(2016-05-22, 23:58)dmdsoftware Wrote: [ -> ] (2016-05-21, 21:55)scofield27 Wrote: [ -> ] (2016-05-21, 17:02)scofield272 Wrote: [ -> ]all my files and srt names are in this format : Viking - ויקינגים
english - hebrew
maybe the hebrew part is what that cause the issue?
** update **
ya this is why lol , i removed the hebrew part from the names and the sub appeared
thanks
I have sent you a PM regarding the issue.
thanks brother,
i cant reply there for some reason , so here the thing you wanted :
http://mab.to/D04iIGEv4
i hope its ok , you can delete my post after you see it
Hi dmdsoftware,
first all, amazing job.
One request could you implement save position and auto mark view for strm files.
I'll trying to add this using code in this other addon:
http://forum.kodi.tv/showthread.php?tid=246110
(2016-05-26, 19:19)torcuato Wrote: [ -> ]Hi dmdsoftware,
Testing underway to store resume points in a google spreadsheet. When you playback, it would ask if you would like to resume. It will also track watched status but it won't appear in the library (library is updated but I find the library doesn't refresh often enough to show the "watched" checkmark.
(2016-05-27, 01:14)dmdsoftware Wrote: [ -> ]Testing underway to store resume points in a google spreadsheet. When you playback, it would ask if you would like to resume. It will also track watched status but it won't appear in the library (library is updated but I find the library doesn't refresh often enough to show the "watched" checkmark.
If I enable on Library settings Google drive spreadsheet, Kodi show me an error when it try to play strm
23:30:21 T:2774555456 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: unknown url type: ?sq=fileid=0B1i-mGcpoRTPbKJwU2ZqR0JUHjA
File "/home/torcuato/.kodi/addons/plugin.video.gdrive-testing/default.py", line 1005, in <module>
media = service.gSpreadsheet.updateMediaPackage(service.worksheetID, package)
File "/home/torcuato/.kodi/addons/plugin.video.gdrive-testing/resources/lib/gSpreadsheets.py", line 343, in updateMediaPackage
response = urllib2.urlopen(req)
File "/usr/lib/python2.7/urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 396, in open
protocol = req.get_type()
File "/usr/lib/python2.7/urllib2.py", line 258, in get_type
raise ValueError, "unknown url type: %s" % self.__original
ValueError: unknown url type: ?sq=fileid=0B1i-mGcpoRTPbKJwU2ZqR0JUHjA
23:30:21 T:2774555456 WARNING: CPythonInvoker(5, /home/torcuato/.kodi/addons/plugin.video.gdrive-testing/default.py): the python script "/home/torcuato/.kodi/addons/plugin.video.gdrive-testing/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE
I'm using last testing build on ubuntu with this setting:
On login tab settings, Cloud Media Spreadsheet ID -> blank
On library tab setings,
Resume point and playbackcount -> Google Drive Spreadsheet
Always resume -> check
Use library integration? -> check
Spreadsheet name -> library
On my account api settings google drive, and google docs has permissions for write & read
Maybe I miss some settings?
is there any chance that gdrive will sync in the future with metadata like imdb or some like that and we will get the posters&data from there to our movies and shows on the drive ?
it will be so awesome
(2016-05-27, 23:38)torcuato Wrote: [ -> ] (2016-05-27, 01:14)dmdsoftware Wrote: [ -> ]Testing underway to store resume points in a google spreadsheet. When you playback, it would ask if you would like to resume. It will also track watched status but it won't appear in the library (library is updated but I find the library doesn't refresh often enough to show the "watched" checkmark.
It requires to load a spreadsheet into your account, which is missing. Add the following to your account (Make a copy... from File Menu)
https://docs.google.com/spreadsheets/d/1...sp=sharing
Once it is added, it should start loading. There is some advance features under testing. Right now, you don't need to make any changes to the spreadsheet *you just need to have it
(2016-05-31, 01:25)dmdsoftware Wrote: [ -> ] (2016-05-30, 17:04)scofield27 Wrote: [ -> ]is there any chance that gdrive will sync in the future with metadata like imdb or some like that and we will get the posters&data from there to our movies and shows on the drive ?
Yes, it is possible
Do you mean without needing .strm files?
Yes, it is possible
oh man , if you will update something like that it will be superr
also please if you can add in gdrive settings "set default view" for the addon ,it will be nice,
(2016-05-31, 13:54)ashlar Wrote: [ -> ] (2016-05-31, 01:25)dmdsoftware Wrote: [ -> ] (2016-05-30, 17:04)scofield27 Wrote: [ -> ]is there any chance that gdrive will sync in the future with metadata like imdb or some like that and we will get the posters&data from there to our movies and shows on the drive ?
Yes, it is possible
correct, without .strm files
(2016-05-31, 18:43)dmdsoftware Wrote: [ -> ] (2016-05-31, 13:54)ashlar Wrote: [ -> ] (2016-05-31, 01:25)dmdsoftware Wrote: [ -> ]Yes, it is possible
WOW! You will make truly happy a couple of friends!
so for now until you do your charms on the "without strm files"...
can i set the gdrive to make strm files automatically to the path i set my library integration to every new movie i upload to my drive?
Any suggestions on best options for storing DVDs for streaming? upload the discs in file format (VOB?), package in iso, etc?
