2016-04-21, 12:25
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
2016-04-23, 20:39
I am not sure if this is a skin issue or a kodi issue, so i am sorry if I am posting in the wrong thread.
I notice that when i use a menu shortcut for an addon or library when i press the back button i will got to the previous scfeen till I return to the home screen. When I use the home/esc button i retun immediately to home screen. Which is good. If I open up that same shortcut again it brings me to were I left off instead of that menu shortcut link.
Is there a way that when i return to the home screen that the cache will refresh so if i go back in to the same area it will not return to were I left off??
I am not sure if i worded this probably, but any help would be greatly appreciated.
2016-04-24, 00:09
2016-04-24, 00:13
(2016-04-24, 00:09)Songen Wrote: [ -> ]It says: "Skin shortcuts error" and I have no way to use kodi now. I don't know even how to go to settings to change the skin.
If you need some logos, help me to activate and access them.
Logs are always needed - follow the link here - debug log (wiki) - for details of how to provide a useful one
2016-04-24, 00:50
(2016-04-24, 00:13)BobCratchett Wrote: [ -> ]Thank you :-)(2016-04-24, 00:09)Songen Wrote: [ -> ]It says: "Skin shortcuts error" and I have no way to use kodi now. I don't know even how to go to settings to change the skin.
Done:
http://xbmclogs.com/p3doebn67
2016-04-24, 00:56
There is no Skin Shortcuts error in that log.
There are two scripts showing errors in that log - the service.nextup.notification script, and the script.skin.helper.service - in both cases, the indications are that you've installed git version of the scripts (which, without some work, install the scripts to the wrong directories - they append '-master' to the install directories.)
Either way, if you have an issue with the Skin Shortcuts script - which is my speciality - you need a log which actually shows issues with that script.
2016-04-24, 01:26
(2016-04-24, 00:56)BobCratchett Wrote: [ -> ]There is no Skin Shortcuts error in that log.
SOLVED!!!
It was those two scripts you said, that didn't let work the shortcuts script.
Thank you, man :-) :-) :-)
2016-04-24, 01:31
You're very welcome
2016-04-25, 14:46
I use your theme but I have a small bug. I have choose to have series backgroud when I am to the "Series TV" but when I swith to the "Film" section I have a white screen and after the background arrive.
Have you an idee?
I have made a video:
https://www.youtube.com/watch?v=0Ll5EdFJ...load_owner
Sorry for my English..
Have you an idee?
2016-04-25, 22:39
Bob, does this mean I should not install them from zip, or, must I rename the zips before installing / rename the folders after installing? Do something else?
2016-04-26, 20:58
Just a little question. How to disable the little (médium) panel that popup when i watch tv série. Like informations about next tv show etc.. Where is that option ?
2016-04-26, 22:16
(2016-04-25, 22:39)Sjors125 Wrote: [ -> ]If you uncompress them manually, change the name after that.(2016-04-24, 00:56)BobCratchett Wrote: [ -> ]There is no Skin Shortcuts error in that log.
If you install them using Kodi, not sure if same thing.
2016-04-26, 22:19
(2016-04-25, 14:46)Nico51 Wrote: [ -> ]Hi,You unhappy with the white screen?
Have you an idee?
2016-04-26, 22:46
(2016-04-23, 20:39)EB1980 Wrote: [ -> ]I am not sure if this is a skin issue or a kodi issue, so i am sorry if I am posting in the wrong thread.I'd love to know how to reload the menu items each time as well instead of loading a cached version
Sent from my SM-N910V
2016-04-26, 22:47
(2016-04-26, 20:58)Biofx80 Wrote: [ -> ]Hi,
Biofx80,
If you mean in the middle of an Episode, I think this is a bug in the Next Up TV app as I have started getting this as well & it's very annoying.
