(2012-05-24, 09:36)Hunter2-1 Wrote: [ -> ]Are the source files available for the buttons by any chance? It would be much easier, I'm adding an outer glow to the buttons so they can resemble the tron style a bit more.
Thoughts on the colors?
This is probably going to need a different font color:
you can find most of the source files I made for this skin here
http://forum.xbmc.org/showthread.php?tid=103419
I wanted to do a TR0N theme for long, but lack time for it, so glad you started it. With my source files you should manage to do it easily. Good luck!
If you need special files (I worked them in Illustrator generally) just ask me, I will put them temporarly on the cloud so you can download them
(2012-05-26, 10:50)N.O.W.A.L.L Wrote: [ -> ]you can find most of the source files I made for this skin here http://forum.xbmc.org/showthread.php?tid=103419
Thanks, I'll see what I can do.
I noticed that there are 3d and hd movie genres in extras/moviegenresnowall and extras/moviegenres, how can I use them?
I made you these 3d bluray cases and logos I hope you use them in the skin
I couldn't post all of them so here are the rest:
3dbd
http://www2.zshare.ma/fe0q1isk5v2n
You need to tag every 3D movie as 3D genre.
Thanx for the cases, is something i'm working on, so great timing
(2012-05-27, 09:20)butchabay Wrote: [ -> ]You need to tag every 3D movie as 3D genre.
Ah in that case I will wait. My 3D movies look like this: Despicable Me (2010) 3DBD.mkv
Awesome!
There's more in the download link, I made several since I didn't know which ones you would need.
hunter> Yeah, I designed the moviegenres with HD/3D options. Useless for now, but maybe in the future it will be useful, that's why I made an ultra complete set.
I noticed I didn't put all the source files on my thread > just MP me if you need specific file(s)
What prevented me to do the TRON them was, 1st lack of time, but also that I knew that, to make it really cool, I'd have to take all the icons, make them cyan (easy part) but also add a glow effect (pain in the ass part).
What you did until now is really cool, exactly how I had imagined to do it myself, congrats!
with a black/glowing cyan theme, I think we would need different backgrounds than current CE2's, something more hi-tech.
Anyway, great work!
butcha - is it possibile for you to make easy way to change set of beckgrounds. On Aeon MQ3 you can set folder for diferent set's.
Already there, you can set single picture or choose a background folder for every home item.
butcha - you mean thet there is way to set let say all cyan backgrounds what in one folder. I know how to change every item manualy. If there is way to change from orange to cyan or black with pointing only one folder pls. explain. May be I dont know where to look.
Thanks in advance.
(2012-05-27, 11:01)N.O.W.A.L.L Wrote: [ -> ]@hunter> Yeah, I designed the moviegenres with HD/3D options. Useless for now, but maybe in the future it will be useful, that's why I made an ultra complete set.
Anyway, great work!
Please send me all the files you think need a glow effect.
I agree that adding the glow effect is the hard part but it's way easier if I have the source files
Here is the link to the source files, with icons, textures etc:
http://www.mediafire.com/download.php?8xnyjupt7a9la83
If you want, I could upload the full moviegenres files, but it's heavy... 1Gb!
But with only one condition: if you decide to edit the moviegenres, you'll have to do the french ones too, not only the english!
Hope you'll be able to work with this.
Please tell me when you'll have downloaded the data, so that I can delete it from mediafire
Best regards
PS
When your theme will be completed, I guess I will pimp my OS too.
I've found these on devianart, should look cool with a Tron Theme
Download link
http://necramar.deviantart.com/art/Carbo...-258273943
(2012-05-28, 10:52)N.O.W.A.L.L Wrote: [ -> ]Please tell me when you'll have downloaded the data, so that I can delete it from mediafire
Downloaded. Thanks
I will do the genres once I'm done with the rest.
I might as well match the colors with those folders right?
Is it necessary to compress textures? Is there an easier way to test changes?
(2012-05-27, 20:32)harybary Wrote: [ -> ]@butcha - you mean thet there is way to set let say all cyan backgrounds what in one folder. I know how to change every item manualy. If there is way to change from orange to cyan or black with pointing only one folder pls. explain. May be I dont know where to look.
Thanks in advance.
Just replace the backgrounds in the skin folder. Within the skin you have to change it by one to one yes, that's how all other skins do.
(2012-05-29, 06:12)Hunter2-1 Wrote: [ -> ]Is it necessary to compress textures? Is there an easier way to test changes?
Yes. Else you need to download uncompressed media folder and replace the .png's with yours ...
