butchabay Wrote:Ofcourse, that's why i've integrated use banner.jpg support
Use posters instead of banners should be default, as i see every day the same comments about that ... squished posters !
lol sorry. Should of know you already had that in it. Not really familiar with your settings. Because mine worked from the start
Machine-Sanctum Wrote:lol sorry. Should of know you already had that in it. Not really familiar with your settings. Because mine worked from the start
Sadly it's a setting in the scraper, they really should set it as deafault, because actually it's set to banners by default.
butchabay Wrote:Sadly it's a setting in the scraper, they really should set it as deafault, because actually it's set to banners by default.
I think Confluence needs it by default
Commited to SVN:
Dharma and Pre Eden:
- Reworked Fanart Slide view
- Login Screen ( not finished )
- mpeg1 & mpeg2 Flags Fixed ( Thanx to yohan )
I love this skin so much. One question though. For some reason, under the TV SHOWS 'Fanart Slide Logo' view for SVN Dharma, there is a weird graphical hiccup that I've noticed. When browsing the the shows, there is an empty slot to navigate to the parent directory that is labeled 'Logo Missing.' Is there any way to fix this that anyone is aware of? Suggestions would be most helpful!
brandonjcreek Wrote:I love this skin so much. One question though. For some reason, under the TV SHOWS 'Fanart Slide Logo' view for SVN Dharma, there is a weird graphical hiccup that I've noticed. When browsing the the shows, there is an empty slot to navigate to the parent directory that is labeled 'Logo Missing.' Is there any way to fix this that anyone is aware of? Suggestions would be most helpful!
Just disable show parent folder item in settings. Most views are looking ugly in several skins if enabled, so if you don't really need it, disable it.
What is SVN and how do I install it so I can get all these updates?
butchabay Wrote:Please could you test something?
Open home.xml and set :
Line2
PHP Code:
<defaultcontrol always="true">8999</defaultcontrol>
To:
PHP Code:
<defaultcontrol always="true">9000</defaultcontrol>
and
Line4
PHP Code:
<allowoverlay>no</allowoverlay>
To:
PHP Code:
<allowoverlay>yes</allowoverlay>
And try to start ptv from favourites ...
Thanx
Yep, that fixed it. Thanks a ton!
Butcha,
Do you Remember the issue with free cable plugin, where upon, when you load the plugin it would chgne the view from "list" to fan art and therefore it would become almost impossible to navigate.
I think the resolution was to enter the plugin another way... .
Well, that issue seems to have returned for me, for Freecable and now 4od?
Is this a skin related issue, or plugin related? If its plugin related move this into the respective threads to see if they can resolve the issue..
Basically, more plugins are now displaying in fanart view when previously they were being displsyed in list view and therefore the names of the tvshows etc re not visible (as its fanart) and it's not possible to change it manually to list view?
Any ideas bro,
Pat~
PatrickBateman Wrote:Butcha,
Any ideas bro,
Pat~
Strange, i've created fanart landscape view exactly for these kind of addons and checked free cable and everything was displayed well. Same for youtube addon, lately they changed back again and now you can use the file views (fanart square, fanart wide, fanart poster same for rightlist view).
I can't change the views everytime the plugin autors are changing something. Sorry.
Fallback views are returning back to list view everytime you're entering (youtube, vimeo), but free cable is handled as episodes, maybe they've changed something again.
