butchabay Wrote:Yeah hopefully the fanart problem is solved soon. Thanx a lot for your help.
Cheers
FYI, my ATV2 fanart problem was, in fact, solved by updating to the most recent nightly as was suggested in the other thread. It's almost instantaneous now.
xbmc-20110831-b7436bd-master-atv2.deb
To all the devs, thanks for all the work, effort & patience!
butch, you should come over to efnet & join #multiman. I, for one, would be curious to see what you could come up with in terms of themes for multiMAN. Between Dean, you and Condor, you could polish/perfect the UI.
Just a thought if you ever have time.
Regards
Hi there,
I just came back from holliday and ... CE 2.05 is here!!
Butcha: Awesome!! as usual. Thanks for the hard work. This skin is getting better and better.
El_P: Thanks for all the work you do on this skin. And thanks especially for Weather Fanart Condition when entering Weather (my request).
NOWALL: Thanks for your work (if you needs help for french strings tell me... et à ce propos, l'option de la barre de progression de el_p marche quand on la desactive...)
I tried to install 2.05 via repository.xbmcnerds but always get just the version 2.03 to install. What could be the problem?
on the repo must be the 2.04 Version.
go to the repository overview in XBMC mark the repository.xbmcnerds go inte the contextmenü and klick on update reposetory. Then u should see the newest Versions who are availible on the repository.
2.05 Is not availibe on the repository yet. You have to install it manuell by copy the Folder into your Addon Folder on your HDD.
Yes, repo isn't updated for preEden due some addon.xml problem.
I'm already working on 2.06. Big performance increasment for all views, some reworked textures and bugfixes should be finished soon. As keibertz said download, unrar in your addons folder. Be sure to delete 2.04 first.
hey butchabay by the way it is posible to show a tv guide widget showing the show aired today similar to the one skin.simplicity use
i try but fail so bad
warlion
I can surely take a look, but it's not on high priority list.
+1 for that feature! Would be really cool to see that...TV Aired on homescreen
I would also like to have a Random Movie or Random Show script on the homescreen as well, perhaps combine with recently added? There is one for Featured Music already, so it would make sense to have one for the others.
Also looking forward to 2.06, thanks for all your hard work!
Just a message for info: the alpha version of the Metropolis skin has been released (wow, very gorgeous! though I'll keep with CE2, more convenient for me).
The Metropolis skinner has also cleverly implemented some "random widget" on the home screen.
Maybe El_Paraguayo will be interested in comparing the 2 codes
I just don't know if you can have both (recently added a random) widgets on home.
Metropolis is definitive the best looking skin at the moment!
looks bad ass, i love the information of the movie on fanart and the watched notification in shows keep it coming
butchabay Wrote:I just don't know if you can have both (recently added a random) widgets on home.
Where can i find the Skin Metropolis ? is the Skin preEden ready ?
EDIT: Ok found the Skin
http://forum.xbmc.org/showthread.php?tid=99317 and not preEden ready
