@ UnisonRuss do u use preEden or Dharma ?
on Dharma the add-on tv next aired who delivers the informations for the TV-Guide is not working.
That's why, I'm using Dharma. Thanks! Does the play random movie script not work on Dharma either? I don't see an option for it anywhere...
UnisonRuss Wrote:That's why, I'm using Dharma. Thanks! Does the play random movie script not work on Dharma either? I don't see an option for it anywhere...
Random Movie is only for dharma now, el_p is going to make it preEden compatible.
Plot outline is showing fine for me on the highlighted item, that depends on
the scraper if plot outline is fetched or not.
butchabay Wrote:Is tv next aired working again? I'll have to try it.
About banners, you have setup " use banner.jpg " in extended mod settings?
You need to have banner.jpg in your tvshow folders.
yes it does, i do have banner in the setup also i change the fanart.jpg for landscape.jpg in custom_TVGuide_1115.xml to had the correct bakground , but i cant use the banner but dont know what to change
Thank you for the fast response! However, plot details are scraped fine, as they show in the actual library, just not on the homescreen. However, TV Show plot details are visible...just not movies. Also, I noticed that if I change the fanart of a selected movie, it's not reflective on the recently added widget.
As for random movie, I am using Dharma but I still don't see it. I enabled it in the skin options.
Lastly, when will TV Guide work for Dharma again?
UnisonRuss Wrote:Thank you for the fast response! However, plot details are scraped fine, as they show in the actual library, just not on the homescreen. However, TV Show plot details are visible...just not movies. Also, I noticed that if I change the fanart of a selected movie, it's not reflective on the recently added widget.
Have you downloaded the script? You need to install the addon for it to work. The link is in post #1.
As for pre Eden, should have this version ready in a couple of days.
warlion Wrote:yes it does, i do have banner in the setup also i change the fanart.jpg for landscape.jpg in custom_TVGuide_1115.xml to had the correct bakground , but i cant use the banner but dont know what to change
Anyone else having problems? I'm going to take a look, haven't touched the tvguide section so it's the same 2.04 and 2.05 ...
is a clean install of all cirrus and preEden
1. Plot isn't the same as Plot Outline. Switch to another skin and tell me if you see the plot (don't think so, but you may try)
2. Fanart is grabbed from the scraped image, you have setup extrafanart ?
3. Random Movie script have to ib in your addons folder, there is nothing you have to setup. You will see them in movies submenu.
warlion Wrote:is a clean install of all cirrus and preEden
TV Guide fixed! I'll share the files later ...
MaRINoL Wrote:Hello-
Would you mind sharing how you got 2.05 working on the ATV2? For the life of me, I have not been able to get in to install regardless of what I've tried.
Installing from zip, I receive the message that the addon does not have the proper structure.
Unzipping and copying over via SSH I get errors due to commas in file names within the flagging directory.
I've tried modding addon.xml, re-zipping and copying to no avail.
I updated to the latest ATV2 nightly, xbmc-20110829-bfbb8cd-master-atv2.deb 29-Aug-2011 10:56
I'm out of ideas at this point.
Extract the files from the rar file first............
Then copy over the
skin.cirrus extended v2 folder to:-
/private/var/mobile/Library/Prefrences/XBMC/addons
It's as simple as that.
I must admit though that I've gone back to using v2.04 - The fanart is just so slow with v2.05.
