Hello and great job with the plugin
Wondering if it's possible to add the STRM creation feature with it creating the structure like we have on gdrive?
I already have my files organized as it should, it would be good to create exactly the same structure but with strm files.
Thanks for your job on this!
(2017-05-18, 13:45)efegue Wrote: [ -> ]Hello and great job with the plugin
if you right-click save STRM, on a folder it will retain this structure. I will update the options to make it more clear.
(2017-05-17, 20:38)scofield272 Wrote: [ -> ] (2017-05-17, 18:45)dmdsoftware Wrote: [ -> ] (2017-05-16, 11:36)scofield272 Wrote: [ -> ]hii there ,
using kodi 17.1 and i have been noticed that my srt files doesn't appeared automatically when i play my shows or movies from gdrive like it used to for me on kodi 16.1 ....
is it just me or it's known issue ?
and thanks for this fantastic addon
I have created an issue so I can track it. i will investigate. It probably is related something that changed in 17.1
https://github.com/ddurdle/GDrive-for-KODI/issues/119
you the best , cheers.
hii again ... kodi 17.3 got out today so if you can fix the thing with the srt ^^ it will be nice if you make it work on kodi 17.3
thanks alot .
(2017-05-25, 11:08)scofield272 Wrote: [ -> ] (2017-05-17, 20:38)scofield272 Wrote: [ -> ] (2017-05-17, 18:45)dmdsoftware Wrote: [ -> ]I have created an issue so I can track it. i will investigate. It probably is related something that changed in 17.1
thanks alot .
Noted, it still happens in 17.3?
How can I film poster or TV shows poster
Sent from my ONEPLUS A3003
(2017-05-25, 15:43)scofield272 Wrote: [ -> ] (2017-05-25, 14:58)dmdsoftware Wrote: [ -> ] (2017-05-25, 11:08)scofield272 Wrote: [ -> ]hii again ... kodi 17.3 got out today so if you can fix the thing with the srt ^^ it will be nice if you make it work on kodi 17.3
thanks alot .
yes sir
The SRT file is stored in the same location on the Google Drive as the video file?
(2017-05-27, 00:25)dmdsoftware Wrote: [ -> ] (2017-05-25, 15:43)scofield272 Wrote: [ -> ] (2017-05-25, 14:58)dmdsoftware Wrote: [ -> ]Noted, it still happens in 17.3?
yes sir
Is anyone else having subtitles issues on KODI 17? I'm not able to reproduce it, and I've asked another user and neither him.
(2017-05-27, 15:02)dmdsoftware Wrote: [ -> ] (2017-05-27, 00:25)dmdsoftware Wrote: [ -> ] (2017-05-25, 15:43)scofield272 Wrote: [ -> ]yes sir
if i go into addon settings -> offline and checkbox offline SRT, the srt files load automatically on 17.3 perfect
is it ok to work like this? what this option change about my srt files ?
(2017-05-28, 11:25)scofield272 Wrote: [ -> ] (2017-05-27, 15:02)dmdsoftware Wrote: [ -> ] (2017-05-27, 00:25)dmdsoftware Wrote: [ -> ]The SRT file is stored in the same location on the Google Drive as the video file?
Offline SRT actually works better then without, in particular when it comes to a case where there are multiple SRT files for a video file. If you have 4 SRT files, for instance, all 4 would load, but they would show up as language unknown for each, and you need to toggle between them to find the one you are looking for. In offline SRT, they cache first (which is not a big concern since it is only text files), so all the language is detected for each, and it will advise you which SRT is for which language.
I'm wondering in your case on this 17.1/17.3 device if the subtitle is taking longer to load when called through online SRT mode, and it isn't loading it for that fact.
(2017-05-28, 13:24)dmdsoftware Wrote: [ -> ] (2017-05-28, 11:25)scofield272 Wrote: [ -> ] (2017-05-27, 15:02)dmdsoftware Wrote: [ -> ]Is anyone else having subtitles issues on KODI 17? I'm not able to reproduce it, and I've asked another user and neither him.
thanks !
so i will keep it as "Offline SRT" for now ,
and the load speed doesn't matter for me so much as long as the srt load automatically .
(2017-05-28, 14:19)scofield272 Wrote: [ -> ] (2017-05-28, 13:24)dmdsoftware Wrote: [ -> ] (2017-05-28, 11:25)scofield272 Wrote: [ -> ]if i go into addon settings -> offline and checkbox offline SRT, the srt files load automatically on 17.3 perfect
thanks !
*update*
even with the "offline SRT" it's working half of the time( some time it load the srt automatically and some time not )... so it must be Because the loading time, it's taking about 10-15 secs to load the stream....
(2017-05-28, 18:14)scofield272 Wrote: [ -> ] (2017-05-28, 14:19)scofield272 Wrote: [ -> ] (2017-05-28, 13:24)dmdsoftware Wrote: [ -> ]Offline SRT actually works better then without, in particular when it comes to a case where there are multiple SRT files for a video file. If you have 4 SRT files, for instance, all 4 would load, but they would show up as language unknown for each, and you need to toggle between them to find the one you are looking for. In offline SRT, they cache first (which is not a big concern since it is only text files), so all the language is detected for each, and it will advise you which SRT is for which language.
thanks !
*update*
When it fails to load, can you hit back to start the video over from the start. I'm almost expecting it will start the subtitles. In that case, I'll know exactly what aspect of the timing is having an issue.
(2017-05-28, 20:40)dmdsoftware Wrote: [ -> ] (2017-05-28, 18:14)scofield272 Wrote: [ -> ] (2017-05-28, 14:19)scofield272 Wrote: [ -> ]thanks !
*update*
yap , on second time the srt is displayed
