2017-01-12, 00:34
(2017-01-11, 18:59)Alanon Wrote: [ -> ][@wise_rice: I've looked into the code, and I remain confused. The way it's set up, it should hide the tile during playback, only it doesn't. The settings in Includes_Furniture include only the contents, not the background itself. The header settings, however, list the proper conditions for visibility. I'd wager that what did the trick was deleting the DialogVolumeBar, since that's what appears when you change the volume anyway. As far as I know, there are no IsDisabled window conditions in Kodi.
As far as the audio flags go, the only line of code I've found commands to display the flag that matches the codec name. If there's nothing displayed but question marks, it means that Kodi didn't find anything among the flags and reverted to its default. I would try to make copies and rename some of the existing aiff flags an see if that helps? I don't really know what other naming convention these files might have? Perhaps they are some special variation of the aiff format that kodi is sensitive to, that need proper representation as a new flag?
I tried again with your fresh Version 1.7 (Very good job, by the way ! The animated Artwork is nice and the Scrollbar is perfect)
Now I only deleted the DialogVolumeBar and left all other files unchanged. This prevents the "volume-Circle" from showing up.
Sadly, it does still show the blue background of the tile. It shows the text "Playing" very quickly and then it fades away together.
Replacing/Changing the Custom_Debug_Overlay did nothing. So we can skip that on our search for the culprit.
Changing the Includes_Furniture file solved the problem. Maybe kodi is in fact accepting IsDisabled window conditions? Or is it something else I have changed?
Here is my file: Includes_Furniture.xml
I noticed a little glitch: When navigating through the movies, It does show the time of the movie again (thanks for that !! This was broken before) but it has a latency (propably due to the online-lookup of the movies standart time?)
Is it possible to move the movie-time icon to the very left? In this way, it does not move all other icons to the left after the search was done and the time is showing up. And it would then also make sense to move the "ending-time" right next to it. To the second position from the very left.
Or is it possible to show the "real" time of the actual file? By checking it on the Storage/NAS? I feel it was like that before...
For the music:
My hi-res music files have a standart .aif ending and are formatted in a normal way (96khz, 24 bit).
There is a aif.png in media>indicator>audio/
But it is not displayed. I don't know why. Only the question-marks
PS: what versions of SkinHelperService and Skin Widgets are you using? Do we need a special github beta-Version?
I get a short message that e.g. the SkinHelperService addons are needed when switching to the skin, even though they are installed (Version 1.0.143 and 0.0.33.) Maybe a normal bug in Kodi or Libreelec when switching skins? It seems to work fine and all necessary addons have a green tick in the skin settings.
