(2016-02-19, 17:26)Bonecrusher Wrote: [ -> ]Hello,
i got a problem with the cdart manger in the awesome skin. How to rename the cd arts that got a symbol in the filename like "?","!",":" Windows don't accept this symbols in filenames... Any idea?
For example Bon Jovi - Greatest Hits: The Collection.
(2016-02-19, 18:38)Guilouz Wrote: [ -> ] (2016-02-19, 17:26)Bonecrusher Wrote: [ -> ]Hello,
Rename your album title.
What Guilouz says.
I only use those special characters in my id3 tags. The file names are without them. That is working fine for me.
I can confirm that with these latest updates all errors that I experienced are fixed!
The skin could benefit from some different views, but aside from that, it's perfect!
Hi Guilouz,
Great update, works like a charm.
Did you intentionally remove the Unwatched indicator? It's not showing for me on movies or TV shows in latest update. I prefered it showing, perhaps there could be an option to show if it's been removed. Also could the indicators be coloured as they are now on the widgets? perhaps an option again for those who prefer the white.
I mentioned it before but is there any chance you can add background fanart to the skinning of the NextAired addon?
Cheers & keep up the great work.
(2016-02-15, 23:36)Trachemys Wrote: [ -> ] (2016-02-15, 23:07)Blurayx Wrote: [ -> ] (2016-02-15, 19:40)Trachemys Wrote: [ -> ]Hi.
I would like to have a widget to see the next aired tv shows but not from all the tv shows, just the tv shows of my library.
Is actually any way to make some widget work to that purpose?
PS: Im blind and this ticks are hard to see for me, it would be awesome if you can add some option to use colours instead of the tick to mark the watched chapters
1) skin settings
2) customise home menu
3) scroll down to Next Aired
4) select widget on the left
5) scroll down one, select default widgets. that's where you will find My TV Shows Airing Today. unfortunetly the widget does not display Season and episode numbers.
http://forum.kodi.tv/showthread.php?tid=...pid2246057
I hope this helps.
A Colour option instead of the tick to mark watched chapters is a great idea
Thanks! Got it, didnt see it.
But as you said, it lacks on information like the day or the number of chapter and I would love to see the upcoming shows on a 15/20 days range and not only today. But well, its a good point to start.
Hi Guilouz,
Excellent work, I like the cycle view.
I know I have asked you before but can you please,please add season & episode numbers on widget for My TV shows Airing today
Thank you
It would be absolutely wonderful if you could add the 'wide' view from Arctic for Episodes and Seasons views
New Update 1.4.3 for Jarvis & 1.2.3 for Krypton :
Add fanarts support for Next Aired addon.
Add season and episode number for Next Aired widget.
(2016-02-20, 04:07)Guilouz Wrote: [ -> ]New Update 1.4.3 for Jarvis & 1.2.3 for Krypton :
Hi Guilouz,
Little things mean a lot
Thank you for adding season and episode number for Next Aired widget
Now this is the best skin without a doubt. I'm so impressed with Eminence 2 MOD 1.4.3, I had to make a donation.
(2016-02-20, 04:14)Guilouz Wrote: [ -> ] (2016-02-20, 03:53)KarmaMole Wrote: [ -> ]It would be absolutely wonderful if you could add the 'wide' view from Arctic for Episodes and Seasons views
This one ?
No, I mean the other one, hold on - I'll screengrab now..
