2017-11-11, 16:44
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
2017-11-13, 11:43
Awesome announcement dmd! Fingers crossed you manage to implement a solution for resume playback on encrypted videos and a fix for the watched state (completion %) on encrypted videos.
2017-11-17, 07:20
Hello,
I have follow the tutorial from other site then it take me here.
I got some error while let the script encrypt to work (script from https://github.com/SteveMalso/Encrypt-and-Upload-GDrive)
When I do the python strm.py 1 2 3 4 5 6 7 I got
also installed pycrypto with command pip install pycrypto
So this script will upload everything has been completed download to google drive and encrypt it at google drive?
//edit:
I am got it work and enter verification code but got another error
Quote: python strm.py 1 2 3 4 5 6 7How can I fix that ?
File "strm.py", line 14, in <module>
strmDestination = str(sys.argv[8])
//edit:
File "strm.py", line 21, in <module>
pb = Pushbullet("Your API Key")
File "/home/akuser/.local/lib/python2.7/site-packages/pushbullet/pushbullet.py", line 43, in __init__
self.refresh()
File "/home/akuser/.local/lib/python2.7/site-packages/pushbullet/pushbullet.py", line 381, in refresh
self._load_devices()
File "/home/akuser/.local/lib/python2.7/site-packages/pushbullet/pushbullet.py", line 78, in _load_devices
resp_dict = self._get_data(self.DEVICES_URL)
File "/home/akuser/.local/lib/python2.7/site-packages/pushbullet/pushbullet.py", line 67, in _get_data
raise InvalidKeyError()
pushbullet.errors.InvalidKeyError
2017-11-17, 14:20
(2017-11-01, 14:20)dmdsoftware Wrote: [ -> ]Hi, i think i found the reason for the failure and it is some kind of my bad. I put the CLOUD_DB xml spreadsheet in the root of the teamdrive and set the watch and resume option to google drive spreadsheet. I got the folder structure like "[cloud: library]" , therefore i thought it would be the right place for die CLOUD_DB for Teamdrives. But as stated before it results in an error.(2017-10-29, 16:32)klesk Wrote: [ -> ](2017-09-23, 22:58)klesk Wrote: [ -> ]Yes, you hit the mark.That's what i meant when i wrote about Spreadsheet Issue with Teamdrives.
As soon as i set the resume point and playback count to "local only" playback starts working.
If i set it back to "Google Drive Spreadsheet" it stops.
Thx, I will look into that issue.
A couple of days ago i got the idea, and sorry for my misinterpretation, to put it into the root of my normal google drive account. Now i can play video files with spreadsheet enabled without and error.
Again sorry for the trouble.
2017-11-17, 16:21
(2017-11-17, 14:20)klesk Wrote: [ -> ]Thanks for the update. The intent will be that the document could be in a team drive or my drive. Now I further understand the issue and I can fix it so that the spreadsheet will work with either.(2017-11-01, 14:20)dmdsoftware Wrote: [ -> ]Hi, i think i found the reason for the failure and it is some kind of my bad. I put the CLOUD_DB xml spreadsheet in the root of the teamdrive and set the watch and resume option to google drive spreadsheet. I got the folder structure like "[cloud: library]" , therefore i thought it would be the right place for die CLOUD_DB for Teamdrives. But as stated before it results in an error.(2017-10-29, 16:32)klesk Wrote: [ -> ]That's what i meant when i wrote about Spreadsheet Issue with Teamdrives.
2017-11-17, 16:25
Teaser video for the Google Drive KODI plugin for HTML5 browsers.
2017-11-17, 21:08
Looks good so far, i am really looking forward to test it on my own.
There are many possibilities now.
2017-11-18, 02:41
(2017-11-17, 21:08)klesk Wrote: [ -> ]Looks good so far, i am really looking forward to test it on my own.I'll be pushing out binary files soon for Mac and Windows, but if you have python installed on your linux or mac, you can give it a spin:
https://github.com/ddurdle/Python-Google...ree/master
Works great on VPS and Google Compute Engines.
2017-11-18, 17:02
(2017-11-18, 02:41)dmdsoftware Wrote: [ -> ]Thank you, i cloned it to my vps and my localhost, both linux.(2017-11-17, 21:08)klesk Wrote: [ -> ]Looks good so far, i am really looking forward to test it on my own.I'll be pushing out binary files soon for Mac and Windows, but if you have python installed on your linux or mac, you can give it a spin:
I was able to import my settings.xml and start the application, browse the content of my gdrive and also teamdrive.
But i wasn't able to playback a file, it think something is missing. I tested with Firefox 56, Pale Moon 27.6.1 and Google Chrome on Android.
Here the settings.xml modded (removed credentials)
python dbm_import.py ./gdrive.db settings.xml
saving the following key,value pairs
account_default,1
accounts,1
always_cache,false
avoid_codec,0
avoid_format,0
cache_continue,false
cache_percent,20
cache_single,false
cache_srt,false
cache_thumbnails,false
cc,true
chunk_size,163840
context_emusic,0
context_ephoto,0
context_evideo,0
context_music,0
context_photo,0
context_video,0
crashreport_enable,false
crashreport_os,0
crashreport_version,0
encfs_cache_percent,10
encfs_cache_single,false
encfs_chunk_size,163840
encfs_continue,false
encfs_download_type,1
encfs_exp,false
encfs_inode,0
encfs_stream,false
local_db,false
movie_db_watch,true
never_stream,true
parse_music,true
parse_tv,true
photo_resolution,1
preferred_format,5
preferred_quality,0
prompt_quality,false
resumeprompt,true
srt,true
stream_port,8011
streamer,false
strm,true
strm_path,/storage/STRM/
trace,false
tv_db_watch,true
user_agent,Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US) AppleWebKit/532.0 (KHTML, like Gecko) Chrome/3.0.195.38 Safari/532.0
video_skip,70
Unfortunately there is no error
python default.py
LOAD LANGUAGES
Google Drive Media Server ready....
CONSTANT =True
Host: 12.34.56.78:9988
User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:52.9) Gecko/20100101 Goanna/3.4 Firefox/52.9 PaleMoon/27.6.1
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3
Accept-Encoding: gzip, deflate
Connection: keep-alive
IN
[enroll account]
Acc1
Remove account from plugin
Acc2
98.76.54.321 - - [18/Nov/2017 15:47:59] "GET / HTTP/1.1" 200 -
OUT <a href="default.py?mode=enroll&content_type=">[enroll account]</a><br />
<a href="default.py?mode=main&content_type=&instance=gdrive1">Acc1</a><br />
<a href="default.py?mode=main&content_type=&instance=gdrive2">Acc2</a><br />
CONSTANT =True
Referer: http://12.34.56.78:9988/
show all
Videos
[show all Videos]
show all
Shared Files & Folders
[show all Shared Files & Folders]
show all
Starred Files & Folders
[show all Starred Files & Folders]
setting key gdrive2_auth_refresh_token
setting key gdrive2_auth_access_token
SEARCH
[SEARCH]
<Testing - manual run of change tracking build STRM>
Filme
Save STRM
Make offline
Playback Entire Folder
[treat as encfs]
[treat as crypto]
Scan Media Info
98.76.54.321 - - [18/Nov/2017 15:48:03] "GET /default.py?mode=main&content_type=&instance=gdrive2 HTTP/1.1" 200 -
OUT <a href="?mode=index&folder=VIDEO&instance=gdrive2&content_type=video">[show all Videos]</a><br />
<a href="?mode=index&folder=SHARED&instance=gdrive2&content_type=video">[show all Shared Files & Folders]</a><br />
<a href="?mode=index&folder=STARRED-FILESFOLDERS&instance=gdrive2&content_type=video">[show all Starred Files & Folders]</a><br />
<a href="?mode=search&instance=gdrive2&content_type=video">[SEARCH]</a><br />
<a href="?mode=buildstrm2&instance=gdrive2&content_type=video">(Testing - manual run of change tracking build STRM)</a><br />
<a href="?mode=index&instance=gdrive2&folder=1lj_jenotu_vF2z4yVezyh6xrtHIQUSNH&epath=%2FFilme%2F&content_type=video">Filme</a><br />
CONSTANT =True
Referer: http://51.15.193.27:9988/default.py?mode...ce=gdrive2
Annabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
98.76.54.321 - - [18/Nov/2017 15:48:04] "GET /default.py?mode=index&instance=gdrive2&folder=1lj_jenotu_vF2z4yVezyh6xrtHIQUSNH&epath=%2FFilme%2F&content_type=video HTTP/1.1" 200 -
OUT <a href="?mode=index&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F&content_type=video">Annabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE</a><br />
CONSTANT =True
Referer: http://51.15.193.27:9988/default.py?mode...type=video
CONSTANT =True
Proof
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
Sample
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
Subs
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
coincidence-annabelle2-1080p.mkv
Save STRM
Play ...
Start at
Make offline
Play + make offline
98.76.54.321 - - [18/Nov/2017 15:48:08] "GET /default.py?mode=index&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F&content_type=video HTTP/1.1" 200 -
OUT <a href="?mode=index&instance=gdrive2&folder=1-RFQujbVERWPf34PdUivmIxHKy5Vq7Rs&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F%2FProof%2F&content_type=video">Proof</a><br />
<a href="?mode=index&instance=gdrive2&folder=1FjWXU85a40doRXAfb9mSLP3qu_a4ohCP&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F%2FSample%2F&content_type=video">Sample</a><br />
<a href="?mode=index&instance=gdrive2&folder=1beb3oEm71QvuGjBLob0aM7F62uPq91q4&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F%2FSubs%2F&content_type=video">Subs</a><br />
<a href="?mode=video&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&filename=13ny7N6Vwu7MtpsQm1gOvtuMP_t1qH7Jz&title=coincidence-annabelle2-1080p.mkv&content_type=video">coincidence-annabelle2-1080p.mkv</a><br />
Proof
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
Sample
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
Subs
Save STRM
Make offline
[treat as encfs]
[treat as crypto]
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
98.76.54.321 - - [18/Nov/2017 15:48:09] "GET /default.py?mode=index&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&epath=%2FFilme%2F%2FAnnabelle.2.2017.German.DL.1080p.BluRay.x264-COiNCiDENCE%2F&content_type=video HTTP/1.1" 200 -
CONSTANT =True
Referer: http://12.34.56.78:9988/default.py?mode=...type=video
QuZiV_cZaFI
98.76.54.321 - - [18/Nov/2017 15:48:10] "GET /default.py?mode=video&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&filename=13ny7N6Vwu7MtpsQm1gOvtuMP_t1qH7Jz&title=coincidence-annabelle2-1080p.mkv&content_type=video HTTP/1.1" 302 -
url = https://www.googleapis.com/drive/v2/file...&alt=media
cookie = QuZiV_cZaFI
auth = Bearer+ya29.Gl0IBZ_RgLy6UvMcZD19OzDZrwB-FHF1ChJxCeLY1oD1BmzAN3qL1rZPGroUD4A11yJHG2H_CZr9cluWymcQrrFP8gdnx8zFedT7sxGDdVmNY3FwbVwOkbFiIX9sMp0
ITEM = https://www.googleapis.com/drive/v2/file...bFiIX9sMp0
98.76.54.321 - - [18/Nov/2017 15:48:10] "GET /default.py?mode=video&instance=gdrive2&folder=1fic01aJPwHK6Hizbzc0bVI5s7qtAYXPK&filename=13ny7N6Vwu7MtpsQm1gOvtuMP_t1qH7Jz&title=coincidence-annabelle2-1080p.mkv&content_type=video HTTP/1.1" 200 -
OUT
CONSTANT =True
PLAYBACK
STILL ERROR
CONSTANT =True
PLAYBACK
STILL ERROR
^CTraceback (most recent call last):
File "default.py", line 44, in <module>
server.handle_request()
File "/usr/lib/python2.7/SocketServer.py", line 271, in handle_request
fd_sets = _eintr_retry(select.select, [self], , , timeout)
File "/usr/lib/python2.7/SocketServer.py", line 150, in _eintr_retry
return func(*args)
KeyboardInterrupt
2017-11-18, 17:14
(2017-11-18, 17:02)klesk Wrote: [ -> ]I will test with those config parameters. Probably something related to them -- should be fixable(2017-11-18, 02:41)dmdsoftware Wrote: [ -> ]Thank you, i cloned it to my vps and my localhost, both linux.(2017-11-17, 21:08)klesk Wrote: [ -> ]Looks good so far, i am really looking forward to test it on my own.I'll be pushing out binary files soon for Mac and Windows, but if you have python installed on your linux or mac, you can give it a spin:
Code:python dbm_import.py ./gdrive.db settings.xml
account_default,1
accounts,1
always_cache,false
avoid_codec,0
avoid_format,0
cache_percent,20
cache_single,false
cache_srt,false
cc,true
chunk_size,163840
context_emusic,0
context_ephoto,0
context_evideo,0
context_music,0
context_photo,0
context_video,0
crashreport_os,0
encfs_exp,false
encfs_inode,0
encfs_stream,false
local_db,false
movie_db_watch,true
never_stream,true
parse_music,true
parse_tv,true
photo_resolution,1
preferred_format,5
preferred_quality,0
resumeprompt,true
srt,true
stream_port,8011
streamer,false
strm,true
trace,false
tv_db_watch,true
video_skip,70
Code:python default.py
LOAD LANGUAGES
CONSTANT =True
IN
[enroll account]
Acc1
Acc2
CONSTANT =True
show all
Videos
[show all Videos]
show all
show all
SEARCH
[SEARCH]
Filme
Save STRM
Make offline
[treat as encfs][treat as crypto]
Scan Media Info
CONSTANT =True
Save STRM
Make offline
Scan Media Info
CONSTANT =True
CONSTANT =True
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
CONSTANT =True
QuZiV_cZaFI
OUT
CONSTANT =True
PLAYBACK
STILL ERROR
CONSTANT =True
PLAYBACK
STILL ERROR
return func(*args)
KeyboardInterrupt
2017-11-18, 18:53
(2017-11-18, 17:02)klesk Wrote: [ -> ]Good news, I loaded your settings and my playback broke too with same error. So don't change anything. Let me investigate the culprit with the settings.(2017-11-18, 02:41)dmdsoftware Wrote: [ -> ]Thank you, i cloned it to my vps and my localhost, both linux.(2017-11-17, 21:08)klesk Wrote: [ -> ]Looks good so far, i am really looking forward to test it on my own.I'll be pushing out binary files soon for Mac and Windows, but if you have python installed on your linux or mac, you can give it a spin:
account_default,1
accounts,1
always_cache,false
avoid_codec,0
avoid_format,0
cache_percent,20
cache_single,false
cache_srt,false
cc,true
chunk_size,163840
context_emusic,0
context_ephoto,0
context_evideo,0
context_music,0
context_photo,0
context_video,0
crashreport_os,0
encfs_exp,false
encfs_inode,0
encfs_stream,false
local_db,false
movie_db_watch,true
never_stream,true
parse_music,true
parse_tv,true
photo_resolution,1
preferred_format,5
preferred_quality,0
resumeprompt,true
srt,true
stream_port,8011
streamer,false
strm,true
trace,false
tv_db_watch,true
video_skip,70
LOAD LANGUAGES
CONSTANT =True
IN
[enroll account]
Acc1
Acc2
CONSTANT =True
show all
Videos
[show all Videos]
show all
show all
SEARCH
[SEARCH]
Filme
Save STRM
Make offline
Scan Media Info
CONSTANT =True
Save STRM
Make offline
Scan Media Info
CONSTANT =True
CONSTANT =True
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
CONSTANT =True
QuZiV_cZaFI
OUT
CONSTANT =True
PLAYBACK
STILL ERROR
CONSTANT =True
PLAYBACK
STILL ERROR
return func(*args)
KeyboardInterrupt
2017-11-18, 19:45
(2017-11-18, 18:53)dmdsoftware Wrote: [ -> ]Ok, sounds good, i am on standby. Maybe it has something to do, that i disabled transcoding and only use original quality ?(2017-11-18, 17:02)klesk Wrote: [ -> ]Good news, I loaded your settings and my playback broke too with same error. So don't change anything. Let me investigate the culprit with the settings.(2017-11-18, 02:41)dmdsoftware Wrote: [ -> ] I'll be pushing out binary files soon for Mac and Windows, but if you have python installed on your linux or mac, you can give it a spin:Thank you, i cloned it to my vps and my localhost, both linux.
account_default,1
accounts,1
always_cache,false
avoid_codec,0
avoid_format,0
cache_percent,20
cache_single,false
cache_srt,false
cc,true
chunk_size,163840
context_emusic,0
context_ephoto,0
context_evideo,0
context_music,0
context_photo,0
context_video,0
crashreport_os,0
encfs_exp,false
encfs_inode,0
encfs_stream,false
local_db,false
movie_db_watch,true
never_stream,true
parse_music,true
parse_tv,true
photo_resolution,1
preferred_format,5
preferred_quality,0
resumeprompt,true
srt,true
stream_port,8011
streamer,false
strm,true
trace,false
tv_db_watch,true
video_skip,70
LOAD LANGUAGES
CONSTANT =True
IN
[enroll account]
Acc1
Acc2
CONSTANT =True
show all
Videos
[show all Videos]
show all
show all
SEARCH
[SEARCH]
Filme
Save STRM
Make offline
Scan Media Info
CONSTANT =True
Save STRM
Make offline
Scan Media Info
CONSTANT =True
CONSTANT =True
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
CONSTANT =True
QuZiV_cZaFI
OUT
CONSTANT =True
PLAYBACK
STILL ERROR
CONSTANT =True
PLAYBACK
STILL ERROR
return func(*args)
KeyboardInterrupt
UPDATE
set never_stream to false and it works
2017-11-18, 23:35
(2017-11-18, 19:45)klesk Wrote: [ -> ]I checked and the working settings.xml I was using indeed used never_stream=false.(2017-11-18, 18:53)dmdsoftware Wrote: [ -> ]Ok, sounds good, i am on standby. Maybe it has something to do, that i disabled transcoding and only use original quality ?(2017-11-18, 17:02)klesk Wrote: [ -> ]Thank you, i cloned it to my vps and my localhost, both linux.Good news, I loaded your settings and my playback broke too with same error. So don't change anything. Let me investigate the culprit with the settings.
account_default,1
accounts,1
always_cache,false
avoid_codec,0
avoid_format,0
cache_percent,20
cache_single,false
cache_srt,false
cc,true
chunk_size,163840
context_emusic,0
context_ephoto,0
context_evideo,0
context_music,0
context_photo,0
context_video,0
crashreport_os,0
encfs_exp,false
encfs_inode,0
encfs_stream,false
local_db,false
movie_db_watch,true
never_stream,true
parse_music,true
parse_tv,true
photo_resolution,1
preferred_format,5
preferred_quality,0
resumeprompt,true
srt,true
stream_port,8011
streamer,false
strm,true
trace,false
tv_db_watch,true
video_skip,70
LOAD LANGUAGES
CONSTANT =True
IN
[enroll account]
Acc1
Acc2
CONSTANT =True
show all
Videos
[show all Videos]
show all
show all
SEARCH
[SEARCH]
Filme
Save STRM
Make offline
Scan Media Info
CONSTANT =True
Save STRM
Make offline
Scan Media Info
CONSTANT =True
CONSTANT =True
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
Proof
Save STRM
Make offline
Scan Media Info
Sample
Save STRM
Make offline
Scan Media Info
Subs
Save STRM
Make offline
Scan Media Info
Save STRM
Play ...
Start at
Make offline
Play + make offline
CONSTANT =True
QuZiV_cZaFI
OUT
CONSTANT =True
PLAYBACK
STILL ERROR
CONSTANT =True
PLAYBACK
STILL ERROR
return func(*args)
KeyboardInterrupt
UPDATE
2017-11-19, 00:06
Ok, i know this project is in an early stage and i don't want to pre-empt.
Here are just some first impressions and maybe some other things.
- dbm_display.py don't work, while i can access gdrive.db through dbm_setup.py
- OK, this is hard to explain and maybe a wanted behaviour. I will try my best to make it clear as possible.
- Behaviour[A]
- Client[A] connects and does nothing, Client[X] connects. Now both can start a different Stream.
- Behaviour\[B\]
- Client[A] connects and browse a folder but doesn't start a stream, Client[X] can't connect.
- Behaviour[C]
- Client[A] connects and starts a stream, all other clients which try to connect get redirected to /play?count=x
All Clients can watch the stream, even Client[A] can change the stream to another, while the other Clients can still watch the "old" stream. Also they are able to change the stream to the new stream when the change the url to f.e /play?count=1. But all other Clients then [A] can't browse the folder structure.
- Behaviour[D]
- Client[A] connects and start a stream and gets disconnected. If he reconnects he will be redirected to the previous started stream, but can't go back to the folder structure.
Like i wrote before that a just some first impressions.
Besides that, it works really, really good. It streams like a charm.
Really great work. I am looking forward to the coming features.
python dbm_display.py gdrive.db
usage: dbm_file.db
- Behaviour[A]
- Behaviour\[B\]
Select an account:
Exception happened during processing of request from ('123.45.67.89', 59534)
File "/usr/lib/python2.7/SocketServer.py", line 596, in process_request_thread
self.finish_request(request, client_address)
File "/usr/lib/python2.7/SocketServer.py", line 331, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "/usr/lib/python2.7/SocketServer.py", line 652, in __init__
self.handle()
File "/usr/lib/python2.7/BaseHTTPServer.py", line 340, in handle
self.handle_one_request()
File "/usr/lib/python2.7/BaseHTTPServer.py", line 328, in handle_one_request
method()
File "/home/klesk/Python-GoogleDrive-VideoStream/resources/libgui/webgui.py", line 153, in do_GET
mediaEngine.run(self, DBM=self.server.dbm, addon=self.server.addon)
File "/home/klesk/Python-GoogleDrive-VideoStream/resources/lib/default.py", line 341, in run
instanceName = kodi_common.getInstanceName(addon, addon_parameters.PLUGIN_NAME, mode, instanceName, invokedUsername, numberOfAccounts, contextType)
File "/home/klesk/Python-GoogleDrive-VideoStream/resources/lib/kodi_common.py", line 583, in getInstanceName
ret = xbmcgui.Dialog().select(addon.getLocalizedString(30120), options)
File "/home/klesk/Python-GoogleDrive-VideoStream/resources/libgui/xbmcgui.py", line 31, in select
print heading + ":" + line1 + "\n" + line2 + "\n" + line3
TypeError: cannot concatenate 'str' and 'list' objects
- Behaviour[C]
- Behaviour[D]
2017-11-20, 01:46
Thanks for testing. I'll work on the issues you identified.
The never_stream = true is now fixed among a few other things:
v0.1.1 (2017-11-19)- fix never_stream = true- add support for secure login for /, /list, /kill (to enable, run dbm_setup.py ./gdrive.db username username_to_create and run dbm_setup.py ./gdrive.db password password_to_use)- add "passthrough" mode (to enable, run dbm_setup.py ./gdrive.db passthrough true)- start work on settings- decode language codes into strings https://github.com/ddurdle/Python-Google...-0.1.1.zip
