2013-11-08, 05:50
Jurial, new OSD looks great! When listening to music, it disappears after ten seconds. Is there a way to keep it from doing this? (Yes, it looks that good!)
(2013-11-08, 05:50)deletedpenguin Wrote: [ -> ]Jurial, new OSD looks great! When listening to music, it disappears after ten seconds. Is there a way to keep it from doing this? (Yes, it looks that good!)
(2013-11-08, 05:50)Martijn Wrote: [ -> ](2013-11-08, 05:50)deletedpenguin Wrote: [ -> ]Jurial, new OSD looks great! When listening to music, it disappears after ten seconds. Is there a way to keep it from doing this? (Yes, it looks that good!)
press "i" (info button)
Quote:This controls how long the song information will remain onscreen when the song changes during visualisations. The valid range is "1" to "Indefinite (0)", in seconds. This does not include the duration of any transition effects.
(2013-11-08, 07:14)Steveb Wrote: [ -> ]Add <songinfoduration> to your advancedsettings.xml
<songinfoduration>0</songinfoduration> should do the trik
plus the info button 'i' will still work.
(2013-11-08, 18:27)Ferno Wrote: [ -> ]And the last question, what is the correct approach to update the skin to a new version?
(2013-11-08, 06:13)Tripp Wrote: [ -> ]Should I be worried that the skin shows up broken in the repository? Does this mean it will stop updating?Strange, it shouldn't be marked as broken - I haven't changed any of the dependencies. I'll look into it.
(2013-11-08, 08:14)BenAtNVS Wrote: [ -> ]love this skin !!!Thanks.
I've 3 request (question) :
1 - I use artist info wall with fade cover. it seems to me the corner of artist image is not complelty white.
2 - is it possible to have local extrafanart in music visualization on background.
3 - a gotham version is it prepared?
(2013-11-08, 10:35)Myrddraal Wrote: [ -> ]Excellent skin. I just came to find it thanks to Paul Salem's Big mod, and just wanted to thank you for all the hard work. It is truly awesome.Thanks
(2013-11-08, 18:07)d_hero Wrote: [ -> ]just want to add my love for this skin, ive been using it as default for a while now, and its great. But i wondered if I was missing something. When i change the theme in Appearance to Dark or Carbon Ocean etc, I cant see any difference, nothing seems to change. Is there something im missing or should i be doing something differently?You have to change it to what you want then wait a couple of seconds for it to enable (don't press back or go to another menu).
(2013-11-08, 18:27)Ferno Wrote: [ -> ]First of all, this skin is amazing!!!
(1) How can I adjust TV NEXT aired to show on the seasons overview of each show?
(2) How can I use the TV NEXT aired in one of the home widgets like the one called spotlite etc.
(3) How can I add a whole TV show as an favorite? Not an episode but the whole show so I can jump directly to the overview of that show.
(4) Is it possible to jump to an alphabet letter while browsing trhough the media library?
(2013-11-08, 19:10)Scottland Wrote: [ -> ]Not sure if this is a skin thing, or XBMC/PVR thing - but in the EPG is it possible to switch directly the channel without the info box popping up and having to press 'switch stream'. Ideally, I'd prefer it to switch on enter/return and info would give the popup with the option to record etc.Its an xbmc thing. Add this to your advancedsettings.xml (see http://wiki.xbmc.org/index.php?title=Adv...ttings.xml for more info)
<pvr>
<showepginfoonselect>false</showepginfoonselect>
</pvr>
(2013-11-08, 19:11)PatOso Wrote: [ -> ]jurialmunkey, Awesome skin, congratulations.Thanks once again
(2013-11-08, 22:49)hoopsdavis Wrote: [ -> ]Anyone know if its possible to jump to a channel in the EPG Timeline instead of having to scroll?Yeah I've thought this in the past too but haven't found anything about a way to do it - it really should work in the same way that jumpsms does for the library etc. -- Luckily I don't have that many channels (only Aus Freeview so about 20 channels). You can use the Channel Up/Down buttons in the epg timeline to jump down a page - i.e. jump by 6 channels at a time. Unfortunately that's the best I can suggest currently.
Seems like you should be able to the number of that channel and the TimeLine EPG will jump directly to it.
