Don't know if this is skin-related or xbmc by design:
As mentioned before my movie view is fanart slide sorted by rating desc, but now movie sets show up right before the first actual movie.
edit: ok, not skin related, Confluence does the same...
Small question
In Movies--->Moviesets fanart view , can i have the info of the movie shown same way as it does when scrolling right and left from one movie to other, in the Fanart view? i mean, is there any option i'm not seeing or is it simply not implemented in that view?
vicmanpergar Wrote:Small question
Moviesets view is intended to use with moviesets, it's the same as fanart slide, info window pops up after a few seconds.
matzer Wrote:Yes, I meant the movie set view in particular, but now modified the other views, too. Usually I use movie fanart slide, sorted by rating desc, so I had the crappy movies shown right next to the best rated
fixedlist... perfect, thx to both of you.
You asked a very good question, and got very good answers... thanks for the trick, I just applied it and it's very cool
dirtydesaster Wrote:in which directory shall I put them?
Hey...weird..I've tried several movies with DTS-MA but CEV2 doesn't show up these signs..so..it isn't working for me ether
@butch: Any idea? With Confluence it works like a charm
Another question...what does these two buttons mean (2)?
Cheers..
@littlemixi:
the codecflagging in confluence is very different from cirrus...
This is what Confluence does:
<include name="AudioCodecFlaggingConditions">
<control type="image">
<description>Audio Codec Image</description>
<width>80</width>
<height>35</height>
<aspectratio align="right">keep</aspectratio>
<texture>$INFO[ListItem.AudioCodec,flagging/audio/,.png]</texture>
</control>
</include>
And this is what Cirrus does:
<description>mp3 Codec Image</description>
<width>75</width>
<height>28</height>
<aspectratio>keep</aspectratio>
<texture>flagging/audio/mp3.png</texture>
<visible>substring(ListItem.AudioCodec,mp3)</visible>
</control>
<description>dts Codec Image</description>
<width>75</width>
<height>28</height>
<texture>flagging/audio/dts.png</texture>
<visible>substring(ListItem.AudioCodec,dca)</visible>
</control>
<description>ac3 Image</description>
<width>75</width>
<height>28</height>
<texture>flagging/audio/ac3.png</texture>
<visible>substring(ListItem.AudioCodec,ac3) + !substring(ListItem.AudioChannels,6)</visible>
</control>
<description>aac Image</description>
<width>75</width>
<height>28</height>
<texture>flagging/audio/aac.png</texture>
<visible>substring(ListItem.AudioCodec,aac)</visible>
</control>
<description>Dolby Digital Image</description>
<width>75</width>
<height>28</height>
<texture>flagging/audio/dolbydigital.png</texture>
<visible>substring(ListItem.AudioCodec,ac3) + substring(ListItem.AudioChannels,6)</visible>
</control>
<description>WMA Pro Codec Image</description>
<width>75</width>
<height>28</height>
<texture>flagging/audio/wmapro.png</texture>
<visible>substring(ListItem.AudioCodec,wmapro)</visible>
</control>
<description>Audio Channels Image</description>
<width>75</width>
<height>28</height>
<aspectratio align="left">keep</aspectratio>
<texture>$INFO[ListItem.AudioChannels,flagging/audio/,.png]</texture>
</control>
</include>
So you might to create a new image and condition for dts-ma like this:
<width>75</width>
<height>28</height>
<texture>flagging/audio/dtsma.png</texture>
<visible>substring(ListItem.AudioCodec,dtshd_ma)</visible>
</control>
@Butch:
Is there a reason why you do the codecflagging that way?
I saw some !substring(channels6)...
Just curious, because this might reduce the code a bit
i changed the home.xml code in the lines of
<visible>!Skin.HasSetting(homeNoClock)</visible>
<visible>!Skin.HasSetting(originalcirrusclock)</visible>
section and added $INFO[Weather.Temperature] so now i can see temperature in my upper date bar but how can i get long date?
As always..our fast guy mm
Ok..I add your code and it's working now..unfortunatly I couldn't edit these .xbt files which contains the audio flags
Can someone call me a tool?
Sorry guys, no time for cirrus atm ...
butchabay Wrote:Sorry guys, no time for cirrus atm ...
no problem. i read the wiki and got it. i changed $INFO[System.Date] to
$INFO[System.Date(DDD)], $INFO[System.Date(d)]. $INFO[System.Date(MMM)] $INFO[System.Date(yyyy)]
and now it works fine and looks great (for me)
@ Nimo can u post a Screenshot and attach the changed file please ?
littlemixi Wrote:As always..our fast guy mm
Uncompressed media is linked in the first post int the thread...
cheers,
Max
@ butch i know u dont have time for this Skin at the moment but maby u can fix this error when u finde a little time. Or in some weeks when u have time again.
In Fanart View ViewsVideoFanart.xml if the movie title is to long and is scolling the font hight is set too low. So the movie title looks bad while scrolling
line 226 and 241
Quote:<height>30</height>
<font>cirrus_40</font>
please change it too this then it looks perfekt even during scolling
Nimo thx for posting screenshot and file
