hey, thx for your great work.
Sadly, i have a few problems.
Usling Linux, kodi 16, i cant get the oauth working
tried google aps and your pass-through.
when i use yours, after i clicked on the acc the first time there was a popup saying account activated/verified successfull, but then i get a popup error, check logs plz
when i use google aps, i get same error popup
https://pastebin.com/1Tv15D1F
the auth works under windows
(2017-05-10, 20:14)Anubiz Wrote: [ -> ]hey, thx for your great work.
Which version of python installed on the linux system? There is known issue with some installs with Python not validating certificates properly, so SSL fails, so first time you would see this is when trying to authenticate.
After authenticating, have you tried backing out with .. of plugin and then re-entering to see if account is listed.
Can i create m3u automatically?
my python version is 2.7.12
and yes, the account is shown in the plugin, right below [enroll account]
Hey dmd, finding the clouddb handling of resume points to be unreliable. For instance, a resume point won't save to the spreadsheet when a video abruptly stops. Would be cool if you could also integrate native Kodi resume functionality with the watch status update.
i am using window v17 version, and i use the newest gdrive add-on,
but how can i login to my google account?
i try OAUTH2 authentication
GOOGLE APPS OAUTH2 - READ-only (DEFAULT)
dmdsoftware.net OAUTH2 - READ-only (DEFAULT)
those method i try one time,but it still can not login,
also i see this
http://dmdsoftware.net/GoogleSetupOAUTH2...drive.html
i choose dmdsoftware OAUTH2
enter my name
and token
i follow the step, and i still can not login
also where can i find my log?
hii there ,
using kodi 17.1 and i have been noticed that my srt files doesn't appeared automatically when i play my shows or movies from gdrive like it used to for me on kodi 16.1 ....
is it just me or it's known issue ?
and thanks for this fantastic addon
I was having problems with the previous version. I got it to say Token Accepted then it would have an error and not connect. New version works fine!
Thanks for keeping this updated, much appreciated. My biggest fear is Google changing the way the code works and this addon stops working because I really can't find anything better this.
Would anyone happen to know how many devices could access your Google Drive at the same time with this addon? I wanted to put it on a few more TVs in my house.
Thanks again Dev!
(2017-05-16, 14:53)audioce0 Wrote: [ -> ]Would anyone happen to know how many devices could access your Google Drive at the same time with this addon? I wanted to put it on a few more TVs in my house.
Thanks again Dev!
If it helps I have it on 8. Not all running simultaneously but 4 TVs and 4 tablets. Also have put my login on a box I did for my parents and a mate.
Sent from my ONEPLUS A3003
(2017-05-16, 17:02)delboy666 Wrote: [ -> ] (2017-05-16, 14:53)audioce0 Wrote: [ -> ]Would anyone happen to know how many devices could access your Google Drive at the same time with this addon? I wanted to put it on a few more TVs in my house.
Thanks again Dev!
Sent from my ONEPLUS A3003 (typie typie)
Thanks for the info. I wonder if it conflicts if they are accessing at the same time.
(2017-05-16, 14:53)audioce0 Wrote: [ -> ]I was having problems with the previous version. I got it to say Token Accepted then it would have an error and not connect. New version works fine!
Thanks again Dev!
Which login method do u use? i am appreciate if you paste the tutorial link. THANKS
(2017-05-17, 03:33)audioce0 Wrote: [ -> ] (2017-05-16, 17:02)delboy666 Wrote: [ -> ] (2017-05-16, 14:53)audioce0 Wrote: [ -> ]Would anyone happen to know how many devices could access your Google Drive at the same time with this addon? I wanted to put it on a few more TVs in my house.
Thanks again Dev!
I don't believe it does I would estimate I have had three different streams going on three devices without issue.
(2017-05-16, 11:36)scofield272 Wrote: [ -> ]hii there ,
I have created an issue so I can track it. i will investigate. It probably is related something that changed in 17.1
https://github.com/ddurdle/GDrive-for-KODI/issues/119
(2017-05-11, 17:34)simonlkch Wrote: [ -> ]i am using window v17 version, and i use the newest gdrive add-on,
also i see this http://dmdsoftware.net/GoogleSetupOAUTH2...drive.html
enter my name
and token
Are you still having an issue?
