2019-09-14, 16:40
@cmik I noticed when I use ReloadSkin command it won't refresh the episodes on the widget unless I open the tfc addon first. It seems to want to log on first before it would update the episodes.
(2019-09-13, 12:04)cmik Wrote: [ -> ]Hi all,Thanks for your hard work and continued support to the filipino community cmik! 🤞
A new version 1.3.4 fixes the issue with shows epidodes that won't display.
The bug appeared after the change in TFC website's show page (number of episodes and episodes).
Thanks in advance for your feedbacks.
(2019-09-14, 22:56)Adrreew Wrote: [ -> ]It’s give me an error of error 400 bad reportHi,
(2019-09-09, 00:47)johnny2000 Wrote: [ -> ]To all,(2019-09-07, 04:17)mha1la0 Wrote: [ -> ](2019-09-06, 18:04)lucid365 Wrote: [ -> ]Hi does anybody know why when you try to play a movie that it always says the type of media is not supported, so no movies can be watched with this addon, it was not a problem for me before because I used to watch the pinoy movies on different addons, but now all pinoy add ons are down and nowhere can anyone find a addon that tagalog movies can we watched on, will their come a time anyone that movies will be able to be watched on cmiks addon? Someone pls answer I made a a recent comment about this but nobody answered!
Thanks cmik for this great addon
Regards paul
Hi CMIK,
I have the same issue, i am getting "this type of media is not supported" when playing Premium movies or IWant Originals. I have my TFC.tv premium subscription. Any chance you can take a look?
Thank you CMIK for maintaining this addon
Mhai Lao  Â
As cmik mentioned from his previous post, those features are not yet supported by the the tfc add-on. Let's just hope that cmik will find the time and solution for those issues.Â
Regards paul
(2019-09-15, 10:00)mha1la0 Wrote: [ -> ](2019-09-06, 18:04)lucid365 Wrote: [ -> ]Hi does anybody know why when you try to play a movie that it always says the type of media is not supported, so no movies can be watched with this addon, it was not a problem for me before because I used to watch the pinoy movies on different addons, but now all pinoy add ons are down and nowhere can anyone find a addon that tagalog movies can we watched on, will their come a time anyone that movies will be able to be watched on cmiks addon? Someone pls answer I made a a recent comment about this but nobody answered!
Regards paul
Hi CMIK,
Mhai Lao
(2019-09-15, 20:35)cmik Wrote: [ -> ]To all,Hi cmik,Â
Version 1.4.0 is out (need Kodi v18+)Â
- now can play AES encrypted medias (previously not supported medias with message "this type of media is not supported")
- override cache for home menu items and my list last episodes and force to refresh every hour.Â
If it is not updating automatically, you can download it from https://repo.cmik.me (<-- add this URL to your files to facilitate your installation)
File : https://repo.cmik.me/tfc.tv/plugin.video...latest.zip
(see "How do I install the TFC.tv addon" : https://forum.kodi.tv/showthread.php?tid...pid2606907)
(2019-09-16, 02:35)prettysick Wrote: [ -> ]Hi @cmik can u pls revisit the addons.xml. Version says 1.4.1 when in fact the latest is 1.4.0.Thanks.
-I tried watching vice ganda directors cut on 1.4.0. The media plays but it freezes a lot.
@340rag try this
https://github.com/cmik/cmik.xbmc/raw/ma...-1.4.0.zip
(2019-09-16, 06:30)cmik Wrote: [ -> ](2019-09-16, 02:35)prettysick Wrote: [ -> ]Hi @cmik can u pls revisit the addons.xml. Version says 1.4.1 when in fact the latest is 1.4.0.Thanks.
@340rag try this
It is normally fixed. Can you check again ?Â
(2019-09-16, 06:36)johnny2000 Wrote: [ -> ]I just tried installing it again through cmik repo and the version it says tfc.tv -------- cmik-1.4.1(2019-09-16, 06:30)cmik Wrote: [ -> ](2019-09-16, 02:35)prettysick Wrote: [ -> ]Hi @cmik can u pls revisit the addons.xml. Version says 1.4.1 when in fact the latest is 1.4.0.Thanks.
@340rag try this
It is normally fixed. Can you check again ?  Â
The update says "cmik 1.4.1". So it is 1.4.1 in the repo not 1.4.0. Â
