know what im trying to say :-))
Thats all ive been able to test so far, as i have not yest finihsed my fresh install of my other htpc so ill keep you guys posted with any bugs etc that i come across.
Amazing work though, from what i have seen so far, this update is beyond incredible.
I'm so grateful that you guys do what you do and ill be sure to report back with all/any bugs for you to help keep this skin as truly amazing as it is.
Thanks again for another wonderful release guys x
Also, i hope you don't think i am complaining or anything, as thats most defiently not the case!
I love this skin and i can't sing its praises enough, just reporting back with any all bugs/info/feedback i have to help you guys out for the next updates etc.
Thanks again for everything...
butcha did you do something to the main skin animation? I am getting a screen flash/flicker ever time i open and close a option from the main menu? its quite a dramtic/prominent flash and is very noticible... its as if the screen goes completly black for a 100th of a second and then re draws its self? For example, when returning/entering from the videos/weather etc there appears to be a dramtic "pop" as the screen "pops" back into view from black, im usre this faded in before, but i could be wrong
It never used to do this (that i can remember) but it is quite prominant and distracts me every time i exit and enter a window etc? Like a slap in the face
