The core functionality of the addon is now complete.
Hi team! thanks for the addon.
I'm having a problem with gdrive. When I watch a video, is not being marked as watched nor showing the progress as it did in past.
Is there any known bug ongoing?
Ps: I'm using firestick
(2023-04-30, 12:30)romangt Wrote: [ -> ]Hi team! thanks for the addon.
Are you using my addon or the official Kodi Google Drive addon? You may have posted in the wrong thread.
https://forum.kodi.tv/showthread.php?tid...4&page=116
I'm using the official, but I guess I may try your addon and check if it improves over the official one.
(2023-04-30, 21:30)romangt Wrote: [ -> ]I'm using the official, but I guess I may try your addon and check if it improves over the official one.
I don't have that issue using my addon with a 4K Max, can't speak for the other addon though.
i also have 4K max but i havent been able to make this addon work, i have all my content encripted with rclone in a team drive.
how can i make it work?
The decryption/encryption logic was created by dmdsoftware (practically the only code of his left in my addon) which is incompatible with rclone. Your best bet would be to create a rclone mount.
Hi all!
I installed the official addon in Kodi (running in my Google Chromecast). I can access to my files and play them, but there is no way to add them to my collection.
When i export strm file it creates the directories, but there is no files inside.
I export the files to an USB storage connected to the Chromecast (since i didn't find the way to export them to internal storage).
Can anyone help me? where is the problem?
Thanks in advanced!
I repply to myself.
After a lot of reading and trying, I finally managed to add the Google Drive videos to the collection. I'm sharing in case anyone is interested. Indeed, the Google Chromecast (I don't know about other Android TV devices) has some restriction on saving files to external storage, which is why it did not output the .strm files. The solution is to use the internal storage, but Kodi does not show you the internal routes by default. You must first find out the route and add it with a source. There I leave a guide in case someone looks for it one day
https://aguacatec.es/anadir-videos-de-go...n-de-kodi/
