Is tvheadend pvr working? I can't seem to get it working in latest jarvis build.
Also do forced subtitles work, I'm using a beebox n3150 by the way.
Thanks the xorg fix worked for me (isengard)
PPA builds for ubuntu 15.10 are now available
mbosner, did you get kodi working on your skylake setup? I have essentially the same hardware as you, but so far no success. Thanks for any pointers!
No matter - I have two HDMI ports on my motherboard. One appears to get turned off on boot (with these recent development OE builds). The other HDMI was working all along...
Most likely such an internal DP to HDMI converter bridge. I don't think there is support anywhere in linux kernel / x driver.
kodi doesn't switch from 50 to 24hz with last build
http://xbmclogs.com/pvthpngbc
and as already said sometimes i get black screen
when it occurs a restart i sufficient but sometimes after bios post and kodi logo i get black screen and i need to remove the power cord
this problem never happened before but only recently
Here is an upstream fix for the "missing refrehsrates":
http://cgit.freedesktop.org/xorg/driver/...bdb1d9b534
I will rebuild the OE builds as we speak. Ickle cached the outputs on xserver start and therefore the modes were not enumerated at all. With this patch no need for xorg.conf anymore.
Edit:
First fixed jarvis version: OpenELEC-Generic.x86_64-6.0-devel-20151031104725-r21512-g3421da2
First fixed Isengard version: OpenELEC-Generic.x86_64-6.0-devel-20151031105023-r21503-gc2fba5d
Thank you , will test this night and report if it's all ok
Could be useful if i post a log (available one in /log folder) when i get the black screen error ?
Updated the initial howto to 15.10 Wily
Changes:
libnfs8 instead of libnfs4
wsnipex's mesa ppa can be dropped. His vaapi ppa is still needed for libva / libva-driver-intel version 1.6.1
For Braswell Users I currently suggest kernel 4.3-rc7. I will update those links the very moment 4.3.0 is out
Concerning the refreshrate issues: I added a dropbox link to a fixed driver that you can install on Ubuntu Wily - with this no xorg.conf is needed.
i have some trouble playing 25hz mkv files with passthrough enabled.
After a time video is getting jerky, same mkv file with sync to audio enabled plays fine.
Also 23.976 and 24 mkv playing without problems with activated passthrough.
Adjust Display Refresh Rate is activated.
Newest javris verison. Asrock beebox 3000.
Log:
http://pastebin.com/TAxKNjSk
Any idea ?
Btw: Thanks guys for your great work!!
@m_gl:
Post /usr/lib/kodi/kodi-xrandr | pastebinit please
(2015-10-31, 17:57)meowmoo Wrote: [ -> ]Is the latest update supposed to fix my issue posted here? http://forum.kodi.tv/showthread.php?tid=...pid2146729
Just tried the isengard build, and still sync 2 times.
And any news on the projectM DLL issue?
No and No. Not target of those developments here.
