Cool, looking forward to when its in the addon!
I consider this a bug. don't you?
I'm using this to try and keep watched statuses synced between xbmc and plex. If I watch a show/movie on one of them do I always need to manually sync the other to pull the watched status from trakt or should it do it automatically?
If we get an advanced rating dialog like Traktr, can i suggest we go with grey hearts versus red for the rating scale instead of overlayed numbers? Because on smaller screens (like my 26 inch TV) the numbers were hard to see from a distance. TIA
2.0 is in the xbmc repository! Big thanks to everyone who contributed code.
huzz456 yes it will sync between both platforms assuming you have the sync settings on for both.
question: how can I start trakt update every time I start xbmc?
I tried the option to start trakt when the library is update, and I enable library update at startup, but unfortunately it does not update all files: old files that were already present in the library are not passed to trakt
I am a bit confused. The add-on isn't working on my new Android-Device either (1.0.1 and 2.0.0). So the problem must be on my side. What exactly should I try in the settings?
Or could it be a problem with my username ("p.h.i"). Any ideas?
Would like to post a log from the android device. But I don't know where to find it.
(2013-02-11, 21:48)rectifyer Wrote: [ -> ]2.0 is in the xbmc repository! Big thanks to everyone who contributed code.
With the advanced rating? Cool ! Will try asap.
No need for traktr anymore then.
(2013-02-12, 16:54)p.h.i Wrote: [ -> ]I am a bit confused. The add-on isn't working on my new Android-Device either (1.0.1 and 2.0.0). So the problem must be on my side. What exactly should I try in the settings?
What are you trying to do? sync libraries?
yelo3 it should just start up on boot if you have the setting on. Once you finish the library updated, trakt will sync everything. You can confirm in the xbmc.log file.
@p.h.i. usename shouldn't matter.
http://wiki.xbmc.org/index.php?title=Log_file
Skank 2.0 doesn't have ratings, but a future update will.
Is it possible for XBMC to sync up with the watched statuses marked on the Trakt.tv website?
Let me give you an example. Lets say I watch an episode of How I Met Your Mother that was just downloaded in HDTV with sickbeard. It gets marked as watched. The next afternoon, sickbeard automatically got the better (Web-DL) version and deleted the old HDTV version that was marked as watched.
Ideally, running a library update and trakt sync the program would recognize that it is the same episode that was already marked as watched (just a different format) and mark it as watched on XBMC.
What really ends up happening is that I get the Web-DL version showing up as recommended episode even though I already saw it in HDTV format.
Any workaround?
The addon does not care about filenames only show season and episode number. If the episode was scrobbled or a library update happened between watching the episode and the new copy being downloaded it should be caught and marked as watched.
(2013-02-12, 19:50)yelo3 Wrote: [ -> ]What are you trying to do? sync libraries?
I activated all the options. Nothing works. Main thing I want to do is scrobble my watched episodes.
Log file is coming tonight. Not at home right now
Hm, I have this folder:
"/Android/data/org.xbmc.xbmc/files" but no "/cache" and so no log-file...
Also got trakt to work on my Windows-PC. Applied the same settings to the android-installation but it does nothing. I'm confused
(2013-02-13, 02:23)rectifyer Wrote: [ -> ]@yelo3 it should just start up on boot if you have the setting on. Once you finish the library updated, trakt will sync everything. You can confirm in the xbmc.log file.
@p.h.i. usename shouldn't matter. http://wiki.xbmc.org/index.php?title=Log_file
@Skank 2.0 doesn't have ratings, but a future update will.
Thx, will wait then and use traktr meanwhile.
