Full Version: [RELEASE] trakt.tv tv/movie scrobbler
This is the only plugin that I really need to use can I update to 13.0 and still have Trakt Plugin working, I've read the last view pages of the thread and I'm unclear. I'd love to hear from someone who has updated to Gotham and still has a working Trakt plugin. thanks.
@warrell if everything is enabled in the sync options, then it should be syncing everything, sync only occurs after a library update (if configured to do so) or by triggering a manual sync. also make sure simulate settings are not enabled in the debug area.
@kevn57 as i just posted a couple posts back I run on gotham now, infact, updating to the final release right now.
@nate1280 thanks very much, I'm going to update now myself.
edit: just finished the update and the plugin works like a charm!
(2014-05-04, 11:00)Marx1 Wrote: [ -> ]From Trakt website?
Yes, trakt.tv -> profile -> library:
The shows marked with a big red X I removed long time ago from my XBMC library, I want to get rid them from my trakt account as well, this is possible?
Trakt website doesn't have such option?
@tinybutstrong there's a sync option to remove shows/movies from library, enable it and it will do this. otherwise, manually delete them from the trakt website, the ability is there.
(2014-05-05, 14:48)nate1280 Wrote: [ -> ]@tinybutstrong there's a sync option to remove shows/movies from library, enable it and it will do this. otherwise, manually delete them from the trakt website, the ability is there.
I enabled that option but it does nothing here. In trakt website, can you guide me to remove them manually? I have not found this option yet.
How about posting a log file then so it can be looked at?
Forgot to mention, the remove option can only remove from your collection, it can't remove scrobbles (this has always been the case). Judging from that picture you posted, thats your played shows which it can't remove. And removing those manually is more involved.
Oh, got it! In trakt website you need to open the History, then delete each episode for the show. Not possible to remove the whole show at once.
My problem is solved. Anyway here (a lot garbage) is a log when I tried the sync yesterday.
Thanks guys.
(2014-05-05, 15:28)tinybutstrong Wrote: [ -> ]Oh, got it! In trakt website you need to open the History, then delete each episode for the show. Not possible to remove the whole show at once.
Thanks guys.
I thought you could hover over show and a option to delete should become visible?
/edit:
Nobody that has an answer on my previous question?
Why shows are manual marked seen instead of scrobbled? Could it have something to do with script.xbmc.unpausejumpback that jumps back a configured time on resume/pause?
@schumi2004 no idea, I can't see it causing an issue, would need a log file. Usually the only time shows are manually marked is during a sync (if enabled) or if using the action available to do so, otherwise it should only scrobble during playback. Would really need a log file to see whats going on.
(2014-05-06, 14:53)nate1280 Wrote: [ -> ]@schumi2004 no idea, I can't see it causing an issue, would need a log file. Usually the only time shows are manually marked is during a sync (if enabled) or if using the action available to do so, otherwise it should only scrobble during playback. Would really need a log file to see whats going on.
I think it's the addon. I'll try to reproduce it with and without addon and see what happens with debug logging enabled.
trakt won't scrobble for me, here is my log:
00:15:36 T:153428  NOTICE: -----------------------------------------------------------------------
00:15:36 T:153428  NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows 7 SP1 32-bit, build 7601. Built on Dec 19 2013 (compiler 1600)
00:15:36 T:153428  NOTICE: AMD Phenom(tm) II X4 940 Processor
00:15:36 T:153428  NOTICE: Desktop Resolution: 1920x1200 32Bit at 59Hz
00:15:36 T:153428  NOTICE: Running with restricted rights
00:15:36 T:153428  NOTICE: Aero is enabled
00:15:36 T:153428  NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
00:15:36 T:153428  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
00:15:36 T:153428  NOTICE: special://masterprofile/ is mapped to: C:\Users\Dor\AppData\Roaming\XBMC\userdata
00:15:36 T:153428  NOTICE: special://home/ is mapped to: C:\Users\Dor\AppData\Roaming\XBMC\
00:15:36 T:153428  NOTICE: special://temp/ is mapped to: C:\Users\Dor\AppData\Roaming\XBMC\cache
00:15:36 T:153428  NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
00:15:36 T:153428  NOTICE: Local hostname: Dor-PC
00:15:36 T:153428  NOTICE: Log File is located: C:\Users\Dor\AppData\Roaming\XBMC\xbmc.log
00:15:37 T:153428  NOTICE: Found 2 Lists of Devices
00:15:37 T:153428  NOTICE: Enumerated DirectSound devices:
00:15:37 T:153428  NOTICE:     Device 1
00:15:37 T:153428  NOTICE:         m_deviceName      : {7C81FC97-5A6E-45D6-A969-A2A0590625DB}
00:15:37 T:153428  NOTICE:         m_displayName     : Speakers - רמקולים (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_displayNameExtra: DirectSound: רמקולים (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
00:15:37 T:153428  NOTICE:         m_channels        : FL,FR
00:15:37 T:153428  NOTICE:         m_sampleRates     : 44100
00:15:37 T:153428  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3
00:15:37 T:153428  NOTICE:     Device 2
00:15:37 T:153428  NOTICE:         m_deviceName      : {901EE6D9-DCE5-4E42-B895-AA47789FC67C}
00:15:37 T:153428  NOTICE:         m_displayName     : SPDIF - שמע דיגיטלי (S/PDIF) (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_displayNameExtra: DirectSound: שמע דיגיטלי (S/PDIF) (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
00:15:37 T:153428  NOTICE: Enumerated WASAPI devices:
00:15:37 T:153428  NOTICE:         m_displayNameExtra: WASAPI: רמקולים (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_channels        : FL,FR,FC,LFE,SL,SR,BL,BR
00:15:37 T:153428  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
00:15:37 T:153428  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
00:15:37 T:153428  NOTICE:         m_displayNameExtra: WASAPI: שמע דיגיטלי (S/PDIF) (התקן High Definition Audio)
00:15:37 T:153428  NOTICE:         m_sampleRates     : 192000,96000,88200,48000,44100
00:15:37 T:153428  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
00:15:37 T:153428  NOTICE: load settings...
00:15:37 T:153428  NOTICE: special://profile/ is mapped to: special://masterprofile/
00:15:37 T:153428  NOTICE: loading special://masterprofile/guisettings.xml
00:15:37 T:153428  NOTICE: Getting hardware information now...
00:15:37 T:153428  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:15:37 T:153428  NOTICE: Loaded playercorefactory configuration
00:15:37 T:153428  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
00:15:37 T:153428  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:15:37 T:153428  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
00:15:37 T:153428  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
00:15:37 T:153428  NOTICE: Default DVD Player: dvdplayer
00:15:37 T:153428  NOTICE: Default Video Player: dvdplayer
00:15:37 T:153428  NOTICE: Default Audio Player: paplayer
00:15:37 T:153428  NOTICE: Disabled debug logging due to GUI setting. Level 0.
00:15:37 T:153428  NOTICE: Log level changed to 0
00:15:37 T:153428  NOTICE: Loading media sources from special://masterprofile/sources.xml
00:15:37 T:153464  NOTICE: Thread CSoftAE start, auto delete: false
00:15:37 T:153428  NOTICE: Running database version Addons15
00:15:37 T:153208  NOTICE: Thread XBMC Peripherals start, auto delete: false
00:15:37 T:152276  NOTICE: Previous line repeats 1 times.
00:15:37 T:152276  NOTICE: Thread CRemoteControl start, auto delete: false
00:15:53 T:153568  NOTICE: Thread Jobworker start, auto delete: true
00:15:53 T:153428  NOTICE: Found screen: Generic PnP Monitor on ATI Radeon HD 4800 Series , adapter 0.
00:15:53 T:153428  NOTICE: Primary mode: 1920x1200 @ 59.94 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Previous line repeats 2 times.
00:15:53 T:153428  NOTICE: Additional mode: 800x600 @ 56.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 848x480 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x900 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1360x1024 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1920x1200 @ 59.94 - Full Screen
00:15:53 T:153428  NOTICE: Additional mode: 1920x1200 @ 60.00 - Full Screen
00:15:53 T:153428  NOTICE: Checking resolution 16
00:15:55 T:153428  NOTICE: Running database version Addons15
00:15:55 T:153428  NOTICE: Running database version ViewModes4
00:15:55 T:153428  NOTICE: Running database version Textures13
00:15:55 T:153428  NOTICE: Running database version MyMusic32
00:15:55 T:153428  NOTICE: Running database version MyVideos75
00:15:55 T:153428  NOTICE: Running database version TV22
00:15:55 T:153428  NOTICE: Running database version Epg7
00:15:55 T:153428  NOTICE: initializing playlistplayer
00:15:55 T:153428  NOTICE: DONE initializing playlistplayer
00:15:57 T:153432  NOTICE: Thread XBPyThread start, auto delete: false
00:15:57 T:151944  NOTICE: Previous line repeats 5 times.
00:15:57 T:151944  NOTICE: Thread Jobworker start, auto delete: true
00:15:57 T:153428  NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
00:15:57 T:153160  NOTICE: Thread CVideoInfoScanner start, auto delete: false
00:15:57 T:152312  NOTICE: Thread XBPyThread start, auto delete: false
00:15:57 T:153428  NOTICE: Previous line repeats 1 times.
00:15:57 T:153428  NOTICE: initialize done
00:15:57 T:152596  NOTICE: Thread XBPyThread start, auto delete: false
00:15:57 T:153160  NOTICE: Previous line repeats 2 times.
00:15:57 T:153160  NOTICE: VideoInfoScanner: Starting scan ..
00:15:57 T:153432  NOTICE: -->Python Interpreter Initialized<--
00:15:58 T:153428  NOTICE: Running the application...
00:15:58 T:153160 WARNING: No information found for item 'D:\Downloads\South Park Season 01-16 (05-16 720p WEB-DL)\', it won't be added to the library.
00:15:58 T:152460  NOTICE: Thread Jobworker start, auto delete: true
00:15:59 T:153160  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:01
00:15:59 T:153428  NOTICE: Webserver: Starting...
00:15:59 T:153428   ERROR: WebServer: Failed to start the webserver
00:15:59 T:153428  NOTICE: starting upnp server
00:15:59 T:153428  NOTICE: starting upnp renderer
00:15:59 T:153428  NOTICE: ES: Starting event server
00:15:59 T:152684  NOTICE: Thread CEventServer start, auto delete: false
00:15:59 T:152684  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
00:15:59 T:152684  NOTICE: UDP: Listening on port 9777
00:15:59 T:153012  NOTICE: Thread CTCPServer start, auto delete: false
00:15:59 T:151944  NOTICE: EPG::CEpgContainer::Start - EPG thread started
00:15:59 T:151944  NOTICE: PVRManager - starting up
00:15:59 T:151768  NOTICE: Thread EPG updater start, auto delete: false
00:15:59 T:152048  NOTICE: Thread PVR manager start, auto delete: false
00:15:59 T:153536  NOTICE: Thread PVR add-on updater start, auto delete: false
00:15:59 T:151580  NOTICE: Thread CRssReader start, auto delete: false
00:15:59 T:153028  NOTICE: Thread CFileCache start, auto delete: false
00:16:00 T:153536  NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 135 channels.
00:16:00 T:153372  NOTICE: Thread PVR GUI info updater start, auto delete: false
00:16:03 T:153804  NOTICE: Thread CFileCache start, auto delete: false
00:16:05 T:153432  NOTICE: Previous line repeats 4 times.
00:16:05 T:153432  NOTICE: ****** TV GUIDE DIXIE INFORMATION ******
00:16:05 T:153432  NOTICE: *************** LOGO PACK **************
00:16:05 T:153432  NOTICE: C:\Users\Dor\AppData\Roaming\XBMC\userdata\addon_data\script.tvguidedixie.o2ri\extras\logos\
00:16:05 T:153868  NOTICE: Thread CFileCache start, auto delete: false
00:16:05 T:152900  NOTICE: -->Python Interpreter Initialized<--
00:16:05 T:144544  NOTICE: -->Python Interpreter Initialized<--
00:16:05 T:153168  NOTICE: -->Python Interpreter Initialized<--
00:16:05 T:153124  NOTICE: -->Python Interpreter Initialized<--
00:16:05 T:151976  NOTICE: -->Python Interpreter Initialized<--
00:16:05 T:151612  NOTICE: -->Python Interpreter Initialized<--
00:16:06 T:152312  NOTICE: -->Python Interpreter Initialized<--
00:16:06 T:152596  NOTICE: -->Python Interpreter Initialized<--
00:16:06 T:153512  NOTICE: -->Python Interpreter Initialized<--
00:16:06 T:153332  NOTICE: -->Python Interpreter Initialized<--
00:16:07 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
00:16:07 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: Reconnect, (re)try 1
00:16:07 T:152460   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:16:07 T:152460   ERROR: XFILE::CFileCache::Open - failed to open source <http://bitbucket.org/mash2k3/mash2k3-repository/raw/master/addons.xml.md5>
00:16:08 T:153168  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.10)
00:16:08 T:153168  NOTICE: script.tv.show.next.aired: ### no prior data found
00:16:08 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
00:16:08 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: Reconnect, (re)try 1
00:16:09 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
00:16:09 T:152460   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:16:09 T:152460   ERROR: Repository All Addons by Mash2k3 returned no add-ons, listing may have failed
00:16:10 T:153912  NOTICE: Thread Background Loader start, auto delete: false
00:16:10 T:153920  NOTICE: Previous line repeats 1 times.
00:16:10 T:153920  NOTICE: Thread Jobworker start, auto delete: true
00:16:10 T:152900  NOTICE: [trakt] Loading 'script.trakt' version '2.3.1'
00:16:10 T:152900  NOTICE: [trakt] Service thread starting.
00:16:10 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
00:16:10 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: Reconnect, (re)try 1
00:16:10 T:153168  NOTICE: script.tv.show.next.aired: ### starting data update
00:16:11 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
00:16:11 T:152460   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:16:11 T:152460   ERROR: XFILE::CFileCache::Open - failed to open source <http://whufclee.googlecode.com/svn/repo/addons.xml.md5>
00:16:11 T:152900  NOTICE: [trakt] [traktPlayer] Initalized.
00:16:11 T:152900  NOTICE: [trakt] [traktMonitor] Initalized.
00:16:11 T:152900  NOTICE: [trakt] [traktAPI] Initializing.
00:16:11 T:152460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: Reconnect, (re)try 1
00:16:11 T:153924  NOTICE: Thread XBPyThread start, auto delete: false
00:16:11 T:152900  NOTICE: [trakt] Queued dispatch: {u'action': u'loadsettings'}
00:16:11 T:152900  NOTICE: [trakt] Dispatch: {u'action': u'loadsettings'}
00:16:11 T:152900  NOTICE: [trakt] [traktAPI] Loaded cached account settings for 'dor272'.
00:16:11 T:152460   ERROR: Repository whufclee Addon Repository returned no add-ons, listing may have failed
00:16:12 T:153932  NOTICE: Thread CFileCache start, auto delete: false
00:16:15 T:151612  NOTICE: Previous line repeats 1 times.
00:16:15 T:151612  NOTICE:  StorageServer Module loaded RUN
00:16:15 T:151612  NOTICE: StorageClient-2.5.4 Starting server
00:16:15 T:151612  NOTICE: StorageServer-2.5.4 Storage Server starting C:\Users\Dor\AppData\Roaming\XBMC\cache\commoncache.db
00:16:15 T:154080  NOTICE: Thread CFileCache start, auto delete: false
00:16:15 T:152596  NOTICE: PrimeWire: Service: MySQL not enabled or not setup correctly
00:16:16 T:154088  NOTICE: Thread CFileCache start, auto delete: false
00:16:16 T:152460   ERROR: Repository TheWiz Hebrew Add-Ons returned no add-ons, listing may have failed
00:16:18 T:152596  NOTICE: PrimeWire: Service: Loading sqlite3 as DB engine
00:16:18 T:152596  NOTICE: PrimeWire: Service: Resetting...
00:16:18 T:154112  NOTICE: Thread CFileCache start, auto delete: false
00:16:18 T:152596  NOTICE: PrimeWire: Service starting...
00:16:19 T:154128  NOTICE: Thread CFileCache start, auto delete: false
00:16:20 T:153512  NOTICE: Previous line repeats 1 times.
00:16:20 T:153512  NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.12.1
00:16:20 T:153512  NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup Start
00:16:20 T:153512  NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-04-19'
00:16:21 T:153512  NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup End
00:16:21 T:153332  NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.12.1
00:16:21 T:153332  NOTICE: Watch History Module and Service: Auto Cleanup - Start
00:16:21 T:153924  NOTICE: -->Python Interpreter Initialized<--
00:16:21 T:153332  NOTICE: Previous line repeats 1 times.
00:16:21 T:153332  NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-04-19'
00:16:21 T:153332  NOTICE: Watch History Module and Service: Auto Cleanup - End
00:16:23 T:153924  NOTICE: [trakt] Queuing for dispatch: {'action': 'managelists'}
00:16:24 T:152900  NOTICE: [trakt] Queued dispatch: {u'action': u'managelists'}
00:16:24 T:152900  NOTICE: [trakt] Dispatch: {u'action': u'managelists'}
00:16:24 T:152900  NOTICE: [trakt] [Tagger] Starting to manage lists.
00:16:24 T:152900  NOTICE: [trakt] [Tagger] Getting 'movies' from XBMC.
00:16:24 T:152900  NOTICE: [trakt] [Tagger] Key 'movies' not found.
00:16:24 T:152900  NOTICE: [trakt] [Tagger] Problem loading XBMC data, aborting.
00:16:36 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
00:16:45 T:152900  NOTICE: [trakt] Queuing for dispatch: {'action': 'settingsChanged'}
00:16:45 T:154388  NOTICE: Thread Jobworker start, auto delete: true
00:16:45 T:154396  NOTICE: Thread Background Loader start, auto delete: false
00:16:45 T:152900  NOTICE: Previous line repeats 1 times.
00:16:45 T:152900  NOTICE: [trakt] Queued dispatch: {u'action': u'settingsChanged'}
00:16:45 T:152900  NOTICE: [trakt] Dispatch: {u'action': u'settingsChanged'}
00:16:45 T:152900  NOTICE: [trakt] Settings changed, reloading.
00:17:43 T:155028  NOTICE: Thread Background Loader start, auto delete: false
00:18:39 T:155532  NOTICE: Previous line repeats 1 times.
00:18:39 T:155532  NOTICE: Thread Jobworker start, auto delete: true
00:18:43 T:155600  NOTICE: Previous line repeats 3 times.
00:18:43 T:155600  NOTICE: Thread XBPyThread start, auto delete: false
00:18:44 T:155600  NOTICE: -->Python Interpreter Initialized<--
00:18:46 T:155632  NOTICE: Thread Background Loader start, auto delete: false
00:18:59 T:153888  NOTICE: Previous line repeats 1 times.
00:18:59 T:153888  NOTICE: Thread XBPyThread start, auto delete: false
00:18:59 T:153888  NOTICE: -->Python Interpreter Initialized<--
00:19:00 T:153888  NOTICE: CommonFunctions-2.5.1
00:19:01 T:153888  NOTICE: metahandler: Initializing MetaHandlers version: 2.4.0
00:19:01 T:153888  NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.7.12.1
00:19:02 T:153904  NOTICE: Previous line repeats 1 times.
00:19:02 T:153904  NOTICE: Thread Background Loader start, auto delete: false
00:21:09 T:153168  NOTICE: script.tv.show.next.aired: ### no prior data found
00:21:11 T:153168  NOTICE: script.tv.show.next.aired: ### starting data update
00:21:37 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
00:24:57 T:155284  NOTICE: Thread Jobworker start, auto delete: true
00:25:04 T:154024  NOTICE: Previous line repeats 3 times.
00:25:04 T:154024  NOTICE: Thread XBPyThread start, auto delete: false
00:25:05 T:154024  NOTICE: -->Python Interpreter Initialized<--
00:25:08 T:154024  NOTICE: CommonFunctions-2.5.1
00:25:09 T:154024  NOTICE: metahandler: Initializing MetaHandlers version: 2.4.0
00:25:09 T:154024  NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.7.12.1
00:25:32 T:154400  NOTICE: Previous line repeats 1 times.
00:25:32 T:154400  NOTICE: Thread Background Loader start, auto delete: false
00:25:40 T:146332  NOTICE: Previous line repeats 2 times.
00:25:40 T:146332  NOTICE: Thread XBPyThread start, auto delete: false
00:25:41 T:146332  NOTICE: -->Python Interpreter Initialized<--
00:25:43 T:146332  NOTICE: Sdarot Domain=http://www.sdarot.tv
00:25:43 T:146332  NOTICE: common domain=http://www.sdarot.tv
00:25:43 T:146332  NOTICE: common domain=www.sdarot.tv
00:25:43 T:146332  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
00:25:43 T:146332  NOTICE: params:
00:25:43 T:146332  NOTICE: []
00:25:43 T:146332  NOTICE: check if logged in already
00:25:43 T:146332  NOTICE: getData: Attempt 1
00:25:43 T:146332  NOTICE: getData: url --> http://www.sdarot.tv
                                            postData-->None
00:25:44 T:146332  NOTICE: received gzip len 21117
00:25:44 T:146332  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=c9hudj3l35prj8s5se358mjgu4 for .sdarot.tv/>]>
00:25:44 T:146332  NOTICE: login required
00:25:44 T:146332  NOTICE: Trying to login to sdarot tv site username:TheBenjamin
00:25:44 T:146332  NOTICE: getData: Attempt 1
00:25:44 T:146332  NOTICE: getData: url --> http://www.sdarot.tv/login
                                            postData-->username=*******&password=*****&submit_login=התחבר
00:25:45 T:146332  NOTICE: received gzip len 21226
00:25:45 T:146332  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
00:25:45 T:153808  NOTICE: Thread Background Loader start, auto delete: false
00:25:46 T:154136  NOTICE: Thread XBPyThread start, auto delete: false
00:25:47 T:154136  NOTICE: -->Python Interpreter Initialized<--
00:25:49 T:154136  NOTICE: Sdarot Domain=http://www.sdarot.tv
00:25:49 T:154136  NOTICE: common domain=http://www.sdarot.tv
00:25:49 T:154136  NOTICE: common domain=www.sdarot.tv
00:25:49 T:154136  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
00:25:49 T:154136  NOTICE: params:
00:25:49 T:154136  NOTICE: {'url': 'all-eng', 'mode': '2', 'name': '%d7%94%d7%9b%d7%9c%20a-z'}
00:25:49 T:154136  NOTICE: getData: Attempt 1
00:25:49 T:154136  NOTICE: getData: url --> http://www.sdarot.tv/series
                                            postData-->None
00:25:49 T:154136  NOTICE: received gzip len 705353
00:25:49 T:154136  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
00:25:50 T:154784  NOTICE: Thread Background Loader start, auto delete: false
00:25:55 T:154812  NOTICE: Previous line repeats 1 times.
00:25:55 T:154812  NOTICE: Thread XBPyThread start, auto delete: false
00:25:56 T:154812  NOTICE: -->Python Interpreter Initialized<--
00:25:58 T:154812  NOTICE: Sdarot Domain=http://www.sdarot.tv
00:25:58 T:154812  NOTICE: common domain=http://www.sdarot.tv
00:25:58 T:154812  NOTICE: common domain=www.sdarot.tv
00:25:58 T:154812  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
00:25:58 T:154812  NOTICE: params:
00:25:58 T:154812  NOTICE: {'name': '24', 'url': 'http%3a%2f%2fwww.sdarot.tv%2fwatch%2f61%2f24-24', 'image': 'http%3a%2f%2fwww.sdarot.tv%2fmedia%2fseries%2f61.jpg', 'series_name': '24-24', 'series_id': '61', 'mode': '3'}
00:25:58 T:154812  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
00:25:59 T:154476  NOTICE: Thread Background Loader start, auto delete: false
00:26:24 T:154972  NOTICE: Previous line repeats 1 times.
00:26:24 T:154972  NOTICE: Thread XBPyThread start, auto delete: false
00:26:24 T:154972  NOTICE: -->Python Interpreter Initialized<--
00:26:27 T:154972  NOTICE: Sdarot Domain=http://www.sdarot.tv
00:26:27 T:154972  NOTICE: common domain=http://www.sdarot.tv
00:26:27 T:154972  NOTICE: common domain=www.sdarot.tv
00:26:27 T:154972  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
00:26:27 T:154972  NOTICE: params:
00:26:27 T:154972  NOTICE: {'series_id': '61', 'name': '%d7%a2%d7%95%d7%a0%d7%94%201', 'url': 'http%3a%2f%2fwww.sdarot.tv%2fwatch%2f61%2f24-24', 'image': 'http%3a%2f%2fwww.sdarot.tv%2fmedia%2fseries%2f61.jpg', 'series_name': '61', 'season_id': '1', 'mode': '5'}
00:26:27 T:154972  NOTICE: getData: Attempt 1
00:26:27 T:154972  NOTICE: getData: url --> http://www.sdarot.tv/ajax/watch
                                            postData-->episodeList=true&serie=61&season=1
00:26:28 T:154972  NOTICE: received gzip len 1264
00:26:28 T:154972  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
00:26:28 T:154972  NOTICE: [{u'double': u'0', u'episode': u'1', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'2', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'3', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'4', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'5', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'6', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'7', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'8', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'9', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'10', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'11', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'12', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'13', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'14', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'15', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'16', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'17', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'18', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'19', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'20', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'21', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'22', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'23', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'24', u'hd': u'0', u'watched': u'0'}]
00:26:28 T:154960  NOTICE: Thread Background Loader start, auto delete: false
00:26:42 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
00:28:06 T:151788  NOTICE: Thread Jobworker start, auto delete: true
00:28:07 T:151956  NOTICE: Thread XBPyThread start, auto delete: false
00:28:07 T:151956  NOTICE: -->Python Interpreter Initialized<--
00:28:09 T:151956  NOTICE: Sdarot Domain=http://www.sdarot.tv
00:28:09 T:151956  NOTICE: common domain=http://www.sdarot.tv
00:28:09 T:151956  NOTICE: common domain=www.sdarot.tv
00:28:09 T:151956  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
00:28:09 T:151956  NOTICE: params:
00:28:09 T:151956  NOTICE: {'series_id': '61', 'name': '\xd7\xa4\xd7\xa8\xd7\xa7 9', 'url': 'http%3A%2F%2Fwww.sdarot.tv%2Fwatch%2F61%2F24-24', 'image': 'http%3A//www.sdarot.tv/media/series/61.jpg', 'series_name': '61', 'episode_id': '9', 'season_id': '1', 'mode': '4'}
00:28:09 T:151956  NOTICE: getData: Attempt 1
00:28:09 T:151956  NOTICE: getData: url --> http://www.sdarot.tv/ajax/watch
                                            postData-->watch=true&serie=61&season=1&episode=9
00:28:12 T:151956  NOTICE: received gzip len 336
00:28:12 T:151956  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
00:28:12 T:151956  NOTICE: Sdarot processing JSON:{"VID":"3500","heb":"08:00-09:00","eng":"08:00-09:00","description":"\u05d0\u05d9\u05df \u05ea\u05e7\u05e6\u05d9\u05e8 \u05d6\u05de\u05d9\u05df","duration":"2536.68","addtime":"0","viewnumber":"28800","ratedby":"12","rate":"4.5","viewed":"0","hd":false,"url":"media5.sdarot.tv","watch":{"sd":"aoUPbw9bVNV2baqmUImCLw"},"time":1399594713}
00:28:12 T:151956  NOTICE: vid_url: media5.sdarot.tv
00:28:12 T:151956  NOTICE: VID: 3500
00:28:12 T:151956  NOTICE: Time: 1399594713
00:28:12 T:151956  NOTICE: Token: aoUPbw9bVNV2baqmUImCLw
00:28:12 T:151956  NOTICE: finalUrlhttp://media5.sdarot.tv/watch/sd/3500.mp4?token=aoUPbw9bVNV2baqmUImCLw&time=1399594713
00:28:12 T:153428  NOTICE: DVDPlayer: Opening: http://media5.sdarot.tv/watch/sd/3500.mp4?token=aoUPbw9bVNV2baqmUImCLw&time=1399594713
00:28:12 T:153428 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
00:28:12 T:155316  NOTICE: Thread CDVDPlayer start, auto delete: false
00:28:12 T:155316  NOTICE: Creating InputStream
00:28:13 T:155316  NOTICE: Creating Demuxer
00:28:13 T:151568  NOTICE: Thread CFileCache start, auto delete: false
00:28:14 T:155316  NOTICE: Opening video stream: 0 source: 256
00:28:14 T:155316  NOTICE: Creating video codec with codec id: 28
00:28:15 T:155316  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
00:28:15 T:155316  NOTICE: Creating video thread
00:28:15 T:155316  NOTICE: Opening audio stream: 1 source: 256
00:28:15 T:155316  NOTICE: Finding audio codec for: 86018
00:28:15 T:155368  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
00:28:15 T:155368  NOTICE: running thread: video_thread
00:28:15 T:155316  NOTICE: Creating audio thread
00:28:15 T:155396  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
00:28:15 T:155396  NOTICE: running thread: CDVDPlayerAudio::Process()
00:28:15 T:155396  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
00:28:15 T:152596  NOTICE: PrimeWire: Service: Playback started
00:28:15 T:155368  NOTICE:  fps: 25.000000, pwidth: 630, pheight: 348, dwidth: 628, dheight: 348
00:28:15 T:155368  NOTICE: Display resolution DESKTOP : 1920x1200 @ 59.94 - Full Screen (16)
00:28:15 T:155368  NOTICE: D3D: rendering method forced to DXVA2 processor
00:28:16 T:152900  NOTICE: [trakt] [traktPlayer] onPlayBackStarted() - {u'item': {u'type': u'unknown', u'label': u'61\u05e2\u05d5\u05e0\u05d4 1 \u05e4\u05e8\u05e79'}}
00:28:16 T:152900  NOTICE: [trakt] checkScrobblingExclusion(): Checking exclusion settings for 'http://media5.sdarot.tv/watch/sd/3500.mp4?token=aoUPbw9bVNV2baqmUImCLw&time=1399594713'.
00:28:16 T:152900  NOTICE: [trakt] [traktPlayer] onPlayBackStarted() - Started playing a non-library file, checking available data.
00:28:16 T:152900  NOTICE: [trakt] [traktPlayer] onPlayBackStarted() - Non-library file, not enough data for scrobbling, skipping.
00:31:09 T:153168  NOTICE: script.tv.show.next.aired: ### no prior data found
00:31:11 T:153168  NOTICE: script.tv.show.next.aired: ### starting data update
00:31:45 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
00:32:38 T:155396 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
00:36:04 T:151568 WARNING: Previous line repeats 69 times.
00:36:04 T:151568 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 18
00:36:04 T:151568 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: Reconnect, (re)try 1
00:36:46 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
00:46:09 T:153168  NOTICE: Previous line repeats 1 times.
00:46:09 T:153168  NOTICE: script.tv.show.next.aired: ### no prior data found
00:46:11 T:153168  NOTICE: script.tv.show.next.aired: ### starting data update
00:46:49 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
01:06:09 T:153168  NOTICE: Previous line repeats 3 times.
01:06:09 T:153168  NOTICE: script.tv.show.next.aired: ### no prior data found
01:06:11 T:153168  NOTICE: script.tv.show.next.aired: ### starting data update
01:06:54 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
01:13:20 T:155396  NOTICE: Previous line repeats 1 times.
01:13:20 T:155396 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
01:13:21 T:155368 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
01:13:21 T:155316  NOTICE: CDVDPlayer::OnExit()
01:13:21 T:155316  NOTICE: DVDPlayer: eof, waiting for queues to empty
01:13:21 T:155316  NOTICE: DVDPlayer: closing audio stream
01:13:21 T:155316  NOTICE: Closing audio stream
01:13:21 T:155316  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
01:13:21 T:155316  NOTICE: Waiting for audio thread to exit
01:13:21 T:155396  NOTICE: thread end: CDVDPlayerAudio::OnExit()
01:13:21 T:155316  NOTICE: Closing audio device
01:13:21 T:155316  NOTICE: Deleting audio codec
01:13:21 T:155316  NOTICE: DVDPlayer: closing video stream
01:13:21 T:155316  NOTICE: Closing video stream
01:13:21 T:155316  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
01:13:21 T:155316  NOTICE: waiting for video thread to exit
01:13:21 T:155368   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
01:13:21 T:155368  NOTICE: thread end: video_thread
01:13:21 T:155316  NOTICE: deleting video codec
01:13:21 T:155316  NOTICE: CDVDPlayer::OnExit() deleting demuxer
01:13:21 T:155316  NOTICE: CDVDPlayer::OnExit() deleting input stream
01:13:21 T:152596  NOTICE: PrimeWire: Playback completed
01:13:21 T:152596  NOTICE: PrimeWire: Playback Stopped
01:13:21 T:152596  NOTICE: PrimeWire: Service: Resetting...
01:13:21 T:155488  NOTICE: Thread XBPyThread start, auto delete: false
01:13:21 T:153428  NOTICE: CDVDPlayer::CloseFile()
01:13:21 T:153428 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:13:21 T:153428  NOTICE: DVDPlayer: waiting for threads to exit
01:13:21 T:153428  NOTICE: DVDPlayer: finished waiting
01:13:21 T:153428   ERROR: Control 50 in window 10025 has been asked to focus, but it can't
01:13:22 T:152804  NOTICE: Thread Jobworker start, auto delete: true
01:13:22 T:155488  NOTICE: -->Python Interpreter Initialized<--
01:13:24 T:155488  NOTICE: Sdarot Domain=http://www.sdarot.tv
01:13:24 T:155488  NOTICE: common domain=http://www.sdarot.tv
01:13:24 T:155488  NOTICE: common domain=www.sdarot.tv
01:13:24 T:155488  NOTICE: Loading cookies from :'C:\\Users\\Dor\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.sdarot.tv\\sdarot-cookiejar.txt'
01:13:24 T:155488  NOTICE: params:
01:13:24 T:155488  NOTICE: {'series_id': '61', 'name': '%d7%a2%d7%95%d7%a0%d7%94%201', 'url': 'http%3a%2f%2fwww.sdarot.tv%2fwatch%2f61%2f24-24', 'image': 'http%3a%2f%2fwww.sdarot.tv%2fmedia%2fseries%2f61.jpg', 'series_name': '61', 'season_id': '1', 'mode': '5'}
01:13:24 T:155488  NOTICE: getData: Attempt 1
01:13:24 T:155488  NOTICE: getData: url --> http://www.sdarot.tv/ajax/watch
01:13:24 T:155488  NOTICE: received gzip len 1264
01:13:24 T:155488  NOTICE: <_LWPCookieJar.LWPCookieJar[<Cookie Sdarot=8mva03j3lt8huitoct1abcj4j5 for .sdarot.tv/>]>
01:13:24 T:155488  NOTICE: [{u'double': u'0', u'episode': u'1', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'2', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'3', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'4', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'5', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'6', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'7', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'8', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'9', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'10', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'11', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'12', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'13', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'14', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'15', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'16', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'17', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'18', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'19', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'20', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'21', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'22', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'23', u'hd': u'0', u'watched': u'0'}, {u'double': u'0', u'episode': u'24', u'hd': u'0', u'watched': u'0'}]
01:13:24 T:155480  NOTICE: Thread Background Loader start, auto delete: false
01:13:24 T:154628  NOTICE: Thread Jobworker start, auto delete: true
01:15:18 T:151912  NOTICE: Previous line repeats 1 times.
01:15:18 T:151912  NOTICE: Thread CRssReader start, auto delete: false
01:16:57 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
01:18:06 T:151992  NOTICE: Thread Jobworker start, auto delete: true
01:18:27 T:153428   ERROR: Control 18 in window 10129 has been asked to focus, but it can't
01:19:14 T:153160  NOTICE: Thread Jobworker start, auto delete: true
01:19:14 T:153160   ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\Dor\AppData\Roaming\XBMC\xbmc.log
01:19:14 T:153160   ERROR: XFILE::CFile::Delete - Error deleting file special://logpath/xbmc.log
01:19:16 T:153428   ERROR: Unhandled exception in CApplication::Process() : Access violation at 0x772677a2: Writing location 0x00c2adac
01:21:45 T:153276  NOTICE: Thread Jobworker start, auto delete: true
01:21:47 T:154896  NOTICE: Thread Background Loader start, auto delete: false
01:21:53 T:154724  NOTICE: Previous line repeats 1 times.
01:21:53 T:154724  NOTICE: Thread Jobworker start, auto delete: true
01:21:58 T:155328  NOTICE: Thread CFileCache start, auto delete: false
01:21:59 T:151768  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
01:22:01 T:154492  NOTICE: Thread Background Loader start, auto delete: false
01:22:04 T:154496  NOTICE: Previous line repeats 3 times.
01:22:04 T:154496  NOTICE: Thread Jobworker start, auto delete: true
01:22:06 T:154948  NOTICE: Thread XBPyThread start, auto delete: false
01:22:07 T:154948  NOTICE: -->Python Interpreter Initialized<--
01:22:21 T:154948  NOTICE: XBMC Log Uploader: started
01:22:21 T:154948  NOTICE: XBMC Log Uploader: settings: len(email)=16
01:22:21 T:154948  NOTICE: XBMC Log Uploader: settings: skip_oldlog=True
01:22:22 T:154948  NOTICE: XBMC Log Uploader: reading log...
You're trying to play a video from some web service script by the looks of it, and it doesn't provide enough information to scrobble anything.
I checked it now with a movie and it worked.
how can I make it work on TV shows? its like won't recognize the show.
