How do I turn this option?
In the past it worked with "M" button
is it only through KEYMAP?
Is there nor option by Krypton for transparent home?? I cant find it. At Jarvis there was a option. Can you bring it back? looks so nice
This is probably more of a Kodi question and not a skin question, I don't know. However, I have OpenWeatherMap extended installed and when I select the weather tile from the home page, I get a screen that looks like the one kobikite posted above, but I don't see how I get to the radar images and all the stuff OpenWEatherMap Extended is suppose to provide.
Do I need to adjust the tile to activate something else?
(2016-01-22, 20:44)Guilouz Wrote: [ -> ] (2016-01-22, 18:08)rhodges Wrote: [ -> ]An odd bug. I don't know if it is in the mod or the base.
Home screen. Highlight the 4th tile and then press left to lighlight the 3rd tile. There is a pause while the background loads. While paused, I have the none/default gray image for a second or so. I tried it with different tiles in positions 3 and 4 and I get the same behavior. I don't get the behavior when moving left from any other positions.
Please post screenshot, I don't see what do you mean.
https://youtu.be/Hd0D0Wfd-sc
Edit: I had edited my reply to someone else to put the video showing the problem. I thought it might get overlooked there so I replied to you since you asked. Sorry if you already seen my respond the the video.
(2016-01-25, 13:34)kobikite Wrote: [ -> ]Hi Guilouz
It looks like a bug :-)
I know, it's fixed in next release.
(2016-01-25, 15:54)Karandras Wrote: [ -> ]Is there nor option by Krypton for transparent home?? I cant find it. At Jarvis there was a option. Can you bring it back? looks so nice
There is same options in Jarvis & Krypton...
(2016-01-25, 18:10)rhodges Wrote: [ -> ]This is probably more of a Kodi question and not a skin question, I don't know. However, I have OpenWeatherMap extended installed and when I select the weather tile from the home page, I get a screen that looks like the one kobikite posted above, but I don't see how I get to the radar images and all the stuff OpenWEatherMap Extended is suppose to provide.
I don't understand, screenshot please.
(2016-01-25, 18:11)rhodges Wrote: [ -> ] (2016-01-22, 20:44)Guilouz Wrote: [ -> ] (2016-01-22, 18:08)rhodges Wrote: [ -> ]An odd bug. I don't know if it is in the mod or the base.
I have not this pause. I think it's your device. I use mysql database and I have not this loading.
(2016-01-25, 09:45)kobikite Wrote: [ -> ]How do I turn this option?
You must map this button with keymap editor. Since Jarvis I had to do that.
(2016-01-25, 19:44)Guilouz Wrote: [ -> ] (2016-01-25, 09:45)kobikite Wrote: [ -> ]How do I turn this option?
What would this be called in the key map editor?
Hi Guilouz, is there anyway to enable the option to password lock an addon? I would like to ensure that say YouTube is locked if I have visitors over
Hi Guilouz,
The Krypton mod is now broken with the last master commits:
http://forum.kodi.tv/showthread.php?tid=...pid2223875
20:44:06 T:140461147248768 DEBUG: LIRC: Update - NEW at 19495:000000037ff07bdd 00 KEY_OK mceusb (KEY_OK)
20:44:06 T:140461147248768 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
20:44:06 T:140461147248768 DEBUG: ------ Window Init (DialogConfirm.xml) ------
20:44:06 T:140461147248768 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
20:44:06 T:140461147248768 ERROR: unable to load:/home/kodi/.kodi/addons/skin.eminence.2-mod-Krypton/16x9/DialogConfirm.xml, Line 0
Failed to open file
20:44:06 T:140461147248768 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
(2016-01-25, 20:58)tdbegley Wrote: [ -> ] (2016-01-25, 19:44)Guilouz Wrote: [ -> ] (2016-01-25, 09:45)kobikite Wrote: [ -> ]How do I turn this option?
In Windows / Open Player Controls
(2016-01-25, 21:51)incubus Wrote: [ -> ]Hi Guilouz,
Failed to open file
Krypton is in progress. I have fixed loading screen in next release.
