Please let us know if their premium subscription works on Firestick. Thanks.
Thanks cmik. Youre the man. It works good.
I have the firestick so do you use the downloader to update the addon?
Cmik!!! You are the best!!! Thanks for taking care of our favorite TFC addon.
yes they change again, can't grab it with KSV script if i have to download full episode.
I have two android boxes, one updated automatically to 0.74, but the other one is still on 0.73 even if I choose manual update.
(2018-06-26, 07:52)johnny2000 Wrote: [ -> ]I have two android boxes, one updated automatically to 0.74, but the other one is still on 0.73 even if I choose manual update.
you can try uninstalling 0.73 first and install zip file with 0.74... im sure it will get updated to 0.74
I think that's the only way to upgrade it to 74, but I will wait till tomorrow maybe my box (kodi) will try to read again the xml file and check the repo against the current version installed in the box. Thanks.
It’s working again on my fire tv stick. Thank you cmik. I just hit update on the settings.
Oh gaaaaad!!!! I was going crazy whenever it says subscription was expired something.. Well i don’t have a premium subscription so I only play the free replays but it wasnt even playing WTH!!! Glad there’s this forum! I was able to update and play it on firestick tv!!! Thank you cmik for maintaining it I’m so happy I can watch Showtime now
Cmik,
Thank you for your service to the Filipino people wherever so dispersed.
My Firestick updated automatic and works fine. However, The newer Firetv wont play the videos. I uninstalled it and hope that it will fix my problem after I reinstall your addon again.
Thanks again homeboy.
Even with th 75 upgrade, my Firetv still won't play the videos. The Firestick runs without a problem though.
Thanks again cmik
It works now. I uninstalled it again. Cleared cache. Reinstalled. It worjs.
Just want to let you know, it does not play on my Firetv... no issues with my Firestick thoug.
