Full Version: [Archive] Arctic
THIS THREAD IS CLOSED - IT RELATES TO THE OLD VERSION OF ARCTIC - THERE IS NO SUPPORT FOR THIS VERSION - THIS THREAD IS RETAINED HERE FOR ARCHIVE PURPOSES
This skin originally started as a mod to bring an Alaska spin to Black's amazing xperience1080 skin. It has since evolved into a beast of its own. So I present 'Arctic mk.II'
watch gallery
Translations now on transifex
If you want to help with translations, the skin is now on transifex.
Here: https://www.transifex.com/projects/p/xbm...kin-artic/
Features
  • Two homescreen styles -- panel and simple
  • Multiple colour themes -- default, carbon ocean, dark, and cover fade.
  • Support for extrafanart, tv next aired, metadata actors, extendedinfo, cd art and much much more
  • Multiple view types and many skin customisation options
  • Lots of other goodies that I forgot...
Requirements
Optional Extras
Github
https://github.com/jurialmunkey/skin.arctic
Todo List
  • Font options for larger sizes and non-latin characters
  • Some RCB screens
  • PseudoTV/PseudoTV Live skin support
  • Global Search support
  • Extrathumbs support
  • Info-wall style view for pictures.
  • Music-video support
  • Music Files views
  • Additional views for files and genres
  • Plexbmc support
  • Genre fanart
Black for xperience1080 which served as the base to this skin
Additional icon credits go to Piers and Saste for their icon packs for xperience1080.
Hitcher and djh_ for the Alaska skin which served as inspiration.
All the Aeon Nox team from where I used a few icons.
All the xbmc team and addon developers.
Anyone I forgot, let me know and I'll add you here.
Great work jurial. Congratulations again
Thanks Smile
Textures.xbt for latest GIT.
Delete all files in skin/media and put the Textures.xbt in it.
Skin should be much smoother now, especially on systems with low performance like RPi and Atom.
jurial when I am git pulling it says:
error: Your local changes to the following files would be overwritten by merge:
addon.xml
Please, commit your changes or stash them before you can merge.
Aborting
I already made a new addon.xml but still saying that. I am just ignoring it. Just wanted to mention it.
Great work mate, and glad to see it moving forward as its own skin. Thanks for sharing all your hard work with us.
Awesome Work mate this is truly a great skin. Thank you for sharing your time and effort.
Glad to see you have your own thread now Jurial. Well deserved for a fantastic skin.
(2013-08-10, 12:00)Azake Wrote: [ -> ]jurial when I am git pulling it says:
addon.xml
Aborting
Yeah, that's a git error -- nothing to do with me. Basically its because you changed a file and then I have updated that file so doing a pull would overwrite your changes - so git aborts rather than downloading changes and messing everything up. You need to stash your changes then pull in the latest.
git stash
git pull
and this will clear out the stashed changes (basically 'stash' tells git to keep a copy of your previous changes in case you wanted to revert back to them).
git stash clear
Thanks jurial. I am learning here so much Smile Thanks Smile
Just wanted to drop in and say thanks!
Love this skin, only discovered it last week and it is already my daily drive Smile!
I especially like the dark theme. Just awesome!
Looks cool!
i tried to pull from github, its giving errors
I hope you don't try the git pull with the "https:"
so first you have to navigate into the directory
cd .xbmc/addons/skin.arctic
try:
git clone git://github.com/jurialmunkey/skin.arctic
EDIT: Sorry made a mistake.
It should just work with just "git pull" when you are in the "skin.arctic" directory. I guess you already knew that. If it isnt working I think it's a github problem.
i tried using both git bash and smartgit 4.6.6, both gave errors
