pang Wrote:Can anyone help me why on any version of cirrus even the latest svn for dharma the tv guide is always blank. do i need to install something or do asomething to make it work?
Pang
No there were several problems with all scripts in the latest nightlies.
We just have to wait and hope ...
EDIT: See
http://forum.xbmc.org/showthread.php?tid=110545 same problem.
Try to refresh.
Pang
you need the addon TV Show Next Aired
right now the addon tv show is down is been update yesterday and you need the last night that will be available in a few hours
Hi folks,
i've integrated ronies Global Search script in cirrus extended v2, ofcourse with the option to hide it on home. There will be a search button beside the power and favourites buttons too.
ONLY FOR NIGHTLY BUILDS (PRE-EDEN) Already in SVN
keibertz Wrote:Anyone knows a way to autoupdate the SVN folder ?
I have installed Tortoise SVN but i am not able to find a way that the SVN Folder checks every day for new Files.
The only way i found is via batchfile:
CD C:\Program Files\TortoiseSVN\bin\
START TortoiseProc.exe /command:update /path:"C:\www\MyRepo\" /closeonend:0
Via Windows Task-Scheduler i can start this file e.g. once a day.
Any other ideas / ways ?
It must be completly automatic, i dont wanna to go to the Windows Desktop for Update SVN Folder.
PS: SVN is working fine. Skin looks awesome as allways
I'm having problems with my batch file.
I have created the following:-
START TortoiseProc.exe /command:update /path:"C:\Users\Aide\Downloads\Cirrus SVN\" /closeonend:0
But when it runs Tortoise comes back with the following message:-
Action Path
Command Update
Skipped c:\Users\Aide\Downloads\Cirrus SVN
Finished!
It never seems to update, and always comes back with the message: Skipped
What am I doing wrong??
butchabay Wrote:Hi folks,
I've now manually downloaded from the SVN - I'm seeing the recently added - which looks really cool, but one thing I'm not seeing is
Global Search how do I enable this?
ady199 Wrote:I've now manually downloaded from the SVN - I'm seeing the recently added - which looks really cool, but one thing I'm not seeing is Global Search how do I enable this?
It's only visible if you have the script installed.
You have to download the script in the official repo and you'll need the latest nightly build of xbmc.
butchabay Wrote:It's only visible if you have the script installed.
Many Thanks for the info - sorry for being so dumb!
All working now - How do I get it to show the background that you show in your screenshot?? as it's currently just a black background
Butch, buttons are
here
I made 2 versions, up to you to choose…
I won't be able to try them as I don't SVN enabled (I like a stable setup)
Next section will be Music and an option to hide recently added widgets on home.
N.O.W.A.L.L Wrote:Butch, buttons are here
Thanx man, wonderful i'm going to try it out and give a feedback!
@N.O.W.A.L.L
Thanx again bro, version 2 definitively !!!
Sorry to be a pain but where do I get the background image for
Global Search or can I use a wallpaper of my choice? if so, what resolution does the wallpaper have to be?
Thanks in advance
U Can change all the backgrounds from the Homemenüentrys inside the Skinsettings.
Best are Full HD Wallpapers 1920 x 1080. But this depends on your own XBMC resoluten.
